adekeys Posted September 21, 2016 Share Posted September 21, 2016 ok so got a er-5 for the wife when she passes her test next year....it starts and runs fine, but as soon as you release the clutch in first gear the engine stallshave tried moving the rear wheel on its own to see if anything like the brakes were binding but all seem to run smoothlyalso trying to engage second is almost impossibleis there either something wrong with the gearbox or something with the clutch?Thanks Quote Link to comment Share on other sites More sharing options...
megawatt Posted September 21, 2016 Share Posted September 21, 2016 Clutch is dragging Check cable, release mechanism and if necessary strip and clean clutch. Quote Link to comment Share on other sites More sharing options...
adekeys Posted September 21, 2016 Author Share Posted September 21, 2016 if the clutch was dragging would the back wheel not spin all the time?? Quote Link to comment Share on other sites More sharing options...
Stu Posted September 21, 2016 Share Posted September 21, 2016 Moved to the right section Check the side stand switch Quote Link to comment Share on other sites More sharing options...
Tango Posted September 21, 2016 Share Posted September 21, 2016 Will it run ok with the bike on the centre stand? If it cuts out with no load then it could be a shagged gearbox..... Quote Link to comment Share on other sites More sharing options...
adekeys Posted September 21, 2016 Author Share Posted September 21, 2016 ok thanks guys for the quick reply, didnt know older bikes had a sidestand switchlast time i ran it had it on the centre stand but the sidestand was still down Quote Link to comment Share on other sites More sharing options...
Tango Posted September 21, 2016 Share Posted September 21, 2016 ok thanks guys for the quick reply, didnt know older bikes had a sidestand switchlast time i ran it had it on the centre stand but the sidestand was still down Yeah.....Sidestand switches have been standard on most bikes for well over 20 years now....... Quote Link to comment Share on other sites More sharing options...
JRH Posted September 21, 2016 Share Posted September 21, 2016 Also on Kwaks you can't engage 2nd gear till you are actually moving. Helps on selecting neutral when stationary. Quote Link to comment Share on other sites More sharing options...
MR_W Posted September 21, 2016 Share Posted September 21, 2016 Also on Kwaks you can't engage 2nd gear till you are actually moving. Helps on selecting neutral when stationary.That is bloody clever and sounds like something I bloody need.Can find the gf's sense of humour easier than neutral. Quote Link to comment Share on other sites More sharing options...
Hoggs Posted September 22, 2016 Share Posted September 22, 2016 Also on Kwaks you can't engage 2nd gear till you are actually moving. Helps on selecting neutral when stationary.That is bloody clever and sounds like something I bloody need.Can find the gf's sense of humour easier than neutral. Kwaks are amazing Quote Link to comment Share on other sites More sharing options...
RantMachine Posted September 22, 2016 Share Posted September 22, 2016 Also on Kwaks you can't engage 2nd gear till you are actually moving. Helps on selecting neutral when stationary.That is bloody clever and sounds like something I bloody need.Can find the gf's sense of humour easier than neutral. Kwaks are amazing Hmm... don't think mine does that. Will have to try it after work! Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted September 25, 2016 Share Posted September 25, 2016 GF or selecting second???? Quote Link to comment Share on other sites More sharing options...
