spacemonkey Posted May 5, 2014 Share Posted May 5, 2014 Got a Keeway partner 110 (don't laugh, I got it for nothing lol) and need to adjust the chain.The adjusters have just rotted to bits so I need to change them, problem is I cant see how you take off the carrier off the frame.Took the wheel off ok and see the carrier is held on with a sleeve that the axle goes through. I think I may need to pull or bash the carrier off but I just want to check first before I start smacking the crap out of it.Never worked on motorbikes before (if you can even call it one) but handy with spanners on cars so no stranger of getting stuck in but this has me pi**ed right off.Can anyone help?? Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted May 5, 2014 Share Posted May 5, 2014 Just to avoid any confusion, the sprocket carrier is the bit in the hub of the rear wheel that the sprocket bolts to, it will just pull out of the rear wheel and under it are the cush drive rubbers.Chain adjusters are usually screwed somehow into the rear of the swingarm and will probably want to be unscrewed, I think some types may rely on just screwing into a bracket which sits on the end of the swingarm, but most will need to be unscrewed as if tightening the chain, then keep going till it frees completely. I wouldn't start bashing stuff till you can see how it is fixed. Quote Link to comment Share on other sites More sharing options...
spacemonkey Posted May 5, 2014 Author Share Posted May 5, 2014 The adjusting nut at the end snapped off as soon as I put a spanner on it as it was that rusty, I think a Honda C90 one will do though. The adjusters are just like washers with bolts coming off them and they hook on to the end of the swingarm, Just cheap nasty things that resemble to ones I had on a BMX as a kid. When I try to remove the sleeve's big nut that has the adjuster under it the whole lot just spins around including the sprocket and carrier. I cant see anywhere to put another spanner or even put a allen key in.Sorry if im not being too clear, never was the best at describing things through text. Quote Link to comment Share on other sites More sharing options...
Tango Posted May 5, 2014 Share Posted May 5, 2014 Take some pics and post them.....may make things easier to describe...... Quote Link to comment Share on other sites More sharing options...
spacemonkey Posted May 5, 2014 Author Share Posted May 5, 2014 The nut in questionhttp://i35.photobucket.com/albums/d181/no1spacemonkey/7FB56D61-0EE1-4D8F-B296-B811485FCE72.jpg View from behind the bikehttp://i35.photobucket.com/albums/d181/no1spacemonkey/D6FDDB26-A9E4-474B-BB60-72F245AF7A58.jpgView from inside the carrierhttp://i35.photobucket.com/albums/d181/no1spacemonkey/F13A2EFF-E405-4F65-BAA8-3E5189D416C9.jpg Quote Link to comment Share on other sites More sharing options...
littlecat Posted May 5, 2014 Share Posted May 5, 2014 holy c***!!cant be any help, but if theres anything else on the bike looking like that, free or not, I'd be melting it down, not trying to ride it Quote Link to comment Share on other sites More sharing options...
Tango Posted May 5, 2014 Share Posted May 5, 2014 To undo that nut you may need to put the rear wheel back in and use the brake to stop it turning while you loosen that nut......or put the chain back on and stuff some rags where the chain meets the sprocket to try to stop the thing turning while you slacken the nut...... Quote Link to comment Share on other sites More sharing options...
spacemonkey Posted May 5, 2014 Author Share Posted May 5, 2014 To undo that nut you may need to put the rear wheel back in and use the brake to stop it turning while you loosen that nut......or put the chain back on and stuff some rags where the chain meets the sprocket to try to stop the thing turning while you slacken the nut...... That wont work though. The carrier turns on the sleeve and the sleeve just turns when I try to remove nut. In an ideal world it needs to have somewhere I can put a spanner on between the carrier and swingarm and a socket on the big nut.As for the rust, it not as bad as it looks. That's one of the reasons im taking it apart is to give it a good clean and paint. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted May 5, 2014 Share Posted May 5, 2014 As an idea... Can you get a good size bolt through the middle of the sleve and get a nut on nice and tight (might need some big old washers) - then stick a secondary nut on as a locknut and use a spanner on that to stop the sleve spinning while you crack off the main nut? (other way round might work better...)Apologies for the poor explaination and repeated use of the word "nut". Quote Link to comment Share on other sites More sharing options...
Stu Posted May 5, 2014 Share Posted May 5, 2014 and impact gun may work Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted May 5, 2014 Share Posted May 5, 2014 That photo has confused me, the back wheel is off, but not the sprocket carrier? (the sprocket). Did that not come off with the wheel? Quote Link to comment Share on other sites More sharing options...
Tango Posted May 5, 2014 Share Posted May 5, 2014 When I try to remove the sleeve's big nut that has the adjuster under it the whole lot just spins around including the sprocket and carrier. The sprocket must attach to the rear wheel.....so, if you put the wheel back in and put the back brake on you must be able to loosen the nut.....unless I'm misreading what you said about the whole lot turning?..... @Matty....the sprocket and carrier and rear disk all stay in place when I remove the rear wheel on my Speedie......single sided swinging arm..... Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted May 5, 2014 Share Posted May 5, 2014 holy c***!!cant be any help, but if theres anything else on the bike looking like that, free or not, I'd be melting it down, not trying to ride it Really? Wow. It's only a bit of surface rust on a swingarm and chain lube on a sprocket? Quote Link to comment Share on other sites More sharing options...
mattycoops43 Posted May 5, 2014 Share Posted May 5, 2014 [quote="Tango" @Matty....the sprocket and carrier and rear disk all stay in place when I remove the rear wheel on my Speedie......single sided swinging arm..... LOL. That AIN'T no SSSA Bob! It's bloomin spindly and thin if it is! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted May 6, 2014 Share Posted May 6, 2014 old suzukis used to be set up this wayyou need to refit rear wheel tighten spindle upso that the spacer in the carrier is pinched onto bearing it runs on then loosen the nut off before undoing wheel again Quote Link to comment Share on other sites More sharing options...
megawatt Posted May 6, 2014 Share Posted May 6, 2014 I could easy fix that for you. :.......:.with a match. Quote Link to comment Share on other sites More sharing options...
spacemonkey Posted May 6, 2014 Author Share Posted May 6, 2014 All sorted and without the need of a match!Put the wheel back on and bolted up the axle good and tight, 24mm socket on sleeve nut and managed to get a couple of turns on the nut that was enough to get it off when I removed the wheel again.Thanks all for the helpful and not so helpful comments. Quote Link to comment Share on other sites More sharing options...
