fastbob Posted September 21, 2020 Author Posted September 21, 2020 Great score ! Someone on the ER5 FB group was clearing out a job lot of ER5 junk so I persuaded him to flog me just the bars complete with controls , switchgear and bar ends for £10 ! Jumped on the Harley and shot over to Hinckley to grab them . Quote
fastbob Posted September 23, 2020 Author Posted September 23, 2020 I've gone and done it again . I've bought a winter project and it's half finished in September . Setting aside the engine as a separate entity , all that's left to do is reinstall the wiring loom , change the fork seals , fettle the rear brake drum , rebuild the front caliper and find some decent shocks . Time to start looking in Blackberry bushes again . Quote
skyrider Posted September 24, 2020 Posted September 24, 2020 I've gone and done it again . I've bought a winter project and it's half finished in September . Setting aside the engine as a separate entity , all that's left to do is reinstall the wiring loom , change the fork seals , fettle the rear brake drum , rebuild the front caliper and find some decent shocks . Time to start looking in Blackberry bushes again . good to hear that you are well on it's case Bob Quote
fastbob Posted September 24, 2020 Author Posted September 24, 2020 I've gone and done it again . I've bought a winter project and it's half finished in September . Setting aside the engine as a separate entity , all that's left to do is reinstall the wiring loom , change the fork seals , fettle the rear brake drum , rebuild the front caliper and find some decent shocks . Time to start looking in Blackberry bushes again . good to hear that you are well on it's case Bob It's like a release of pent up frustration at having a Harley that is virtually maintenance free . Hydraulic Lifters , belt drive , oil in a tank and everything built to agricultural standards . Nothing worth getting the spanners out for . Quote
fastbob Posted September 25, 2020 Author Posted September 25, 2020 Everything loosely bolted up in case I misplace a bit . That's all the shit and filth , pine needles , rust , spiders and flakey paint dealt with and now that it's spotlessly clean and all the painting is done it's time to move the project indoors . Fitting the wiring loom is next up when the push-in clips arrive . I'm attempting to keep it as per the original and avoid putting Zip Ties around the frame . Those switchgear units that came with the £10 bars are way better than what was on it which had all the writing rubbed off . Just spent the evening bashing the rear brake lever back into shape . Quote
fastbob Posted September 25, 2020 Author Posted September 25, 2020 What a difference If I get the finish on the engine up to the standard of the last one it should look the bollocks . Quote
fastbob Posted September 26, 2020 Author Posted September 26, 2020 The telly's shit but I've got this to look at . Quote
fastbob Posted September 27, 2020 Author Posted September 27, 2020 I thought I'd give the forks a tidy up today . I'm aiming for a brushed effect which I will later give a coat of clear lacquer . Scotchpad and WD40 seems to do the trick . Quote
fastbob Posted September 30, 2020 Author Posted September 30, 2020 Calliper done . I regret not taking a Before picture because it was an absolute lump of shit . How anyone was using it to stop a motorcycle and surviving is beyond me . The finish is Halfords Aluminium Engine Paint , two coats and then baked in the oven for an hour . Quote
fastbob Posted October 1, 2020 Author Posted October 1, 2020 Thermostat housing smartened up a bit . I popped the thermostat in a pan of water and brought it to the boil and it opened nicely . Ok , I didn't use a thermometer but it will do for now . Quote
fastbob Posted October 2, 2020 Author Posted October 2, 2020 New pads and seals in . Just waiting for a nice red braided line now . Quote
fastbob Posted October 3, 2020 Author Posted October 3, 2020 Put the wiring loom back on today . It looks a bit messy in places but that's pretty much now it goes . Quote
fastbob Posted October 4, 2020 Author Posted October 4, 2020 Dosen't look any different but all the electrics are installed and connected up . Next time I take off a wiring loom I'll remember to take more photos ! Now I can turn my attention to the engine . Quote
fastbob Posted October 7, 2020 Author Posted October 7, 2020 Braided line has arrived . I bought from a Northern Irish company called OHA for £22 and I'm very pleased with it . I like to put a few highlights in a contrasting colour on my bikes . My Gasket Set and Exhaust Studs are also here but I'm waiting for an 8 mm Stud Extractor before I go near them . Then it's pop the lid off and see what horrors lurk within . Oh , I've ordered some Camshafts for £15 as well because I don't like the look of what's in it. That's the great thing about ER5s , parts are abundant and cheap especially if you join a FB group . I'v even had a bit of free stuff . Quote
Mr Fro Posted October 9, 2020 Posted October 9, 2020 Valve cover , descabbified . Looks smart. How did you do that? Quote
fastbob Posted October 9, 2020 Author Posted October 9, 2020 Valve cover , descabbified . Looks smart. How did you do that? Hours of hand scrubbing with progressively finer Scotch Pads ( Toolstation equivalent ) degreased with cheapo Brake Cleaner , Two wet coats of Halfords Aluminium Engine Paint and then when it was dry I baked it in a medium oven for an hour to cure it . Life used to be so much easier when Nitromors actually worked . Quote
Mr Fro Posted October 10, 2020 Posted October 10, 2020 Hours of hand scrubbing with progressively finer Scotch Pads ( Toolstation equivalent ) degreased with cheapo Brake Cleaner , Two wet coats of Halfords Aluminium Engine Paint and then when it was dry I baked it in a medium oven for an hour to cure it . Life used to be so much easier when Nitromors actually worked . Nice. You must be a very patient man!Can you link the scotchbrite please? I've been meaning to try some but don't like the price of the pukka ones. Quote
fastbob Posted October 10, 2020 Author Posted October 10, 2020 Hours of hand scrubbing with progressively finer Scotch Pads ( Toolstation equivalent ) degreased with cheapo Brake Cleaner , Two wet coats of Halfords Aluminium Engine Paint and then when it was dry I baked it in a medium oven for an hour to cure it . Life used to be so much easier when Nitromors actually worked . Nice. You must be a very patient man!Can you link the scotchbrite please? I've been meaning to try some but don't like the price of the pukka ones. https://www.toolstation.com/contour-sanding-pads/p10736 Quote
Mr Fro Posted October 10, 2020 Posted October 10, 2020 https://www.toolstation.com/contour-sanding-pads/p10736 Quote
