Hi All
I have a kawasaki versys and the Output shaft was damaged due to the front sprocket nut being too loose
Ok So I decided to make a start on replacing the Transmission / Gearbox as the output shaft were worn to a point where I felt that I would put it in gear and the sprocket would just strip off what was left of the metal
Photo attached  is of the offending article
Sourced a replacement box on ebay
Have hit a bit of a dead end
Gearbox is back in and the chain is on
adjusted the clutch cable
put in some fresh oil
Bike is on the paddock stand
Turned the key & neutral light comes on wheel rotates freely
Start it up and it did not burst in to flames :-)
Engine running and I can select first gear bit of a clunk but it goes in
Try second gear and wahoo second works also
Try 3rd and its like its back in neutral no drive & the wheel stops rotating
Try 4th and it wont go in just makes a bit of a grating noise so I did not want to do any damage so I stopped
This morning I tried it again same thing so I thought maybe the shift rod needed a little adjustment and I spent quite a while adjusting it back and forward with no success :-(
No Matter what I did it just will not go in to any gear after 2
Thinking the replacement box was duff I took it back out
When it was out I noticed that the Locating dowels were still in the old box I had forgotten to swap them over and although I was skeptical that the dowels would make any difference I put the box back in with the dowels
Needless to say it made no difference :-(
So I took the box out again getting quicker at it now
I swapped over the good output shaft in to the old box and reinstalled and the blasted thing is the same with the old box wont go past 3rd gear
The old box was working ok other than the shaft damage so I'm thinking it must be me doing something wrong on installation as both boxes are exhibiting the exact same symptoms
Any gearbox guru's out there can point me in the right direction ?
Or any input at all is welcome at this point
I did not dismantle the selector I just removed and reinstalled it while replacing the gearbox
Cheers
J
Since you have tried reinstalling the original (worn) output shaft and stil go tthe same problem. It would appear to be an assembly problem.
Do you have a workshop manual for the bikre?
There may be a specific assembly process to get the gears aligned with the selector drum.
Hi Ian
Thanks for the reply
Yeah have the service manual and it seems straight forward this is a cassette type gearbox
Manual says to put it in neutral position
Slot the gearbox back in and insert the selector and cover check the drive and output shafts rotate freely in neutral
Kawasaki use what they call Positive Neutral finder
"The transmission is equipped with a positive neutral finder. When the motorcycle is standing still, the transmission cannot be shifted past neutral from 1st gear. To use the positive neutral finder, shift down to 1st gear, then lift up on the shift pedal while standing still. The transmission will shift only into neutral "
I am guessing this is working as I am able to shift from 1st to 2nd to third but after that the Lever comes up as usual but nothing happens it does not move in to fourth
This is being tested with the bike on the paddock stand
Last week with the old gearbox I was able to clean the chain and cycle through all gears to sling the excess oil off the chain before cleaning the rear tyre
photo is of the Selector and Neutral switch
Posted (edited)
Could it be that the rear wheel needs to be under load?
I would put it all back together and take it for a gentle spin round the block. See if you can get through the gears under normal conditions.
Edited by fullscreenaging
  • Like 3
Thanks for your reply :-)
That is a great Idea and certainly worth a shot as I have just been testing with it on the paddock stand
This afternoon I will put the chain back on and take it for a gentle run through the estate and see if anything jumps in to place
Thanks for the suggestion
J
Posted (edited)
Been out tinkering with the bike
Took it off the paddock stand to try bring it for a run
I was checking the adjustment of the clutch by putting it in to first gear pulling in the clutch in and pushing the bike to see if the clutch was releasing and to my surprise it did not
The clutch lever and the clutch actuating arm on the clutch cover seem to be operating normally and I had oiled the cable and the cable is about a year old and moves freely and seems to be in good condition
I can feel resistance against the spring but it was like it was not doing anything the drive still seemed to be engaged
So I started to adjust the clutch more to try get it to the point where the drive to the wheel was disengaged
several turns later the back wheel started to turn while pushing in gear but there was no drive to the wheel when in gear & the clutch was released with the engine running
In order to get drive to the wheel I had to slacken off the adjustment but then pulling the clutch in while in gear did not appear to to release the drive to the wheel
Sorry about the long posts but this is doing my head in
Could this be why it wont go in to gear above third and not a gearbox problem at all?
Or is that wishful thinking
J
Edited by V650
Hard to say from a description but bear in mind that motorcycle clutches do 'drag' a bit. So a bike on a stand the back wheel will spin even when the clutch lever is pulled in fully. Just checking you aren't expecting it to have no drag when disengaged.  On some bikes the drag can be very significant such that you can't turn the back wheel by hand with the clutch pulled in.
My experience is that gear selection can be hit and miss when on a stand. But you need to get the clutch set right before assuming there is problem with the gearbox.
  • Like 2
Thanks for the reply :-)
Trying to set the clutch was being done with the bike on the ground by putting it in gear pulling in the clutch and trying to roll the bike forward and it would not move
I tried adjusting via the adjuster at the clutch lever on the handlebars and also the adjuster near the clutch cover and by the time it got to a point where I could roll the bike
it was too much and had disengaged the drive to the wheel even with the clutch lever let off :-(
I have taken the clutch off again to have another look
Cheers
J
Posted (edited)
On 16/05/2022 at 12:33, fullscreenaging said:
Sounds like you’re getting there.
I wish :-)
I removed the clutch and basket again
The gearbox is still not engaging after 3rd
The selector drum seems to stop halfway round and the pin that the selector engages does not make it down low enough for the lever to push
Photo 1 is the selector and you can see that the pin has not rotated enough for the arm to catch
Photo 2 is the Cam on the other end of the shift drum and the roller has not quite made it in to gear
I drew on it with a marker 1 for 1st gear N for Neutral 2 for second gear  the Roller should be in the dip
Edited by V650
I reckon there is a slight difference in the two output shafts so gear teeth are not compatible so it doesn't turn the selector enough to engage the gear. Considering you had the same problem trying the new shaft with the original selector box points to the new shaft not being right
Yep could well be
I am thinking of putting the old gearbox with its original shaft back in to see if it will cycle through he gears
Wet and miserable here today so did not get a chance to do anything
will see what tomorrow brings
Thanks to both of you for your replies :-)
J
The issue was / is definitely the replacement box as with the clutch and basket removed the drum would not rotate past 3rd gear
I removed the box again ( getting to be an expert at it now ) and removed the output shaft and put the old damaged one back and reinstalled the box and other than the original damaged splines it is working Ok cycles through the gears by spinning the drive shaft by hand while turning the drum
I have buttoned it back up & refilled the oil
Started it up and runs and goes through the gears on the paddock stand
If the weather co operates I might get it out for a little run later
That's a few days I will never get back and still have the original issue but at least i'm back on the road for the moment so to speak
Thanks for the Help guys :-)
J
1 hour ago, fullscreenaging said:
Can you not send the box back at all?
After all it’s not fit for purpose.
Got it on ebay from Netherlands a few weeks back so might be worth looking in to alright
Though I would imagine the cost of sending it back would be extortionate
As you can imagine it's not just the cost of the box it was the wasted time taking it in and out multiple times & second guessing if I had done it right :-(
I’ve just done a quick quote with DPD
I don’t know how much you paid for it but the top quote is pretty good
I tried to over estimate the size and weight;
20kg
size 30cmx30cmx30
Thanks for checking that out for me :-)
The Box cost me €100
Just had a look on DPD Ireland site and it quotes €37 to ship it back
Glutton for punishment
My brain is telling me if i had more time I could remove all gears from that shaft and put the ones from my old box on to the better shaft
But only a sadist would think like that
Maybe a winter project
Or just sell the bike and offer the shaft along with it to sweeten the deal
  • Haha 1
  • 4 weeks later...
Could not stand driving round waiting for the sprocket to strip the teeth off the shaft
So I got another gearbox and put it in on Thursday Cost €280 from Italy and worked a treat no issues
I was able to cycle through the gears by spinning the input  shaft and turning the gear selector drum :-)
  • Like 6
Posted (edited)
Cheers guys
Got out for a run on thursday all seems to be going well :-)
I am off on hols up the west coast of Ireland ( Doonbeg Co Clare ) in the car with the wife and kids  for a week away & it is blowing a gale here
But the Views are fab from Loop head Lighthouse :-)
The wild atlantic way
J
Edited by V650
1 minute ago, V650 said:
Cheers guys
J
Make sure you sample a seafood chowder at one of the many local pubs it's the best!
 Will do :)
Although i have been stuffing my face since we got here Friday
Im on  seafood diet
The more I see the more I eat :-) :-)
J
