Yamaha thundercat suspension
Bhawk
Well I finally passed my test and have been out on my Yamaha thundercat, I'm absolutely loving it, although I have noticed if I go over a bump, I'm bouncing up and down for a good few hundred yards, almost like I'm on a bouncy castle lol.
So how do I firm up the suspension? Is it a matter of buying a specialist tool or can it be done without?
Cheers folks
If it's the rear, then it probably shouldn't do that, no matter how it's set up.
I'd take it to a specialist suspension shop and get their advice. If all it needs is setting up right, they'll tell you.
Sorry I forgot to say it is the rear suspension. Was tempted on fitting r6 shocks on it anyway, but I think ill take it to a bike shop nearby, see what they say before committing to buying a new shock. From what I've seen online it isn't too much of a hard job. Just need to find somewhere that sells the bit that makes it fit
You can adjust the front and rear pretty easy yourself. It is set out in the Haynes if you have one together with the standard positions. When I first started riding mine I thought the back end was overly bouncy (though not as bad as you describe). If you look through the gap in the fairing below the pillion part of the seat (from the chain side of the bike) you will see an adjuster there. Basically a flathead screw with numbers from 1 or 0 (can not remember now) up to 6. Lowest gives softest ride and higher number gives a firmer ride. 4 is the standard and mine was set at position 2 (no idea why anyone would do that). I adjusted it to 4 (simple turn with a screw driver) and the effect was noticeable.
There is a national speed limit road at the back of my village where the large trees lining it have played havoc with the road (you can see the bumps from the roots). Before I had a similar experience of bouncing about over them (left the seat more than once) now the bike skims over them.
The rear suspension is notoriously rubbish on the 'cat I hear but it may the previous owner has just fiddled with it. Perhaps check that it is all set to the standard positions and see what difference that makes? If you do not have the Haynes give me a shout as I do and can let you know the standard specs.
If you ask my mate he will prob say that's how it's supposed to be like his r6 I have told him it's shagged but he refused to believe, lol
Stock unit someone has removed should be just fine as a replacement or there's plenty of upgraded parts out there
Sent from my iPad using Tapatalk Pro
