Mickly Posted November 8, 2020 Posted November 8, 2020 Right here goes, I will attempt to document the strip down & diagnosis, believe me, it won’t be as quick as Fastbob’s sterling ER5 job.The reason I’m doing this is that the Trophy went to a local workshop to have the fuelling sorted as it’s got after market pipes & foam pods instead of an air box.However it was diagnosed with a slipping clutch, oil leak ( only under load) & 59BHP - mainly due to the clutch slip.I then got them to do a compression test & this was the result: While the leak down test results weren’t too bad, the compression should be around 150psi, also there was only a small uplift between dry & wet tests. Armed with this information I’m going to have a look inside the engine & see what’s going on. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 So here is the bike in a dingy but relatively dry Coventry garage. And armed with the Haynes Manual as a guide I will commence. According to the manual could do this without removing the engine but having spilt petrol over it It needs repainting, so out it will come & onto the bench.Which will require a little tidying first. Quote
Guest Swagman Posted November 8, 2020 Posted November 8, 2020 Good luck with it, new rings and valve grind maybe Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Seat unit off ( bubble wrapped & stored with its fixings taped to it) & -ve battery connection undone. Quote
fastbob Posted November 8, 2020 Posted November 8, 2020 So what's the actual plan ? 0.5 over sized pistons and a professional rebore or maybe just new rings and a hone ? I've got a valve spring compressor and a honing tool if you want to borrow them . They're just Machine Mart stuff but they do the job . Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 So what's the actual plan ? 0.5 over sized pistons and a professional rebore or maybe just new rings and a hone ? I've got a valve spring compressor and a honing tool if you want to borrow them . They're just Machine Mart stuff but they do the job . Thanks for the offer I may well have to take you up on that.Not sure until I get into it .... mate of mine has pointed out that I might be able to fit Triumph 955 pistons and liners and take it to 1275cc .... bloody git, now he’s planted that seed I might have to give it proper consideration.Hopefully it’s just a hone & new rings, but as you know, it could be a whole different ball game. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Air filter pods off so I can get to the fuel tap / fuel hose clamp.That green box has had a good wash out as it will house the carbs when they come off. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Fuel hose off - bit of wooden dowel with tape round it shoved in the end to stop any MORE fuel spilling out - doh !!At least I had some rags down to catch it this time!! Quote
fastbob Posted November 8, 2020 Posted November 8, 2020 So what's the actual plan ? 0.5 over sized pistons and a professional rebore or maybe just new rings and a hone ? I've got a valve spring compressor and a honing tool if you want to borrow them . They're just Machine Mart stuff but they do the job . Thanks for the offer I may well have to take you up on that.Not sure until I get into it .... mate of mine has pointed out that I might be able to fit Triumph 955 pistons and liners and take it to 1275cc .... bloody git, now he’s planted that seed I might have to give it proper consideration.Hopefully it’s just a hone & new rings, but as you know, it could be a whole different ball game. You can have my knackered ER5 barrells to practice your cross hatching on . Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Tank off, fixings bagged & taped to it.Wrapped in an old clean sheet & into the cardboard box it came in. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Engine oil filler cap removed to allow sump to vent. Oil drain plug Oil ... I added new oil and it certainly didn’t go in that colour !! Can’t see evidence of water ingress & it’s not milky, more burnt, probably caused by the over heating due to lean fuelling. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Radiator cap removed to allow cooling system to ventCoolant is now over flowing from the rad neck Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Coolant drain plug undone - the coolant looks in good nick. Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Lowest point of the cooling system ( looks nothing like the pic in the Haynes manual. Needs this bracket undoing from the block to separate the hose.Again not in the Haynes !! Quote
fastbob Posted November 8, 2020 Posted November 8, 2020 Haynes Manuals are hit and miss . The ER5 one is excellent but my Sportster one is incomprehensible shite . Quote
onesea Posted November 8, 2020 Posted November 8, 2020 As a fellow trophy owner following with interest. You know there is a FB trophy group full of wisdom...Do you mind if I share this post there? Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 As a fellow trophy owner following with interest. You know there is a FB trophy group full of wisdom...Do you mind if I share this post there? No worries about you sharing it, I’m not on Facebook so unfortunately can’t partake of their wisdom, If I get stuck would you be ok to pass on a few Q’s ? Quote
Six30 Posted November 8, 2020 Posted November 8, 2020 As a fellow trophy owner following with interest. You know there is a FB trophy group full of wisdom...Do you mind if I share this post there? No worries about you sharing it, I’m not on Facebook so unfortunately can’t partake of their wisdom, WHEN I get stuck would you be ok to pass on a few Q’s ? Fixed Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 Cooling fan switch disconnected Cooling fan harness disconnected Horns disconnected - both sides ( Not standard fitting point, but looks ok on the radiator) Bottom fixings removed ( Both sides ) Top Fixings removed ( Both sides ) Radiator is free .... Oh no it’s not says law of Sod!! The fan harness is hooked up & you’ve forgotten the expansion tank hose !!Radiator off, emptied, wrapped in an old tablecloth & stored with the tank. Keep meaning to get some gloves when doing this kind of thing Quote
fastbob Posted November 8, 2020 Posted November 8, 2020 Does anyone remember the long thread on here where a guy stripped his Triumph down and then kind of lost interest or something and put it back together again without actually doing anything ? I'll have a dig later . Quote
fastbob Posted November 8, 2020 Posted November 8, 2020 Here it is . I haven't read it through but I think he lost his bottle in the end . https://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=65912&start=60 Quote
Mickly Posted November 8, 2020 Author Posted November 8, 2020 (edited) Right the side stand needs to be removed next.Top side stand bracket mounting removedSide stand switch connector undone Gear change linkage rod undone & moved to allow access to lower engine mounting bolt that also holds the side stand Lower engine mounting bolt removal - what Haynes don’t say is that you need 6” long fingers & the dexterity of Dynamo to get to the nut at the back.It’s hidden by a plastic plug. And remove the side stand .... but no, what Haynes failed to say is that the harness routes behind the water pump & the bloody connector doesn’t fit through the gap !! Water pump loosened & withdrawn a tad releasing the connector, also need to remove the water pump upper hose cover to wiggle the water pump out.Water pump Hose CoverSide stand removed & stored in an old shoebox.Hose cover wrapped & put with tin with other fixings ( danger of this turning into a biscuit thread )Watch this space ( or not ) for the next instalment.... removing the exhaust oooooooh Edited November 10, 2020 by Mickly Quote
