tmetcalfe09 Posted November 1, 2016 Share Posted November 1, 2016 I'm really not a mechanic so please go easy on me!I own a kawasaki gt550 and the other day as I was riding home, the bike all of the sudden started to run on only two cylinders.The coils on my bike run to cylinders 1/4 and 2/3, It is cylinders 2/3 that stopped firing.I wasn't getting a spark from either plugs 2/3, but when i swapped the wiring of the coils over, I got a spark, so there's no problem with the coils.I then tested the wires that lead from the cdi unit to the coils, and all wires are fine.Therefore I figured the only thing it could be is the cdi unit.I ordered a new one and plugged it in and it started, all exhaust pipes got hot and I sighed with relief!During the time it took me to attach the cdi unit to the bike, it has returned to only firing on 2 cylinders again!!!!!!!If there is any advice you can give me, if someone has experienced something like this before? I would really appreciate it!!Thank you, Tim Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 1, 2016 Share Posted November 1, 2016 it could well be the pick ups round the crankshaft down in the left hand casing one might be breaking down as it gets hot......oh and welcome to the forum please pop into newbies and introduce yourself if you plan to stay around as we are a friendly helpfull bunch........................most of the time...............(keep quiet six ) Quote Link to comment Share on other sites More sharing options...
mas101 Posted November 2, 2016 Share Posted November 2, 2016 Could still be the coils - as said, stuff fails when hot - swap the coils around and see if the problem moves. Quote Link to comment Share on other sites More sharing options...
RantMachine Posted November 2, 2016 Share Posted November 2, 2016 I had a panic this morning, my bike was only running on 1 cylinder! But then I woke up a bit and realised everything was fine Quote Link to comment Share on other sites More sharing options...
thebiglad Posted November 2, 2016 Share Posted November 2, 2016 The coils on my bike run to cylinders 1/4 and 2/3, It is cylinders 2/3 that stopped firing.I wasn't getting a spark from either plugs 2/3, but when i swapped the wiring of the coils over, I got a spark, so there's no problem with the coils.I then tested the wires that lead from the cdi unit to the coils, and all wires are fine.Therefore I figured the only thing it could be is the cdi unit.Thank you, Tim Hi Tim, if you're saying that when you swapped the coils over, you starting getting a spark on plugs 2/3, then I would suggest that you have just proved that the fault lies with one of the coils.When you swapped them over, did you verify that you were still getting a spark on plugs 1/4 ? If you didn't, it might be a good time to try ?????? Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 2, 2016 Author Share Posted November 2, 2016 Ok, so the bike is only running on one cylinder now.I have taken the casing off on the RIGHT hand side where the timing pickups are.Using a multimeter I scratched the surface of the pickup, then placed the other end against the 4 terminals inside the junction box which is located under gt550 fairing.I got no continuity off any of the wires that lead from the terminals to the pickups.I then punctured the wire that runs in to the pickups, and got continuity off all four wires. Am I doing something wrong? Or does this then mean I've solved it and my pickups are shot?Thank you, Tim Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 2, 2016 Author Share Posted November 2, 2016 Hi Tim, if you're saying that when you swapped the coils over, you starting getting a spark on plugs 2/3, then I would suggest that you have just proved that the fault lies with one of the coils.When you swapped them over, did you verify that you were still getting a spark on plugs 1/4 ? If you didn't, it might be a good time to try ?????? thebiglad, I figured once I'd swapped the wires from the working 1/4 coil into the 2/3 coil, and got a spark, that would mean there is nothing wrong with the coil?.. Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 2, 2016 Author Share Posted November 2, 2016 I don't think there's suppose to be continuity from the pickup to the terminal is there?I've just watched a couple of youtube videos and have instead used the multimeter against two of the terminals inside the junction box and got a reading of 0.54 ohms for both.Does this then mean the pickups are fine? Quote Link to comment Share on other sites More sharing options...
Tango Posted November 2, 2016 Share Posted November 2, 2016 Are you sure it's not carb problems?......not dragged a load of sh*t from the tank into the carbs? Quote Link to comment Share on other sites More sharing options...
TimR Posted November 2, 2016 Share Posted November 2, 2016 Kawasaki ....Had similar on my gpz500 mTurned out to be the Sidestand switch partially closed trying to fool the bike that stand was down when it wasnt Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 3, 2016 Author Share Posted November 3, 2016 Kawasaki ....Had similar on my gpz500 mTurned out to be the Sidestand switch partially closed trying to fool the bike that stand was down when it wasnt and that let only out of three cylinders fire? Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted November 4, 2016 Share Posted November 4, 2016 What year is your bike? Quote Link to comment Share on other sites More sharing options...
TimR Posted November 4, 2016 Share Posted November 4, 2016 Kawasaki ....Had similar on my gpz500 mTurned out to be the Sidestand switch partially closed trying to fool the bike that stand was down when it wasnt and that let only out of three cylinders fire?Bike was running along fine and about a mile away from leaving it started coughing sputtering as if out of petrol ...and misfiring .. stopped .. investigated bike ran fine stood there .. ok set off again . Started doing it again within minutes .. stopped .. again running fine . As soon as i lifted the stand it started burbling . The plunger was hovering in that position trying to cut the engine but not enough contact to close fully. Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 6, 2016 Author Share Posted November 6, 2016 What year is your bike?It's a 1989 model. still cannot work out what' wrong with it. As i said it's now only running on one cylinder. I've tested the pickups with a multimeter and got 0.54ohm on both. Quote Link to comment Share on other sites More sharing options...
Tango Posted November 6, 2016 Share Posted November 6, 2016 Have you got a spark on the dead cylinders? I still think it sounds like carbs..... Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 7, 2016 Author Share Posted November 7, 2016 Have you got a spark on the dead cylinders? I still think it sounds like carbs..... So i didn't have a spark on the plugs that lead from coil 2/3, however when I swapped the wires from the (working) 1/4 coil to the (not working) 2/3 coil, I got a spark. Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 7, 2016 Author Share Posted November 7, 2016 If it was the carbs, what would I be checking? I had the tops off and they are clean and dust free. Look fine! Quote Link to comment Share on other sites More sharing options...
tmetcalfe09 Posted November 7, 2016 Author Share Posted November 7, 2016 Not firing at all now. 4 cylinders, to 2, to 1, to none!! So confused. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 7, 2016 Share Posted November 7, 2016 i would be looking at wiring connections around the cdi unit and at that itself Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted November 7, 2016 Share Posted November 7, 2016 I know you had the tops off the carbs but have you looked in the bowls?They're easy enough to drain in situ with a bit of plastic tube and a long screwdriver/hex key (whichever you have). Collect the fuel from the bowls in a jar or something - if there are any bit of crud in there then you'll need to take the carbs off and clean them out. Probably stick a filer in the fuel line too. Quote Link to comment Share on other sites More sharing options...
ThePhatomfart Posted November 10, 2016 Share Posted November 10, 2016 Hi does your bike have the 6 pin Diode Pack, if so have you tested it Quote Link to comment Share on other sites More sharing options...
Tango Posted November 10, 2016 Share Posted November 10, 2016 I know you had the tops off the carbs but have you looked in the bowls?They're easy enough to drain in situ with a bit of plastic tube and a long screwdriver/hex key (whichever you have). Collect the fuel from the bowls in a jar or something - if there are any bit of crud in there then you'll need to take the carbs off and clean them out. Probably stick a filer in the fuel line too. Also check that there's actually fuel in the float bowls and it's not water...... Quote Link to comment Share on other sites More sharing options...
Kninjajr Posted June 6, 2018 Share Posted June 6, 2018 How can I check if i have spark? It seems fine and when I pull them out they have no signs of bad wear Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 6, 2018 Share Posted June 6, 2018 The coils on my bike run to cylinders 1/4 and 2/3, It is cylinders 2/3 that stopped firing.I wasn't getting a spark from either plugs 2/3, but when i swapped the wiring of the coils over, I got a spark, so there's no problem with the coils.I then tested the wires that lead from the cdi unit to the coils, and all wires are fine.Therefore I figured the only thing it could be is the cdi unit.Thank you, Tim Hi Tim, if you're saying that when you swapped the coils over, you starting getting a spark on plugs 2/3, then I would suggest that you have just proved that the fault lies with one of the coils.When you swapped them over, did you verify that you were still getting a spark on plugs 1/4 ? If you didn't, it might be a good time to try ??????Yeah, that's how I read it as well , surely this proves that it IS the coil ? Also when a coil fails it can appear to be ok again when it is cold and fail again as soon as the engine heats up . Quote Link to comment Share on other sites More sharing options...
