Foxy Stoat seeks Pig Posted January 13, 2018 Author Share Posted January 13, 2018 Ok quick update.I satin the shed for a few hours this afternoon, had a beer and cleaned everything thoroughly. Installed new seals and put pistons back into place.I now have the calipers back on the bike now, just need torqueing up. I gave the problem helicoil one final try and managed to get the insert flush one side then tidied up the back end so that was flush too. Probably would have been easier if I had used the correct length insert but I think it will do for now.Here is my next issue though, I filled the brake fluid reservoir and started to pump the lever but it just pumps endlessly, there is no pressure to push the pistons out. Does that mean it needs bleeding> which side do I bleed first? oh and how exactly do you bleed the system? Thanks for all the help so far..... Quote Link to comment Share on other sites More sharing options...
Stu Posted January 13, 2018 Share Posted January 13, 2018 Best ignore my pm then Yes the system will need bleeding up have a Google on how to do it They say start with the furthest away but I always keep going back and forth between them till the brakes are good Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 13, 2018 Author Share Posted January 13, 2018 Excellent so there is hope I could get it working again tomorrow. I will do some YouTube research tonight. Then next weekend maybe tackle the back brake which ironically is the one I can hear binding the most.It was a pretty messy job removing the calipers. Brake fluid on the driveway. Wife not happy. What works best to clean it. Quote Link to comment Share on other sites More sharing options...
raesewell Posted January 13, 2018 Share Posted January 13, 2018 White spirit should clean it up from the drive followed by soapy water, Quote Link to comment Share on other sites More sharing options...
TimR Posted January 13, 2018 Share Posted January 13, 2018 Excellent so there is hope I could get it working again tomorrow. I will do some YouTube research tonight. Then next weekend maybe tackle the back brake which ironically is the one I can hear binding the most.It was a pretty messy job removing the calipers. Brake fluid on the driveway. Wife not happy. What works best to clean it. http://www.halfords.com/workshop-tools/garage-equipment/garage-essentials/laser-absorbent-oil-drip-matAt a £1 they are worth it to save stainage Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 13, 2018 Author Share Posted January 13, 2018 will try white spirits when job is done. those mats look quite handy too. Quote Link to comment Share on other sites More sharing options...
raesewell Posted January 13, 2018 Share Posted January 13, 2018 Don't forget the soapy water afterwards or it will leave a stain. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 14, 2018 Author Share Posted January 14, 2018 Starting bleeding the brakes. There is pressure now but I can still pull the lever all the way back to the handlebar grip. So its still not how it was before. Im using an easy bleed tube which has some kind of valve on it. Only thing is im getting through a lot of fluid, as in have to keep topping it up. Ive used almost 500ml already, is this normal?? Ive just been to buy a 1 litre bottle in case in need it.When I started there were some huge air bubble in the tube, they have gone now.Do I just keep going doing both sides until the lever firms up some more? Quote Link to comment Share on other sites More sharing options...
TimR Posted January 14, 2018 Share Posted January 14, 2018 Have you bled master cylinder ?Place end of tube in fluid as the valves are not 100% airtight on the cheaper bleeders Pump andopen bleed nipple then close and repeat is best optionBleed until no air bubbles .Lever will not firm with bleed nipple openNo 500ml is not normal check your method Top up reservoirPlace lid or cover reservoir Place tube on nipplePump lever a five timesHold lever in Undo bleed nippke whilst keeping pressure on lever at all times .lever will go towards bar as fluid releases .KEEP HOLDING LEVER INTighten bleed nipple Release lever only after nipple is tight Pause Check fluid level and top up if necessaryAnd repeat above until no air bubbles are visible in tube Should only take a few rounds of aboveOn both calipers Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 14, 2018 Author Share Posted January 14, 2018 Haven't bled master cylinder but can see an air coming up when I press the lever. Sometimes fluid will shoot up too. Quote Link to comment Share on other sites More sharing options...
TimR Posted January 14, 2018 Share Posted January 14, 2018 Haven't bled master cylinder but can see an air coming up when I press the lever. Sometimes fluid will shoot up too. That's normal hence why lid or cover ;Bleeding master cylinder very much like calipers Have some rags ready Top up fluid Cover Locate pipe exiting reservoir to brakes it may have a bleed nipple on it or you will need to have spanner to undo banjo bolt .Do not undo yet .place a few rags under the bolt / or place tube on nipple so fluid doesnt contact paintwork etc Pump lever a few times Hold lever in Undo nipple/ banjo bolt ( beware on banjo bolt fluid can go multi directional so may be worth placing a rag over the area to protect you and area .Hold lever in and tighten bolt/nippleRepeat a few timesThen bleed calipers .DO NOT ALLOW RESERVOIR TO GO BELOW MINIMUM Quote Link to comment Share on other sites More sharing options...
JRH Posted January 14, 2018 Share Posted January 14, 2018 Also try rotating the calipers so any air trapped in them will migrate up to the bleed nipple. A few gentle taps helps. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 14, 2018 Author Share Posted January 14, 2018 Method above seems to have worked. Many many thanks. The YouTube video I saw last night said to open valve and keep pumping, hence why I was wasting so much fluid.So all seems fine now. Maybe a little test run before taking it tomorrow though.Think I will leave the back brake for another weekend. Too stressful Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 14, 2018 Author Share Posted January 14, 2018 : Also try rotating the calipers so any air trapped in them will migrate up to the bleed nipple. A few gentle taps helps. Calipers were fixed back on bike so couldn't try this. Assuming I have understood correctly. Quote Link to comment Share on other sites More sharing options...
JRH Posted January 14, 2018 Share Posted January 14, 2018 : Also try rotating the calipers so any air trapped in them will migrate up to the bleed nipple. A few gentle taps helps. Calipers were fixed back on bike so couldn't try this. Assuming I have understood correctly. Yep, calipers off twist and rotate a bit. Had to do that to the GPX after new seals fitted to get all the air out. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted January 21, 2018 Author Share Posted January 21, 2018 Finally got the bike back on the road this weekend. Thought it was ok last week but after couple of rides I noticed that the right disc was scorching hot, too hot to touch. I noticed the caliper when bolted on wasn't aligned properly so the pads were constantly rubbing on the disc. Ordered another caliper during the week, cleaned it up like new and fitted It yesterday, also had no problems bleeding the lines this week.I also ordered some shorter helicoils and have done a proper job on the stripped thread so I have a spare working caliper now.I now feel confident enough to take on the back caliper seals but waiting for some dryer weather for that.Car is staying at home this week and i'm back on the bike, so all is well Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 22, 2018 Share Posted January 22, 2018 Ok quick update.I satin the shed for a few hours this afternoon, had a beer and cleaned everything thoroughly. Installed new seals and put pistons back into place.I now have the calipers back on the bike now, just need torqueing up. I gave the problem helicoil one final try and managed to get the insert flush one side then tidied up the back end so that was flush too. Probably would have been easier if I had used the correct length insert but I think it will do for now.Here is my next issue though, I filled the brake fluid reservoir and started to pump the lever but it just pumps endlessly, there is no pressure to push the pistons out. Does that mean it needs bleeding> which side do I bleed first? oh and how exactly do you bleed the system? Thanks for all the help so far.....It needs filling before you start bleeding . Cheapest and quickest way is stick a meter of pvc tube on the furthest away bleed nipple, open and suck. When you see fluid , stop because it doesn't taste very nice . Quote Link to comment Share on other sites More sharing options...
