Xom Posted June 2, 2018 Posted June 2, 2018 Morning folks,Small issue with a new ('18) MT-07. Less than 1k miles.If I align the chain using a laser alignment tool on the rear sprocket, so that it is perfectly aligned, the wheel alignment on the bike is off. This is verified not only by the marks on the swingarm but also by simply noting a veer off to the right when letting go of the bars on an flat road.Conversely, If I align the rear wheel to the front (using various methods, although the swingarm marks appear fairly accurate for this) so that the tracking is true straight on a flat road, the chain is not aligned correctly.I haven't had this problem before, and haven't been able to find much from searching myself. As I said, its a new bike which has not been involved in any incidents what so ever so I would assume there should be no issues with bent frame etc.Any thoughts?Thanks in advance. Quote
Tango Posted June 2, 2018 Posted June 2, 2018 Yes, [mention]megawatt[/mention] is right.....take it back to the dealer..... Quote
TimR Posted June 2, 2018 Posted June 2, 2018 1.Does the bike require a first dealers service at a recommended milage ie 500miles has this been done ? If No why not ? 2. Was it fine before you adjusted the chain ?If yes then you have not adjusted it correctly 3. Have you read the owners manual regarding adjusting procedures ? Quote
oldgrump Posted June 2, 2018 Posted June 2, 2018 My question would be, Why are you adjusting a Chain with less than a 1000 miles on it!!!!!!!! Quote
TimR Posted June 2, 2018 Posted June 2, 2018 My question would be, Why are you adjusting a Chain with less than a 1000 miles on it!!!!!!!! Because they more than likely missed number 1 on my list Quote
Throttled Posted June 2, 2018 Posted June 2, 2018 I agree with back to the dealer. They often have to do an end build of the bike depending on how it arrives with them. Bikes are transported in packing cases and may not have had the front wheel or bars fitted during transportation, which the dealer then fits. There could be an issue with them or the original build. Quote
fullscreenaging Posted June 2, 2018 Posted June 2, 2018 My question would be, Why are you adjusting a Chain with less than a 1000 miles on it!!!!!!!! Mine needs checking & adjusting every 600 miles Quote
Guest Posted June 2, 2018 Posted June 2, 2018 It's good to check it regularly but if it needs adjusting every 600 miles I'd suggest more regular lubing. Rarely do any of my chains actually need adjusted, except the cheap shit on my 125. Quote
Xom Posted June 2, 2018 Author Posted June 2, 2018 Thanks for the replies,It's going in for first service next week, but I wanted to have a better understanding if this was something simple before bringing it up with them.The chain slack was out of spec after approx 300 miles, so I adjusted it then, which is when I first noticed the issue. I have since been tweaking things back and forth trying to find equilibrium and have not managed it, hence the question.Before I adjusted the chain the first time, the wheel alignment was true and the chain alignment was not - and yes, I have read the owners manual and followed it word for word to adjust.Thanks again for the input. Quote
oldgrump Posted June 2, 2018 Posted June 2, 2018 My question would be, Why are you adjusting a Chain with less than a 1000 miles on it!!!!!!!! Mine needs checking & adjusting every 600 miles Hi as [mention]Meggark[/mention] you need to lube or buy better chains if you need to adjust at 600 miles. Bloody hell that means if I did my normal run to Scotland I would have to take tools to adjust my chain. Quote
Stu Posted June 3, 2018 Posted June 3, 2018 [mention]Xom[/mention] can you actually see the chain out of alignment or are you just going by the laser alignment tool?Could be that the tool is out and not the chain! Quote
Xom Posted June 3, 2018 Author Posted June 3, 2018 Hi Stu!I have checked the tool against other things and it appears fine, I also checked the chain with the little clamp/rod tool type as well which confirmed it. I do believe I can see the misalignment by eye, but its not too easy for me to see like that - I don't have a great eye for that sort of thing. It is not waaaaay out of alignment to look at, but as it's a new bike I don't think it should be an issue, and it's certainly enough that with the chain in alignment, letting go of the bars will take the bike to the right prominently, even against a steep camber. Quote
megawatt Posted June 3, 2018 Posted June 3, 2018 Factory alignment marks are often not accurate. Quote
