Hi all, so, trying to replace the rear pads today and the goddam caliper pin is stuck solid.
Can't twist it with pliers, can't tap it using a small Phillips head screwdriver
I've soaked it with WD40 but no luck
Any advice for a noob?
decent tools would help ...
try a pair of vice grips/mole grips
and a pin punch .
could be the long game of soak with wd or similar and tap and soak
but remember to clean all surfaces of said wd before riding.
check that your tapping the right direction
and that its designed to tap out .
applying heat you run the risk of burning the seals and boiling brake fluid unless you have a small flamed blowtorch but even then you run a risk .
Thanks Tim
Success!
Today I have learned that tapping out seized pins does not work. Absolutely smashing them out with a flattened off Phillips and a great big hammer does :thumb:
The bad news is that after replacing the pads I discovered the cap for the rear brake fluid reservoir has gone missing :|
Heat and penetrating oil as suggested.
Use a hot air gun on a lowish setting or a hairdryer.
I don't know the details or design of the caliper but googling would suggest a Brembo with a pin and r clip?
Can you get to the back of the pin and drive out with a pin punch?
Try tapping it the other way aswell just to loosen it off.
Try tapping the grips with a hammer to move it.
Just posted this then read you had sorted it :thumb:
Motorworks is your friend for all parts BMW. Missing or otherwise.
Or motobins :D
Would one of the these actually work out cheaper ?
I wonder if the top off a jar of Marmite would fit . 😃
Same cost as OEM bottle from Motorworks
Ok , I bet they don't offer a choice of colours though . 😉
well you would either love it or hate it :lol:
