Shepherd Posted November 19, 2020 Posted November 19, 2020 (edited) I can't seem to add to my previous 'NT700 brake discs' post, so I'll have to ask on this new thread/stream/activity, or whatever it's called today ... I'm being quoted £77 each for brake discs ( I need two), which is more than I can run to this side of payday. Does anyone know of an alternative to Wemoto that they can recommend? I've tried cmnsl, Fowlers and Sportsbike shop who were all dearer. Edited November 19, 2020 by Shepherd Stupid spelling Quote
husoi Posted November 19, 2020 Posted November 19, 2020 follow the link for sportbikeshop https://www.sportsbikeshop.co.uk/#/27907,3203,1186 the best is a www.duckduck.com search for your bike 1 Quote
Tiggie Posted November 19, 2020 Posted November 19, 2020 Have you tried eBay? A lot of parts shops run their online business on there 1 Quote
husoi Posted November 19, 2020 Posted November 19, 2020 1 minute ago, Tiggie said: Have you tried eBay? A lot of parts shops run their online business on there True but the link in the forum helps @Stu with forum costs 1 Quote
Shepherd Posted November 19, 2020 Author Posted November 19, 2020 Thanks husoi, I did try them - not the keenest of prices Ebay scares the life out of me, always worried I'll buy the wrong stuff. Looks like I will have to bite the bullet Quote
Tiggie Posted November 19, 2020 Posted November 19, 2020 @husoi He had already mentioned he'd tried them which is why I didn't mention it Quote
TimR Posted November 19, 2020 Posted November 19, 2020 (edited) Go to fowlers website and using the part finder Select your model etc And this will give you a reference to what other vehicles use that part. For reference : ( may not be your year https://www.fowlersparts.co.uk/parts/view/45251MERD01 Or cmsnl.com again handy reference Sometimes other models may be clearing out . Put the part number in Ebay search or even Google Edited November 19, 2020 by TimR 3 Quote
JRH Posted November 19, 2020 Posted November 19, 2020 (edited) @Shepherd sorry to say but that isn’t too bad a price. Edited November 19, 2020 by JRH 1 Quote
WD-40 Posted November 19, 2020 Posted November 19, 2020 2 minutes ago, JRH said: @Shepherd sorry to say but that isn’t too bad a price. Yeah front break discs are expensive. Sometimes you can get lucky and find a good used set. 1 Quote
Shepherd Posted November 19, 2020 Author Posted November 19, 2020 Thanks for the replies, I bit the bullet once I was sure I wasn't being ripped off. I don't mind paying what I need to, as long as I don't see the same thing at half the price afterwards. Quote
Shepherd Posted November 19, 2020 Author Posted November 19, 2020 I was advised on my previous post, that it made sense to change the brake fluid too, but I've also been told it's a nightmare to bleed these due to the linked system. Anyone have any experience doing this on a Deauville? Your answers are appreciated, many thanks. Quote
husoi Posted November 20, 2020 Posted November 20, 2020 I did the fluid change on my ST1300 and the system is similar (maybe a bit more complicated on the ST. The nightmare is when you empty the system completely and then try to refill. you won't be able to remove the air without a vacuum pump. The process I use is to remove enough brake fluid (BF) from the reservoir without emptying it. Then I fill the reservoir with methylated alcohol (you can get it from toolstation) and pump the fluid until the alcohol starts running clean from the calipers. After this you repeat the process with new BF until it runs clean from the calipers. This way you will never have air in the system The alcohol cleans the system but doesn't damage the pipework and it will only be there for no more than 30 min. 1 Quote
Shepherd Posted November 20, 2020 Author Posted November 20, 2020 Great post husoi, thank you I don't mind trying things, as long as I have simple instructions, and the above sounds simple enough. I'll have someone alongside me to keep an eye on the levels. I'll soon post again if I cock it up! Quote
WD-40 Posted November 20, 2020 Posted November 20, 2020 The only thing that should go into a brake system is the specified brake fluid. Download the workshop manual and follow the procedure in that. Quote
Ian Frog Posted November 20, 2020 Posted November 20, 2020 10 hours ago, husoi said: I did the fluid change on my ST1300 and the system is similar (maybe a bit more complicated on the ST. The nightmare is when you empty the system completely and then try to refill. you won't be able to remove the air without a vacuum pump. The process I use is to remove enough brake fluid (BF) from the reservoir without emptying it. Then I fill the reservoir with methylated alcohol (you can get it from toolstation) and pump the fluid until the alcohol starts running clean from the calipers. After this you repeat the process with new BF until it runs clean from the calipers. This way you will never have air in the system The alcohol cleans the system but doesn't damage the pipework and it will only be there for no more than 30 min. Hi @husoi This sounds a great idea in principle to keep air from entering the system. Did you get it from someone with experience in dealing with hydraulic systems? I can see the logic but believe it is questionable to introduce a fluid not specified for the braking system. I am open minded as I said before the principle sounds sensible. Cheers Ian Quote
husoi Posted November 21, 2020 Posted November 21, 2020 17 hours ago, Ian Frog said: Hi @husoi This sounds a great idea in principle to keep air from entering the system. Did you get it from someone with experience in dealing with hydraulic systems? I can see the logic but believe it is questionable to introduce a fluid not specified for the braking system. I am open minded as I said before the principle sounds sensible. Cheers Ian Hi Ian, I use methylated alcohol (MA) because it is inert to metal and plastic in the hoses and have cleaning properties. Usually, when running it in the brake system I will action the brakes a few times to move the pistons and help cleaning. The use is not intended to have any hydraulic capacity. If was to be used as such the water content will become a problem so it must be ensured that is not subject to high pressure as it would occur in a closed system. But this is not a problem is used only to flush the system. The only caution needed is to make sure clear brake fluid is running through the purge valve replacing the MA, because the alcohol is purple it is easy to spot. and that the operation is done without interruption. Having said that if the MA is left for a couple hours "soaking" the system this poses no issues. I've done it on all my bikes, mostly because all of them are Honda with CBS, I have used it also in my cars and never had any problems. I service my calipers every 2 or 3 years depending on mileage and never found any sign that MA would be an issue. I know people usually just push new fluid on used and make a direct replacement but my opinion is that brake fluid have no cleaning capacity and the direct replacement doesn't remove the surface coating the used fluid will deposit throughout the years. Quote
Ian Frog Posted November 21, 2020 Posted November 21, 2020 Your logic seems sound to me. I find it a little suprising that noone has badged it differently and sold it as a flushing fluid at greater expense lol. Cheers Ian Quote
WD-40 Posted November 21, 2020 Posted November 21, 2020 Do any manufactures of bikes, cars, brake systems or brake fluid recommend flushing with alcohol? Any workshop manuals that show it being done? If you take your bike, car, truck etc to a proper mechanic do they flush with alcohol or anything other than brake fluid? Are they all doing it wrong? Quote
TimR Posted November 21, 2020 Posted November 21, 2020 (edited) 58 minutes ago, WD-40 said: Do any manufactures of bikes, cars, brake systems or brake fluid recommend flushing with alcohol? Any workshop manuals that show it being done? If you take your bike, car, truck etc to a proper mechanic do they flush with alcohol or anything other than brake fluid? Are they all doing it wrong? Used to be used on all metal piped systems but think the advent of rubber based hoses and synthetic based seals etc it became less and less wether this is due to it reacting with these am unsure You could consider non aerosol based brake and clutch cleaner (used on pipes to clean internals etc but not as a full system flush) Or just flush through with brake and clutch fluid Edited November 21, 2020 by TimR 1 Quote
