RantMachine Posted February 3, 2017 Share Posted February 3, 2017 Right so I have my front wheel booked in at a local garage to have the spokes done, which means I need to take the thing off tonight. Not got a centre stand, but I have got a paddock stand and a small jack. But, a certain housemate's bikes were too heavy for my paddock stand and now it sags - not convinced I trust it to support the bike for the whole time I'm out getting the wheel done!So here's the question: instead of taking the whole thing off the floor, what if I use the jack under the sump to shift the weight off the front wheel and onto the rear while and sidestand just enough to get the wheel out then lower it down gently so the forts are on the floor. Not gonna do them any harm, is it? Bike only weighs about 130kg. Guess I could rest them on my toolbox so the bike doesn't tip too much.Inb4 bodge job, OF COURSE IT IS THAT'S WHAT I DO. Quote Link to comment Share on other sites More sharing options...
Lateralus Posted February 3, 2017 Share Posted February 3, 2017 Just do what I do with my mountain bike, and flip it over onto the seat and handlebars! /Useful contribution Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 Dangit man you asked for more motorcycle themed threads and this is how you repay me Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 Stuff it, I'm just gonna stick a jack under the front of the frame and balance it on the stand and rear wheel. Fingers crossed the jack doesn't slip while I'm in town I've taken the front wheel off the CG in the same way and everything went fine, and this thing only weighs 15kg more Quote Link to comment Share on other sites More sharing options...
Westbeef Posted February 3, 2017 Share Posted February 3, 2017 Glad we could help Quote Link to comment Share on other sites More sharing options...
Mawsley Posted February 3, 2017 Share Posted February 3, 2017 Stuff it, I'm just gonna stick a jack under the front of the frame and balance it on the stand and rear wheel. Fingers crossed the jack doesn't slip while I'm in town I've taken the front wheel off the CG in the same way and everything went fine, and this thing only weighs 15kg more You got roof struts in the garage you can loop some rope around? Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 Stuff it, I'm just gonna stick a jack under the front of the frame and balance it on the stand and rear wheel. Fingers crossed the jack doesn't slip while I'm in town I've taken the front wheel off the CG in the same way and everything went fine, and this thing only weighs 15kg more You got roof struts in the garage you can loop some rope around?Nah, sadly not. Plain concrete all the way around. Quote Link to comment Share on other sites More sharing options...
old-timer Posted February 3, 2017 Share Posted February 3, 2017 You don't have a main stand, or a center stand, or how is it called in English ?If you do, you could do it my way.Park the bike on the stand, and support the heavy part (engine) with a stool or something.Then take the wheel out, it should keep, my Dakar is a lot heavier than your 135 kg bike. I was lucky, the stool was exactly the right hight, but a pile of wood could do the job as well...Good luck. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2017 Share Posted February 3, 2017 Should work fine. I use an ABBA stand with a jack under the front of the engine (actually lifts on exhaust which I dont like). If I'm leaving it that way for Amy length of time I put a stool under the bottom of the fork leg or chair under the stem if the forks are coming out. That's a 200kg bike.Even if it falls over its a dirt bike. It's designed for falling over. Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 Yeah I just don't want it falling onto the forks without a wheel attached, it was designed to take a lot of shit but maybe not quite that @Old-Timer No center stand sadly, otherwise this would be pretty painless. When I had to take the from wheel off my old F650 I did exactly the same thing as you, only using a jack instead of a stool! Quote Link to comment Share on other sites More sharing options...
Joeman Posted February 3, 2017 Share Posted February 3, 2017 Hang it from the ceiling like I did when changing the forks on my GSXR. Quote Link to comment Share on other sites More sharing options...
Hoggs Posted February 3, 2017 Share Posted February 3, 2017 Hang it from the ceiling like I did when changing the forks on my GSXR. You got roof struts in the garage you can loop some rope around?Nah, sadly not. Plain concrete all the way around. Someone hasn't read the thread Quote Link to comment Share on other sites More sharing options...
tigger004 Posted February 3, 2017 Share Posted February 3, 2017 Support it on the jack under the engine as suggested earlier. Then with the wheel out chock under the fork legs or if you can, lower it on to a sheet of wood on the floor? My ethos is - if something is already as low as it can go it can't fall any furtherSent by Tigger from my Tablet Quote Link to comment Share on other sites More sharing options...
MotoTrackr Posted February 3, 2017 Share Posted February 3, 2017 Support it on the jack under the engine as suggested earlier. Then with the wheel out chock under the fork legs or if you can, lower it on to a sheet of wood on the floor? My ethos is - if something is already as low as it can go it can't fall any furtherSent by Tigger from my TabletAlso good advice after you've had a few too many beers!Sounds like balancing between a jack and the side stand would do the job as well. Especially with a light bike. Quote Link to comment Share on other sites More sharing options...
Joeman Posted February 3, 2017 Share Posted February 3, 2017 Someone hasn't read the thread Busted by the reading police Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 All done. Had to take the bash plate off in order for the jack to get a decent grip on the frame, kept sliding out. Turns out I've smashed a corner off my bash plate at some point So now the jack is lifting from the front right of the frame, and the weight is spread over the back wheel and sidestand. Once the wheel was out I put my metal toolbox under the fork to make it that bit more stable.Cheers all! Quote Link to comment Share on other sites More sharing options...
mailee66 Posted February 3, 2017 Share Posted February 3, 2017 I was faced with the same problem when I had my wheels powder coated. My solution was to use a pair of ladders similar to those in Joemans picture and sling a ratchet strap around the head stock to lift it off the floor. It worked a treat. Quote Link to comment Share on other sites More sharing options...
old-timer Posted February 3, 2017 Share Posted February 3, 2017 All done. Well done. Now just don't squeeze the front brake lever... Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 3, 2017 Author Share Posted February 3, 2017 All done. Well done. Now just don't squeeze the front brake lever... One step ahead! I've got a spanner cable tied in place between the pads until the wheel goes back in Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted February 4, 2017 Share Posted February 4, 2017 [i've got a spanner cable tied in place between the pads until the wheel goes back in Profesh. Profesh to the max. Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted February 4, 2017 Share Posted February 4, 2017 With the bike on the rear stand and the front wheel still on the ground crack loose all the securing nut's and bolts to the front wheel, if there's a belly pan on the bike remove that and then place a block of wood under the engine or exhaust pipes and jack the front of the bike up from there. You should then without any unnecessary force be able to remove the front wheel. Reverse the procedure to reinstall. Quote Link to comment Share on other sites More sharing options...
RantMachine Posted February 4, 2017 Author Share Posted February 4, 2017 Already off! Just sticking it back on again, in fact Quote Link to comment Share on other sites More sharing options...
