Posted (edited)
swing arm bearing/adjustment tool... do i get a prize.
Edited by Six30
Guest Swagman
Chain Adjuster tool for all bevel drive ducatis :D
As Stu says :thumb:
swingarm adjustmenthttps://www.ebay.co.uk/itm/Ducati-Bevel-900SD-Darmah-Eccentric-Swingarm-Chain-Adjuster-Tool-860-900-GTS/303372186455?hash=item46a2643357:g:5wQAAOxyhXRTPI1t tool
Well done sir !!!
ermm... i said that first... and i say again , do i get a prize .
You threw me off with the cam chain! I just picked up on the cam part and not the actual chain :lol:
There you go!
Cheers
Ian
@Six30
:lol: :lol: :lol: cheater
I did add adjuster ...but still a clear winner :D
There you go!
Cheers
Ian
Thanks Ian , give stu one as well before he throws his toys around the garden .
There you go!
Cheers
Ian
sod that its cold here! I aren't going outside :lol:
There you go!
Cheers
Ian
Its nice here I might go back in the garage as Amazon have just delivered cleaning brushes I ordered !
On the down side no sign of my new brake lines for the ZRX yet !
Cheers
Ian
Looks like the tool used to remove the wheel bearings.
You will need a chisel to go on the opening, that press the sides against the inner ring of the bearing and then you can pull it out.
I tried to make one but never worked. Last time I replaced the bearings I just welded a steel rod inside the bearing and whacked it out :D
I was just pleasantly pleased to see they are still available and maybe one day I will get to use my one again.
However I suspect a lottery win will be required for me to go back to bevel drive Ducati`s lol.
Cheers
Ian
