owlis Posted October 19, 2017 Share Posted October 19, 2017 Hey guys!Just changing the engine oil on my Mash Black 7. First time bike, and don't have many/any biker friends who are showing me the ropes. Just drained the engine oil, but when I took the cap off, a spring and a bolt came out from inside. They're obviously meant to be there, but which way round they go back in isn't something I know. Spring first, with bolt pressing against the cap? Or bolt first, with spring pressing against the cap? The user manual is very brief and written in patchy chinglish. Any help much appreciated. Thanks, Oz Quote Link to comment Share on other sites More sharing options...
Westbeef Posted October 19, 2017 Share Posted October 19, 2017 Picture please? I assume this is the cap where you will re-fill the oil, does the spring have something to sit on if you put that in first or is it just going to drop straight into your engine? Quote Link to comment Share on other sites More sharing options...
owlis Posted October 19, 2017 Author Share Posted October 19, 2017 It's the cap from underneath, where the old oil drains out from. ( on the left ). And to it's right, is the little ... well it's not really a bolt, it has no weave, it's just like a bullet that tucks inside that spring. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted October 19, 2017 Share Posted October 19, 2017 Is the piece inside the spring the filter? Will it go together like this;"> Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 19, 2017 Share Posted October 19, 2017 That thing on the right has nothing to do with the oil drain. Looks like part of the gear selection mechanism. Got a bigger pic cycle of it? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 19, 2017 Share Posted October 19, 2017 That thing on the right has nothing to do with the oil drain. Looks like part of the gear selection mechanism. Got a bigger pic cycle of it? I know this is a common mistake people make with the Suzuki VanVan engine - removing the gear selector blanking plug instead of the oil drain plug - and what comes out looks just like that. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 19, 2017 Share Posted October 19, 2017 (edited) Good post MB. In that case it could be the gearbox selector detent spring and ball end. The spring goes in first whilst the ball end is inserted in the spring. Screw the plug in carefully with a new washer or sealant, then stroke the gearbox. Edited October 19, 2017 by megawatt Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 19, 2017 Share Posted October 19, 2017 That thing on the right has nothing to do with the oil drain. Looks like part of the gear selection mechanism. Got a bigger pic cycle of it? I know this is a common mistake people make with the Suzuki VanVan engine - removing the gear selector blanking plug instead of the oil drain plug - and what comes out looks just like that. Yep , I'd go with that theory. Many bikes have blanking plugs or gallery plugs that ( quite understandably ) get mistaken for drain plugs. I reckon it goes back in spring first. I wouldn't worry too much but I probably would undo the real one incase the first one didn't let all of the oil out . Quote Link to comment Share on other sites More sharing options...
Stocky Posted October 19, 2017 Share Posted October 19, 2017 then stroke the gearbox. What if it doesn't respond to stroking?Do you have to kiss and cuddle it? Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 19, 2017 Share Posted October 19, 2017 Can't fix stupid. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 19, 2017 Share Posted October 19, 2017 Here's a drawing of a very similar set of parts on a Suzuki GN 125 so I reckon MB & MW have got it spot on. It's basically a spring loaded stopper that limits the movement of the selector drum . http://i.imgur.com/1jnDO2T.png the spring seems to be in a different place but designs will vary although the function is the same. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 19, 2017 Share Posted October 19, 2017 Thanks FB. Parts 19 & 22. It makes sure that the selector drum stops in a particular position and doesn't continue turning. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 19, 2017 Share Posted October 19, 2017 You probably need to get a workshop manual for your particular bike to make sure it goes back together properly. Quote Link to comment Share on other sites More sharing options...
owlis Posted October 20, 2017 Author Share Posted October 20, 2017 Is the piece inside the spring the filter? Will it go together like this;"> Aside from the fact that my spring doesn't click in, it just sits on top, that is what i'm looking at. Thanks for that link. Think the problem is solved. Others are saying that it's part of gear selection. Why then did it drop out covered in oil when I undid the cap? Hmmm. Hopefully we're right. Quote Link to comment Share on other sites More sharing options...
owlis Posted October 20, 2017 Author Share Posted October 20, 2017 That thing on the right has nothing to do with the oil drain. Looks like part of the gear selection mechanism. Got a bigger pic cycle of it? I know this is a common mistake people make with the Suzuki VanVan engine - removing the gear selector blanking plug instead of the oil drain plug - and what comes out looks just like that. Yep , I'd go with that theory. Many bikes have blanking plugs or gallery plugs that ( quite understandably ) get mistaken for drain plugs. I reckon it goes back in spring first. I wouldn't worry too much but I probably would undo the real one incase the first one didn't let all of the oil out . Right, right. That's interesting. Seems silly that they'd have the drain plug right next to gear selector banking plug ... and that both would drain the oil ... a bit deceptive. I'll see whether the clutch is working :S Quote Link to comment Share on other sites More sharing options...
owlis Posted October 20, 2017 Author Share Posted October 20, 2017 That thing on the right has nothing to do with the oil drain. Looks like part of the gear selection mechanism. Got a bigger pic cycle of it? I know this is a common mistake people make with the Suzuki VanVan engine - removing the gear selector blanking plug instead of the oil drain plug - and what comes out looks just like that. Yep , I'd go with that theory. Many bikes have blanking plugs or gallery plugs that ( quite understandably ) get mistaken for drain plugs. I reckon it goes back in spring first. I wouldn't worry too much but I probably would undo the real one incase the first one didn't let all of the oil out . Would I not be able to change gears if it were the gear selector plug that I removed? Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 20, 2017 Share Posted October 20, 2017 What ? Please don't try to change gear with the plug and spring removed. Why would you even think of doing that? This is an important part of the gearbox , it stops the selector drum going round too far. If you leave it out all the strain will be applied to the selector forks . OK , yes the gearbox might still work but its just not a good idea to mess with things . Tip, when you put it back I think it would be wise to have the bike in 2nd or 3rd gear as this may make it easier to locate. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 20, 2017 Share Posted October 20, 2017 Why would you check the clutch,? It's got nothing to do with the clutch. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 20, 2017 Share Posted October 20, 2017 It will come out covered in oil and drain the oil because the engine and transmission share the same oil. I know a few folk who didn't realize there was a separate drain bolt and always drained the oil by removing the transmission selector retaining bolt. So long as they put it back the right way round it didn't do any harm But I've also known people buy a second hand bike and have gear selection problems, then discover the previous owner had been draining the oil via the selector plug and got the selector back in with part of it upside down. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 20, 2017 Share Posted October 20, 2017 Patchy Chinglish or not I somehow doubt that even the worst of owners handbooks would not show a clear picture or diagram of exactly where the oil drain plug is located.....ok ignore that statement, I've just seen the owners handbook for the Mash QM 125, that is very vague so all is forgiven.http://i.imgur.com/m4Kk2kC.png Could even be wrong by the looks of it, I would have thought it was nearer the front. Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted October 20, 2017 Share Posted October 20, 2017 At least you drained the oil first!As I said In another thread I helped a biker who hadnt drained oil just added to it so engine was Very IllAnd that wasnt a 125 rider he had a ZX10R!! Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 20, 2017 Share Posted October 20, 2017 Well look what I found on this very forum..http://i.imgur.com/bnHGtfR.png and here's the reply I posted back then. This one looks a lot more like the parts in question and definitely suggests that the spring goes in after the stopper. You will have to work backwards through pit stop posts to page 5 entitled Help!! to find the full thread ( April 24 ).http://i.imgur.com/FTVKP36.png Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 21, 2017 Share Posted October 21, 2017 Good spot - what tends to happen is that people put the part numbered 17 back located inside the spring (ie upside down) and then find gear selection is tricky. Often the gears will work but finding neutral is hit and miss. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 21, 2017 Share Posted October 21, 2017 It's a detent. Designed to keep the gear selector drum in the neutral position with minimum friction. Quote Link to comment Share on other sites More sharing options...
