Possible cause water getting into the HT lead somewhere and shorting out, check for any cracks in the lead, and also check the plug cap for signs of water ingress.
  • Thanks 1
Also check the spark plug, a hairline crack in the insulation can hold water which allows the ignition charge to leak to earth.
You may not be able to see damage to a HT lead if it's internal. If you're getting problems in the wet on a bike that's 16 years old I'd replace the HT lead and plug as a matter of course and see how that goes. Give all the electrics a spray with WD40.
  • Thanks 1
Man after my own heart, although I suggest spraying in sections. Start with HT lead spark plus, then rest of wiring.  Done this way you might be able to isolate the location of the fault.
  • Thanks 1
Yeh the HT lead is only about a year old
Is it a good quality bike lead? I've known people buy cheap HT leads on smaller bike engines and they don't last long. Bikes work HT leads much harder than cars.
  • Thanks 1
There's so a lot of knock off leads on ebay etc always best to buy those sorts of things from a well known supplier
  • Thanks 1
I brought an orginal one from a supplier not a repro
If you're unsure if it's the lead or not, you can test it by wrapping insulating tape round it. If the problem goes away then it's the lead. If it doesn't then it's probably something else.
  • Thanks 1
Just make sure it's thoroughly dry before wrapping it in tape. Stick it on a radiator overnight.
  • Thanks 1
It's funny because I e been spraying the connection to the starter motor and it never cut out in the rain yesterday maybe it could be shorting out when wet hopefully cheers for all your answers guys
Insulator cap missing?
