Foxy Stoat seeks Pig Posted April 22, 2017 Posted April 22, 2017 Happy with the pass obviously but fork seals are weeping slightly. I haven't done any research yet but how tricky is it to replace fork seals on a FZ6. Garage has quoted approx. £200 but I'm keen on giving it a try if it's within my capabilities and I don't need any specialist equipment.Actual advisory note is:Front Front shock absorber has light misting of stanchion (2.3.3) Quote
Guest Posted April 22, 2017 Posted April 22, 2017 It's pretty easy on most bikes. \The hardest part is getting the damper bolt out of the bottom as the damper just spins. I use an electric impact gun to zap it loose but you can also stick a wooden dowel down inside the stanchion to hold it still. Quote
Bhawk Posted April 22, 2017 Posted April 22, 2017 https://www.youtube.com/watch?v=vrmYJgcGX30&t=6sDelboys garage is a source of a lot of information, he explains things thoroughly and simply.he has saved a small fortune over the years!Check out his other videos too, he covers most things including simple skills like welding, soldering, grinding etc Quote
Phooey Posted April 22, 2017 Posted April 22, 2017 Del boy is amazing. If this helps, I barely know one end of a spanner from the other but I have changed the fork seals in my ZZR600 when I rebuilt the forks after re-chroming the stanchions. Piece of pi55, as they say! Delboy's vid helped me! Quote
Tango Posted April 22, 2017 Posted April 22, 2017 May be worth having a go with a SealMate. .......check the link to it in this thread.....https://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=63525 Quote
Foxy Stoat seeks Pig Posted April 23, 2017 Author Posted April 23, 2017 Thanks all. Will give the SealMate a try first. Worth a try for £6. Quote
raesewell Posted April 23, 2017 Posted April 23, 2017 I had a weeping fork seal on the FJR and SealMate worked for a few weeks but in the end I had to have them changed. It might buy you some time to save up to get the seals changed Quote
Foxy Stoat seeks Pig Posted April 23, 2017 Author Posted April 23, 2017 Ah right so maybe not a permanent fix then. I think the seals themselves are about £6 each, its the faffing about getting the forks out I need to man up for. . Should be ok, I will need to get a head stand though. Quote
Foxy Stoat seeks Pig Posted May 8, 2017 Author Posted May 8, 2017 Didn't get on with the sealmate at all. In fact couldn't even get it wedged in the seal after removing the dust cap/seal. So looking ahead i'm going to try and take forks out and replace the oil and seals. Just need to research (in great detail) the whys and hows first. Tools wise I should be ok but need a head stand to lift the front. Quote
Mr Fro Posted May 8, 2017 Posted May 8, 2017 That's where you need an Anna or BeeGee stand with the tie-down strap at the back - no pissing about with a rickety head stand. Quote
eastanglianbiker Posted May 8, 2017 Posted May 8, 2017 dont use pattern seals they tend to often fail very quick its always best to go genuine Quote
Foxy Stoat seeks Pig Posted May 9, 2017 Author Posted May 9, 2017 Was looking at WEMOTo for parts, should i be looking elsewhere? Quote
Phooey Posted May 10, 2017 Posted May 10, 2017 Seals are only a few quid each and I learnt the hard way ... £3 a seal and three months later forks are out again ... Genuine £6 a seal and they are still holding two years on!I'd go to Yamaha personally! Quote
TimR Posted May 10, 2017 Posted May 10, 2017 Fork seals tend to go for one reason. A damaged travelling area . Check the stanchions for any imperfection before replacing the seals . Any corrosion or small dinks can be smoothed out with wet/dry paper of different grades. Make sure any section of stanchion the seal has to travel over on its journey to its intended location is clean and smooth otherwise you will rip the seal .( fork oil)Wet/grease the seals lips before installing Pattern parts are fine as long as you don't go for the cheapest from overseas type . Quote
Foxy Stoat seeks Pig Posted May 10, 2017 Author Posted May 10, 2017 Looking a at a couple of these http://www.wemoto.com/bikes/yamaha/fz6-s_fazer_non_abs___floating_calipers_5vx/04-05/picture/fork_oil_seal_-_single_oem/They suggest they are a genuine Yahama part Quote
Guest Posted May 10, 2017 Posted May 10, 2017 As Bob suggested. Clean them first.I ride off road and constantly have leaky forks. 9 out of 10 times or even more, seal mate will stop the leak.Fork seals should really last the lifetime of the bike in your ownership anyway, like 2 stroke pistons... Most replace needlessly Quote
Foxy Stoat seeks Pig Posted May 11, 2017 Author Posted May 11, 2017 Maybe i should try the Sealmate again. Maybe i was just using it incorrectly (youtube vid makes it look so easy). but i could see exactly how it fits into the seal. i only removed the dust cap/cover nothing else. Quote
