TimR Posted April 12, 2020 Posted April 12, 2020 Completely agree with this assessment.And as he has a Harley he is very experienced in oil leaks Perhaps you would be kind enough to point them out to me . Hmmm looks a bit suspect there Quote
fastbob Posted April 12, 2020 Posted April 12, 2020 Completely agree with this assessment.And as he has a Harley he is very experienced in oil leaks Perhaps you would be kind enough to point them out to me . Hmmm looks a bit suspect therePolish_20200411_231005474~2.jpg Oh there it is ! I wondered why my boots were soaked in oil . Quote
skyrider Posted April 12, 2020 Posted April 12, 2020 well the oil should stop them from cracking Quote
Blackholesun Posted September 13, 2022 Posted September 13, 2022 I also dropped my bike today 1st time misjudged where I put my foot down and over it went...anyway seemed like fuel was leaking out for a bit from some rubber tubes so was wondering if this is because it was on its side for a few minutes until I could find a passerby to help me lift it up? Have moved the bike back and seems to be fuel leak free now 1 Quote
bonio Posted September 13, 2022 Posted September 13, 2022 The rubber tubes are there to handle overflows from the tank. They run with fuel if you overfill, and they can do the same when the bike goes over. So no worries on that count. I hope the rest of the bike is ok 1 Quote
bonio Posted September 13, 2022 Posted September 13, 2022 @Esoteric I managed to fix a small crack in the engine casing using chemical metal. I just slapped some on the outside over the crack. It slowed the leak down to begin with, and after a year or so, it stopped it completely. Quote
Mickly Posted September 13, 2022 Posted September 13, 2022 23 minutes ago, bonio said: @Esoteric I managed to fix a small crack in the engine casing using chemical metal. I just slapped some on the outside over the crack. It slowed the leak down to begin with, and after a year or so, it stopped it completely. Was that once it had lost all of its oil 2 Quote
Blackholesun Posted September 14, 2022 Posted September 14, 2022 9 hours ago, bonio said: The rubber tubes are there to handle overflows from the tank. They run with fuel if you overfill, and they can do the same when the bike goes over. So no worries on that count. I hope the rest of the bike is ok Cheers seemed to be ok today looks like I got away with only needing to adjust the brake lever.was a bit embarrassing as I couldn't lift it up needed help from a kind passed by! 1 Quote
keith1200rs Posted September 14, 2022 Posted September 14, 2022 You need to look up the techniques for picking up motorbikes - even 300kg+ bikes should not present a problem with the right technique on your own. 1 Quote
Blackholesun Posted September 14, 2022 Posted September 14, 2022 (edited) Had a look today at a view videos and they make it look so easy ! 13 hours ago, bonio said: Edited September 14, 2022 by Blackholesun Quote
