If anyone ever doubted how important the little circlips Kawasaki use on their rear spindle fastenings were look what happens when one pings off and you are unaware.
Felt just like a blow out then much wobbling stopped and reattached spindle and nut then rode home like miss Daisy lol.
Cheers
Ian
Guest Richzx6r
Oops, looks and sounds like squeaking bum time was had
You are right guys very hairy and I was still a tad shaky when I got home.
Spindle now retorqued to 90Nm waiting for 3 little bits of wire ( part no. 92033) from Mr Cradley Kawasaki 1 as replacement 2 to go under seat lol.
Mind you £3.73 each just added insult to injury lol.
You should have seen the reaction of the guy I was overtaking at the time lol.
I didnt know you could stoppie a BMW K series with full luggage at over 80mph lol.
Cheers
Ian
Guest Richzx6r
Cheers
Ian
Well mate we are just happy nothing bad came of it! 10 quid spent isn't much to be safe
Cheers
Ian
I totally agree and while she was on the bench I scraped and cleaned those recesses that the clips sit in and would advise everyone else who has this system to do the same.
The chain side which was the side in the pic I believe the residue of chain lube hadn't helped so this is now very clean.
At least it proves I haven`t neglected chain oiling lol.
Cheers
Ian
:shock:
Was the spindle torqued up before? I shall be double-checking the clips in mine tomorrow.
Oh yes 98Nm per the book.
Vibration is a wonderful loosener lol.
Now torqued again waiting for postie.
Cheers
Ian
:shock:
Cheers
Ian
A lot of people think that vibration loosening is not a thing!
Thanks [mention]Stu[/mention] that is really interesting !
Petrifying but interesting.
Cheers
Ian
close one, could of ended bad.
stupid Kawasaki
stupid Kawasaki
If you had been following I am sure you would have had a giggle as the back end went all wibble and I was trying to gently scrub off speed mindful that wobble could get worse as I slowed down.
acceleration wasn't an option lol.
Cheers
Ian
Thats interesting new clips from Cradley just arrived.
Very different to the originals! Hmm has someone worked out there is a problem with the old anodized wire clip?
20200519_173646.thumb.jpg.0f4ada2700c755a4bf7af9f43aa46180.jpg20200519_174122.thumb.jpg.610922c2237d8f3fbafaa6d0b0ad11b9.jpg
Nope lol.
New clips totally wrong size and thickness :P
Fook sake back they go.
Cheers
Ian
Guest Swagman
Second pic old beside new and yes same part number.
Cheers Ian
New looks far superior to original. :thumb:
I agree with you and if it was the right diameter I would have used them.
I will be phoning Cradley in the morning.
Cheers
Ian
Oh well now the plot coagulates I am afraid.
Checked bearings for damage after finding the rear wheel stiff to rotate when torqued up and found disc side notchy so new ordered.
Decided to fit old standard wheel as bearings known to be okay.
Once torqued in place also too stiff to rotate even with caliper removed.
Now getting concerned about swing arm itself
As the wheel turns freely at 75Nm once increased beyond 80Nm starts to stiffen and by 90Nm cant really be turned by one hand.
Now looking for dimensions of swingarm to try and establish if the thing is straight.
I am now in the market for suggestions lol as the wheel has been in and out several times and all spacers, washer etc have been checked and re checked.
Cheers
Ian
Maybe one of the adjusters is slightly warped?
My first thought was that maybe the axle wasn't straight any more but it must be or you'd never get it through the wheel, hmmm!
Guest Richzx6r
I'd guess that next you should check the run out of the axle just incase its slightly out of true, the swingarm could have bent slightly but it would probably be quite unlikely to bend the next guess will probably be an adjuster that is slightly binding on the axle or something
The swing arm is a very strong unit when subjected to stresses it is designed to take but notoriously weak in other directions.
I am lucky that a member of the ZRX owners forum has offered me a known straight swinger to try (not that kind lol).
So this afternoon saw a bit of activity in the garage !
Pics to follow.
Cheers
Ian
20200525_150238.thumb.jpg.fc7c442bdcdd97bfd7aa1a481dc05d0b.jpg20200525_150243.thumb.jpg.0cdf2f7b972ff0f1c284f3c2bc89a6cd.jpgIMG-20200525-WA0011.thumb.jpg.d58e2a1c6a1432c6fbd069eadee2ef71.jpg
Last pic is the kind offer from Al in the ZRX club.
So a detour on the way home from work tomorrow and I guess a couple of evenings in the garage to come.
Cheers
Ian
