any of you expert cleaners got any tips on what degreaser to use on my bike ??
gonna be doing a really good clean for the hull show and want to remove all the stuburn spots of oil and grease off the frame, swing arm, wheels etc etc :D
scot oiler degreaser but also wurth chain and brake cleaner the latter works really well on sprockets and quick should be ok for other parts I assume.
parafin fella, the mutts nutts and cheaper than any sprays I use it all the time.
Use it first on the hard areas with a paintbrush, then use your normal cleaning routine to get rid of any residue.
gunk!
been around years and cheap as chips from halfords. you can get a spray can of it too for those hard to reach places. just spray it on, rub with and old paint brush and then wash it off with water.
Diesel petrol mix I get from work, when muppets cant fathom out what their car runs on.
There have been times when we have more of this stuff than we can cope with, and I tell ya, it shifts all known greasy marks and stains!!
can you ship to hull :lol: :lol:
i went to halfrauds the other day and gunk is well expensive now :?
so is motorcycle degreaser :roll:
think im going to buy some paraffin can stick some in my paraffin sprayer connected to the air compressor :lol:
paraffin should be fine on plastics :)
if you have any doubts remove them
some degreasers are a no no for plastics
i was doing some repairs on a my lower fairings and all i had was some carb and choke cleaner i thought it wont hurt to spray a bit to clean the grease off :?
made all the plastic go really soft so just left it to dry off and all was well plastic went hard again and never miss shaped :lol:
wd40 :wink:
not that great at removing grime from brushed finished items :?
tried it already :lol:
Dont get diesel near plastics(or rubber) It soaks in and makes them swell massively. Its a real problem.
Dunno if paraffin and similar things do the same, but keep diesel off plastic.
thanks for the offer but i need it for tomorrow :?
so will buy some paraffin on the way home from work or nowing my go to halfrauds and buy expensive Gunk!
:idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea: JUST THOUGHT! TFR (Traffic Film Remover) :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea:
ah ha my bro can get me that from work for feck all 8-)
mix 1iter water : 80ml tfr hot water then wash with warm clean water and clean raag after as it smerry but will clean paint sexually and metals alike good with plastic also
  • 10 years later...
About to buy some Paraffin after reading this thread. Few questions:
1) What part of the bike should I never spray this stuff on?
2) How long do a let it soak for?
3) How much water should I mix it with..for example... 4 parts water, 1 part Paraffin, or do I spray it on concentrate?
