James in Brum Posted March 17, 2021 Posted March 17, 2021 It seems ages since I posted here asking advice about my bike. the right grip (my grips are heated) seems to slip round. It is not totally loose and I can accelerate but the grip moves round meaning that the cable for the heating limits the amount of rotation. I can turn it back and reset it but it keeps happening. how do I resolve this? Has the glue degenerated? Was it glue? They were fitted before I got the bike. Quote
fastbob Posted March 17, 2021 Posted March 17, 2021 I think you've answered your own question . Quote
James in Brum Posted March 17, 2021 Author Posted March 17, 2021 As in glue degenerated? How do I mend it? Just new glue? Quote
Mississippi Bullfrog Posted March 17, 2021 Posted March 17, 2021 Hey, look on it as free traction control. As above, sounds like the glue has failed. If it's loose you ought to be able to get the grip off and replace the glue. Quote
fastbob Posted March 17, 2021 Posted March 17, 2021 https://www.ebay.co.uk/itm/R-G-Heated-Grip-Glue-Designed-for-use-with-R-G-Heated-Grips-/312802721975?_trksid=p2349624.m46890.l49292 Quote
fullscreenaging Posted March 17, 2021 Posted March 17, 2021 I’ve heard hairspray will do the job. 1 Quote
Stu Posted March 18, 2021 Posted March 18, 2021 I have tried super glue before but I find it sets too quickly and eventually it gives! If you get the grip wrong and it sets you're screwed I have used the spray on contact adhesive for the current grips and it's been spot on Leaves enough time to get them in place before setting I heard hair spray too and tried that but it was a no go for me! 1 Quote
jedibiker Posted March 19, 2021 Posted March 19, 2021 I installed them on both bikes last year and a quick way to get off is with an air line, then all I did was put a little black tape under so it was snug. Not moved at all. Keep hearing how glue fails. (r&g mostly) 1 Quote
James in Brum Posted March 19, 2021 Author Posted March 19, 2021 Thanks. Will try to find time this weekend but most likely next weekend now. Quote
fastbob Posted March 19, 2021 Posted March 19, 2021 51 minutes ago, James in Brum said: Thanks. Will try to find time this weekend but most likely next weekend now. Off Road World in Coleshill will have Grip Glue . Quote
