Joe85 Posted November 18, 2016 Share Posted November 18, 2016 (edited) Need some advice from the good people of TMBF.Are my discs knackered and pads worn???Ducati mentioned to me the other day that my rear disc was blue and i must be resting my foot on the rear. Turns out i do!! A lot! I do a lot of filtering to work and i have developed a habit of not touching the front break and relying on the rear for a smooth ride (when filtering) however, this has developed into me resting my foot on the rear brake pedal. I checked the disc when i got off tonight because it was groaning quite loudly when breaking heavy. When checking i noticed it was HOT!! Almost too hot to touch.See pics below. Im aware of my bad habit and will try to keep my foot off the pedal but do i need to replace the reardisc/pads? Only 3000 miles old.http://uploads.tapatalk-cdn.com/20161118/3f9b85cd3b86733bc6e89e9e33f6effc.jpghttp://uploads.tapatalk-cdn.com/20161118/28c82b327ff9141832877c8246c827db.jpghttp://uploads.tapatalk-cdn.com/20161118/63cd016239df87561b6d2ae5aa4a3d36.jpg Edited November 18, 2016 by Joe85 Quote Link to comment Share on other sites More sharing options...
Guest Posted November 18, 2016 Share Posted November 18, 2016 Bloody ell, my fronts lasted 5k! And that was hard use.From pics i see worn pads but the disc looks fine Get your feet on the pegs and keep them there Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 18, 2016 Author Share Posted November 18, 2016 Bloody ell, my fronts lasted 5k! And that was hard use.From pics i see worn pads but the disc looks fine Get your feet on the pegs and keep them thereCheers drz. The inside pad (last picture) looks completely worn down to me.Any good online outlets for pads? Quote Link to comment Share on other sites More sharing options...
Stu Posted November 18, 2016 Share Posted November 18, 2016 As DRZ says! keep your feet on the pegs as for pads try ebay and look for EBC HH pads Quote Link to comment Share on other sites More sharing options...
TimR Posted November 19, 2016 Share Posted November 19, 2016 Also see if you can adjust the pedal position so that it is still comfortable and easy to use but in a slightly lower position so that if your foot is covering pedal its not actually depressing it but bear in mind you may have to adjust rear brake switch position if its a manual type and not pressure activated Quote Link to comment Share on other sites More sharing options...
JRH Posted November 19, 2016 Share Posted November 19, 2016 Adjusted mine to be more comfortable and easier to use, lower Han the book level. Forgot about the switch. Rode for a couple of days with the brake light on till I noticed. Quote Link to comment Share on other sites More sharing options...
Tango Posted November 19, 2016 Share Posted November 19, 2016 Rotor looks ok......but pads look like they're shot...... Yeah, good advice on moving the pedal down a bit..... Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 Cheers guys. Got some pads today and will be fitting tomorrow! On a side note. Ring Ducati and ask for pads = £60 "oh its cuz they are brembo pads and are better"Find a Bike workshop up the road who has then in stock= £24. Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 Annnnnd...ive f**king had it with Ducati.Another allen bolt about to round off on the calliper. Im "this" close to smashing this bike to bits with a hammer.Piece of shit. More i work in this bike the more convinced i am that the build quality is just shocking. Take into consideration that this is a 4 month old bike, kept in a garage overnight, they are clearly over torquing the bolts. I dont even think the worn break pads are my fault. I know i said i rest my foot on the break lever but i was testing it out earlier and the pressure applied to it by my foot (only when filtering i might add) doesn't even activate the brake light microswitch or slow they tyre down (tested it on the stand). Tempted to leave the garage door open tonight with the key next to it. B******s. Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 Ok. Rant over. (Although im considering this thread my whinging corner for the rest of the weekend)Gonna weld an Allen key into the head and remove, replace and flog the bike. Quote Link to comment Share on other sites More sharing options...
Stu Posted November 19, 2016 Share Posted November 19, 2016 whinge away we will just ignore you Looking at the pics you should be able to get a pair of mole grips on the caliper bolts Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 whinge away we will just ignore you Looking at the pics you should be able to get a pair of mole grips on the caliper bolts Tried. Slipping off. Think it is well seized in there. Was tempted to file it flat at top and bottom to give more grip. Quote Link to comment Share on other sites More sharing options...
Stu Posted November 19, 2016 Share Posted November 19, 2016 grips can't be tight enough on the bolt if you did go the filing route then make a spanner fit Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 grips can't be tight enough on the bolt if you did go the filing route then make a spanner fit It has a ribbed exterior so the grips are chewing it up. It really is a cheap bolt, like the rest of em. Just gonna weld and replace it. What the odds on the head snapping off!? Quote Link to comment Share on other sites More sharing options...
Stu Posted November 19, 2016 Share Posted November 19, 2016 depending on the material used for the bolt it might not even weld if it does snap it would probably go at the bolt head leaving enough to get hold of when the caliper is off thats if the caliper will come off after the bolt has snapped it looks like the bolt screws in to the bracket at the back and not in to the caliper Quote Link to comment Share on other sites More sharing options...
Tango Posted November 19, 2016 Share Posted November 19, 2016 It needs an FBH, mate....... Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 19, 2016 Author Share Posted November 19, 2016 It needs an FBH, mate....... The whole bike does Quote Link to comment Share on other sites More sharing options...
TimR Posted November 19, 2016 Share Posted November 19, 2016 There are two types of mole grips ....Shit cheap copies which dont grip feck all and twist Or Proper Mole grips As said always allen bits on any bolt of reasonable torque And give the the recesses a good clean out before using the bit and then drive it home with a few taps .If you can access the heads easy enough ... small set of decent stilsons Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 20, 2016 Author Share Posted November 20, 2016 There are two types of mole grips ....Shit cheap copies which dont grip feck all and twist Or Proper Mole grips As said always allen bits on any bolt of reasonable torque And give the the recesses a good clean out before using the bit and then drive it home with a few taps .If you can access the heads easy enough ... small set of decent stilsons Huzzah! It seems enough alcohol and crying can solve anything!!!And some pump pliers. http://uploads.tapatalk-cdn.com/20161120/078e7eb60a13fae7f972aa065448bfdd.jpghttp://uploads.tapatalk-cdn.com/20161120/5b60c2daeec1a4723dac9c50cd371c7c.jpgThe inner pad is really bad. Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 20, 2016 Author Share Posted November 20, 2016 Well, personal crisis over and brake pads replaced. Not fully convinced i am causing this, will go for a ride using front break only and see if rear disc is getting hot anyway. Thanks for allowing me to launch my toys out of the forum pram Quote Link to comment Share on other sites More sharing options...
JRH Posted November 20, 2016 Share Posted November 20, 2016 You're welcome.It may be the caliper or piston is sticking and not letting the one pad move away from the disc when releasing the brake, hence the one pad wearing.If it's a sliding caliper a good greasing of the pins otherwise clean up the Pistons and make sure they are free. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 20, 2016 Share Posted November 20, 2016 Just an idea. Nowhere near the breaks http://i157.photobucket.com/albums/t75/GixxerSup/TheMF/images_zpsaygsvxu8.jpg Quote Link to comment Share on other sites More sharing options...
Guest Posted November 21, 2016 Share Posted November 21, 2016 Just an idea. Nowhere near the breaks http://i157.photobucket.com/albums/t75/GixxerSup/TheMF/images_zpsaygsvxu8.jpgI look like that on my breaks, but his right foot is still near the brake Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted November 21, 2016 Share Posted November 21, 2016 Hi, l had a similar problem one time with the Bimota, the bike went in for it first free service on riding it home l notice it was not running free on the overrun, then came the smell of burning from the rear end. On inspection l found that they had adjusted the rear brake peddle return stop screw to tight causing the brake to drag " cost them a new disc it was blued and a new set of pads". Before you set off give the wheel a spin to make sure it free then apply the rear brake and see if there's enough free travel before the brake bite's, remember as the brake heats up and generates heat this is also transmitted into the oil which will cause a small amount of expansion enough to make the pads drag. Quote Link to comment Share on other sites More sharing options...
Joe85 Posted November 22, 2016 Author Share Posted November 22, 2016 Ok, so it is definitely down to the way i ride. Quote Link to comment Share on other sites More sharing options...
