Have you been moonlighting during lockdown [mention]Stu[/mention] ? :shock:
Thankfully it happened during quarantine so not too many around.
I do wonder how it happened though. I first thought it could be brake failure but then I remember reading something about how airbrakes lock on if something goes wrong with the braking system. Unless I'm wrong about that which is always likely :D :scratch:
No you're right they do lock on
Probably a medical episode of some form! or got off the bus and left the handbrake off and in gear!
Guest Swagman
Or maybe just a normal day for a bus driver. :D
It was driver less :mrgreen:
Like I said normal. :thumb: :D
Its the new normal at the minute! we have around 80 buses just parked up at our depot!!
Guest Swagman
Ooh good I’ll get the bike out it’s gonna be safer on the roads. :D :D :D
Its not good :crybaby: jobs are at risk :shock:
[mention]Stu[/mention] I was thinking it might get busier now as they'll need to run more buses than normal as they cant put as many people on board :?
@Stu I was thinking it might get busier now as they'll need to run more buses than normal as they cant put as many people on board :?
It may get busier and more buses but we will be at less than 25% capacity :shock:
Guest Swagman
Yes more buses but cost to run them will be tripled because the more buses the more fuel and drivers, bus companies simply cannot afford that. :crybaby:
Posted (edited)
I nearly had my head removed by an air actuator, was driving past a wagon with trailer and suddenly a huge bang, it took out my side window and shot a cross the dash, half of the actuator drum had made it into my van, was lucky it missed me, I can confirm the wagon did come to a stop.
Edited by Bender
Guest Swagman
Posted (edited)
Thank fook it missed you. :thumb:
Edited by Swagman
is it not air in the tanks that keep the brakes off
Yeah that's right the air pressure releases the brakes and if you lose air then the brakes lock on
The flexi air coils that connect trailers are called suzies, named after the bloke that invented them.
Today's useless fact.
Jeeezzzzeeee. :shock:
Glad you are ok.
you wont be wearing them pants again.
Guest Swagman
They’re full of iron filings. :D :D
