Nah, not another one of those wanky internet challenges, just a way of opening the topic "who the hell gets anywhere near maximum temperature on these things?"
I can only use 40% max before it gets too uncomfortable. How high do you guys go?
Never seen the point of heating the palms of my hands when my arse is freezing off . 😀
I've also fitted heated seats on the Busa Bob :D
You have to bear in mind that these are a kinda 'one size fits all'.. some bars are notoriously hard to heat.. the heat being conducted away from the grips by whatever alloy has been used.. i think this is the case for some bars that are made from aluminium alloy. So, for these the heater has to work that much harder to maintain a temperature in the grips. Whereas other bars made from steel. will absorb the heat and not lose it so quickly due to conduction.
Fair point, never thought of that. I just thought it might have been a bravado thing, like choosing the hottest curry off the menu to impress a bird :lol:
Ah well , now you're talking! 😅
My bike came with heated grips, first time I've ever had em on a bike .... they will never get used though , if it's that cold out I won't be going out .
It revolves around your gloves.
If their summer styled you will feel the heat more than a true winter glove
Because unless there is something badly wrong with you, you arse is fatter than your fingers!
I always used to assume that grips would only heat the inside of the hand, and do nothing for the outside of the fingers which receive the impact of the wind. Instead I had heated glove liners for cold weather which were okay.
Then I got a bike with heated grips installed and discovered I was very badly wrong.
The heat spreads though the hand just fine. Whilst the insides of them are warmer, the outsides still feel better than they did in the liners. And I feel more in control without having the extra layer of padding between my fingers and the bike.
They are official Honda grips though so only have three settings, but that is plenty for all situations.
I fitted some oxford grips to my YBR a couple of weeks ago when it was still cold. I never go above 50%!
I have a better challenge
The post in the correct section challenge :lol:
Don't worry I have moved your thread to the correct one :lol:
As [mention]Gerontious[/mention] says the bars alone have a lot to do with the heat output
I can easily have mine on max any less and it's hardly worth having on!
In winter I can easily run at 100%, most normally it's either 50 or 75.
I did my lessons through the winter, I had the grips on 100% :D . My gloves were cheap Aldi ones and started to melt at points.
And next....how many lines of Wasabi can you snort? :twisted:
None. But I do get very cold hands hence why I run a higher setting than most.
I had the hot grips on my last bike and could easily use 100% but I wore summer gloves all year round
Sent from my SM-G930F using Tapatalk
I have these grips on my Tiger 800 and rarely use them above 50% but I do have winter gloves.
  • 2 weeks later...
During winter months, on my daily early morning half an hour commute to work, I had heated grips on 75% most of the time. And I wore winter gloves.
