Bike still not running unless it's got jump leads attached.
McBert
Fitted new battery, boom started no probs,, put all back together, ready to get going,, nothing again.
Put on jump leads get it started but when take leads off it dies of death?? Anyone came across this before,,
Bike is cbf 125 any info very welcome..
Thanks in advance..
Thanks in advance..
Did you solve the original "lights not working" problem
Rectifier seems roasting as never noticed this before is this normal or could this be problem?
Semi thinking it could be solenoid as it seemed to drain battery even when switched off.. (arrrgghh :crybaby: (doin my freaking Heid in,, )(aye am Scottish )
Don't think it's a wiring problem if it starts with a jump either charging or problem with the starter
So you think it will still charge up if there is a loose wire ? How does the power get INTO the battery ?
  • Sign up now
