BonkersAtHeart Posted December 20, 2023 Share Posted December 20, 2023 diagram is confusing. chain slack should be 55-60mm do I only take the measurement with chain pushed down not up or both measurements down and up Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted December 20, 2023 Share Posted December 20, 2023 (edited) Normally Primary down but you can just check the upper afterwards incase it catches on the swingarm. but as the diagram says its a total upper and lower movement of 55-60mm, place a ruler underneath the swing arm, middle length down the S A. Gently pull and raise as far as it will naturally go and take the measurements from there. example 1: of 20mm raise while lower of 40mm equals 60mm will be on the limit. example 2: of 30mm raise while 50mm Lower equals 80mm will to too slack.. is that clearer? Edited December 20, 2023 by RideWithStyles Quote Link to comment Share on other sites More sharing options...
BonkersAtHeart Posted December 20, 2023 Author Share Posted December 20, 2023 26 minutes ago, RideWithStyles said: Normally Primary down but you can just check the upper afterwards incase it catches on the swingarm. but as the diagram says its a total upper and lower movement of 55-60mm, place a ruler underneath the swing arm, middle length down the S A. Gently pull and raise as far as it will naturally go and take the measurements from there. example 1: of 20mm raise while lower of 40mm equals 60mm will be on the limit. example 2: of 30mm raise while 50mm Lower equals 80mm will to too slack.. is that clearer? so I just add the upper and lower number. Together for the whole number value and don’t subtract anything ? 27mm raise 53mm lower is 80mm ? as a whole but feels tight as anything. Quote Link to comment Share on other sites More sharing options...
Nick the wanderer Posted December 20, 2023 Share Posted December 20, 2023 Hi, yes, if you have 80mm worth of slack and the manufacturer recommends 55-60mm you will only need to tighten it very slightly. If you think it is tight enough then run with it as is. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted December 21, 2023 Share Posted December 21, 2023 I just use one measurement. Push the chain up as far as it will go, then down, measure the distance and that's it. Holding a ruler can be tricky so I make a ply measure with the limit drawn on it. It's easier to hold that on the swingarm than a ruler. Also, don't just take one measurement. Chains don't wear evenly so you will have tight spots and loose spots. It you set it on a loose spot then the chain will be too tight. 1 Quote Link to comment Share on other sites More sharing options...
onesea Posted December 21, 2023 Share Posted December 21, 2023 You are talking VERY fine adjustments on the rear axle, 1/4 turn can make a difference. My suggestion is in time you learn to feel when the chain is to loose. A snatchines when chaining gears is my warning it’s subtle. It doesn’t take long before your lifting it with your foot and saying yup or nay. 1 Quote Link to comment Share on other sites More sharing options...
