Six30 Posted September 29, 2019 Posted September 29, 2019 Any one had experiance of em , vision , vibration , best ones to get , are they easy to fit ? Quote
fastbob Posted September 29, 2019 Posted September 29, 2019 Would I be correct in assuming that in order to fit bar end mirrors you would have to sacrifice your bar end weights ? So you might get more vibration through your hands as a result . Depends on the design I suppose . Quote
Mississippi Bullfrog Posted September 29, 2019 Posted September 29, 2019 I have them on the Bobber. I'm pretty sure they have the weights built into them.They have short stems so vibration isn't an issue. Only minor niggle might be that they tend to be a bit smaller than the conventional stalk type but I've not found it a problem.Being right on the end of the bars they are in a good position. Quote
Six30 Posted September 29, 2019 Author Posted September 29, 2019 I have them on the Bobber. I'm pretty sure they have the weights built into them.They have short stems so vibration isn't an issue. Only minor niggle might be that they tend to be a bit smaller than the conventional stalk type but I've not found it a problem.Being right on the end of the bars they are in a good position. Did you fit them ? I turn into mr Bean when I pick up a screwdriver or spanner . Quote
Mississippi Bullfrog Posted September 29, 2019 Posted September 29, 2019 I have them on the Bobber. I'm pretty sure they have the weights built into them.They have short stems so vibration isn't an issue. Only minor niggle might be that they tend to be a bit smaller than the conventional stalk type but I've not found it a problem.Being right on the end of the bars they are in a good position. Did you fit them ? I turn into mr Bean when I pick up a screwdriver or spanner . No - they're standard fittings. Quote
Titter Posted September 30, 2019 Posted September 30, 2019 Had them on a Street Triple, easy enough to fit. Fitted them and a tail tidy when I first got the bike. A year later I put the originals back on. They both looked great but I got fed up of getting a wet arse and couldnt see much behind me I'm getting old Quote
Fleck Posted September 30, 2019 Posted September 30, 2019 Mine screwed on using an M6 countersunk bolt. They are smaller but look loads better than the big KTM originals. The missing weights haven't made any difference.http://i119.photobucket.com/albums/o151/fleck_bucket/Mobile%20Uploads/20180420_145318.jpgI took the big ones off, before anybody suggests it Quote
One Ball 1971 Posted October 1, 2019 Posted October 1, 2019 I have Rizoma Spy R 80 bar end mirrors on mine. I find them much better, you can actually see what's behind you. No noticable vibrations, nice, quality piece of kit. Quote
brad93 Posted October 1, 2019 Posted October 1, 2019 Just bought a set off Amazon. £11.99. Came today and feel surprisingly well made for the price! Hopefully get them fitted soon, once I’ve found a way to get the original bolts out as Kawasaki add locktite to them out the factory Quote
Mr Fro Posted October 1, 2019 Posted October 1, 2019 Just bought a set off Amazon. £11.99. Came today and feel surprisingly well made for the price! Hopefully get them fitted soon, once I’ve found a way to get the original bolts out as Kawasaki add locktite to them out the factory Not on any Kwak I've ever owned. Quote
Marino Posted October 1, 2019 Posted October 1, 2019 Just bought a set off Amazon. £11.99. Came today and feel surprisingly well made for the price! Hopefully get them fitted soon, once I’ve found a way to get the original bolts out as Kawasaki add locktite to them out the factory Not on any Kwak I've ever owned. I had z750r and bar end bolts were fitted with tread lock Quote
Marino Posted October 1, 2019 Posted October 1, 2019 However, aftermarket mirrors only if they are same size as original, i dit try some rizoma mirrors, they look fantastic, but too small. Got original back in place immediately. Quote
brad93 Posted October 2, 2019 Posted October 2, 2019 Just bought a set off Amazon. £11.99. Came today and feel surprisingly well made for the price! Hopefully get them fitted soon, once I’ve found a way to get the original bolts out as Kawasaki add locktite to them out the factory Not on any Kwak I've ever owned. Mine definitely are, my mates were on his Z900 too Quote
Mr Fro Posted October 2, 2019 Posted October 2, 2019 Well I suppose my "newest" bike is 13 years old so maybe it's a recentish thing. Quote
geofferz Posted October 3, 2019 Posted October 3, 2019 I fitted £9 ebay ones to my mt10 and they're great. Dead easy to fit. Quote
Six30 Posted October 3, 2019 Author Posted October 3, 2019 I fitted £9 ebay ones to my mt10 and they're great. Dead easy to fit. That's what I've done .... £24 , I'll see how I get on with em . Quote
geofferz Posted October 5, 2019 Posted October 5, 2019 I fitted £9 ebay ones to my mt10 and they're great. Dead easy to fit. That's what I've done .... £24 , I'll see how I get on with em . Good luck. I forgot: I had to position the right mirror a mm away from its natural resting position stuck up against the throttle tube thing as the throttle wouldn't snap back shut, which was dangerous! But mine were expanding flange type fittings so all good - pulled it out a mm, screwed open the thing, done. And it takes forever to get them in the right position - try mirror rolled forward and backward as well as tilt back and forth, and laterally. And you may hit the mirror with your glove initially, I got used to not doing so eventually. Quote
Cpt_Tact Posted October 10, 2019 Posted October 10, 2019 I have a set on my ST R675 and providing you accept your visibility is less then its all good. Never had a issue with filtering or vibration but do have my knuckle armour scuffed from reaching for leavers. It cleans up the lines on my bike a treat! Quote
ShouldKnowBetter Posted October 19, 2019 Posted October 19, 2019 I switched out my mirrors for bar ends on my T100 Bonnie visibility just as good as the stock mirrors but I think they look a bit cooler. Can’t figure out how to insert a photo any more, used to just be able to paste it in. If I figure it out I’ll add one. Quote
geofferz Posted October 20, 2019 Posted October 20, 2019 I switched out my mirrors for bar ends on my T100 Bonnie visibility just as good as the stock mirrors but I think they look a bit cooler. Can’t figure out how to insert a photo any more, used to just be able to paste it in. If I figure it out I’ll add one. Quote
ShouldKnowBetter Posted October 20, 2019 Posted October 20, 2019 Cheers geofferz for pointing out the obvious! Quote
geofferz Posted October 20, 2019 Posted October 20, 2019 Cheers geofferz for pointing out the obvious! It's what I do! Nice bike. Quote
