Breezin Posted July 11, 2022 Posted July 11, 2022 I'm stumped. The chain on my bike is supposed to be 100 links long. The one I bought has 110. So it would make sense to cut off 10, right? But what happens with the extra join link? Do I cut at 99, and add the joiner, or do I cut at at 100? Other suppliers of this chain pack 100 plus the additional link. But the chain that I've taken off the bike has just 100. Asking now, because I really don't want to risk having a brand new chain that's one link short! Quote
Mississippi Bullfrog Posted July 11, 2022 Posted July 11, 2022 Does your bike have the standard sized sprockets? And assuming you are changing chain and sprockets at the same time what size sprockets have you got compared to the one on the bike at the moment? From what I can see 15/38 is standard with a 100 link chain. Are you sure that other suppliers have 100 + 1 or is the link included in the 100? You could always cut slightly longer and test fit before rivetting the link if you're not sure. Quote
husoi Posted July 11, 2022 Posted July 11, 2022 Have you heard the saying. Measure 10 times cut once and buy again because you didn't measure it properly? As @Mississippi Bullfrog says, try it before cutting and make sure the adjuster is on the correct position. 1 Quote
Breezin Posted July 11, 2022 Author Posted July 11, 2022 (edited) Thanks both -- sensible advice. I certainly will be measuring it to the bike before cutting, but the OCD me wants it to conform to the 'standard' as written down. I have a regular 15/38 sprocket setup, which won't change -- new ones fitted but same size. Other suppliers say the chain is 100 with a split or rivet link supplied. But no listing I can find states clearly whether the additional link is included in the count or is additional to the 100. Edited July 11, 2022 by Breezin Quote
Stu Posted July 11, 2022 Posted July 11, 2022 Fit everything and set the adjusters to where they need to be for a new chain Fit the chain and hook the ends over the rear sprocket Now pull the chain to take up the slack rest it on the sprocket and you should be able to see how many links too long the chain is Are you counting the side plates? if so then the 100th one will be the link so you would cut to 99 but please check it on the bike before cutting PS hand a weight on the rear brake and put it in gear it will stop the chain falling on the floor 3 Quote
husoi Posted July 11, 2022 Posted July 11, 2022 1 hour ago, Stu said: Fit everything and set the adjusters to where they need to be for a new chain Fit the chain and hook the ends over the rear sprocket Now pull the chain to take up the slack rest it on the sprocket and you should be able to see how many links too long the chain is Are you counting the side plates? if so then the 100th one will be the link so you would cut to 99 but please check it on the bike before cutting PS hand a weight on the rear brake and put it in gear it will stop the chain falling on the floor You just spoiled all the fun of it. 1 2 Quote
billy sugger Posted July 11, 2022 Posted July 11, 2022 There will be a chain reaction if it all goes wrong 5 Quote
Breezin Posted July 11, 2022 Author Posted July 11, 2022 Well, nothing has gone pear-shaped just yet. I've measured it up on the bike, and it looks like it should be cut at 99 to add the extra link. But I'm gonna sleep on it. Quote
billy sugger Posted July 11, 2022 Posted July 11, 2022 You won't get much kip with a chain under the mattress 3 Quote
Breezin Posted July 11, 2022 Author Posted July 11, 2022 38 minutes ago, billy sugger said: You won't get much kip with a chain under the mattress You're on fire tonight Billy. Quote
Breezin Posted July 12, 2022 Author Posted July 12, 2022 (edited) So, just to continue the saga... I measured the fit put on the shorter length, as advised. All good. Then I went and overpressed one of the rivets, and it's popped through the side plate. Any suggestions to rescue this chain? Will it work if I push the pins through with the breaker and fit a new master link? Any help greatly appreciated... don't really feel like forking out for a new chain. Edited July 12, 2022 by Breezin 1 Quote
onesea Posted July 12, 2022 Posted July 12, 2022 1 hour ago, Breezin said: So, just to continue the saga... I measured the fit put on the shorter length, as advised. All good. Then I went and overpressed one of the rivets, and it's popped through the side plate. Any suggestions to rescue this chain? Will it work if I push the pins through with the breaker and fit a new master link? Any help greatly appreciated... don't really feel like forking out for a new chain. I would say remove old and fit new master or split link and it should be fine. You really don’t need to over round the river heads, you can make the link stiff. 1 Quote
Breezin Posted July 12, 2022 Author Posted July 12, 2022 Thanks onesea. Shall try that... hopefully it'll do the trick. Quote
onesea Posted July 12, 2022 Posted July 12, 2022 32 minutes ago, Breezin said: Thanks onesea. Shall try that... hopefully it'll do the trick. I hate it when people say that, means I will feel like it’s my fault if it goes wrong… 2 Quote
Breezin Posted July 12, 2022 Author Posted July 12, 2022 51 minutes ago, onesea said: I hate it when people say that, means I will feel like it’s my fault if it goes wrong… Of course! Quote
Breezin Posted July 13, 2022 Author Posted July 13, 2022 All done. Phew! Thanks again for the sound advice. Lesson learned: RTFM! Quote
