fastbob Posted November 21, 2020 Share Posted November 21, 2020 What an I missing here ? When I attempt to add a reply to a thread , my previous reply pre populates the box . ?? Quote Link to comment Share on other sites More sharing options...
Bender Posted November 21, 2020 Share Posted November 21, 2020 It saves anything you didn't finish, there is a tick box to delete it Quote Link to comment Share on other sites More sharing options...
Bender Posted November 21, 2020 Share Posted November 21, 2020 Just tried it, on the mobile it comes up at bottom saying previous text was saved, there is a x to delete it Quote Link to comment Share on other sites More sharing options...
Stu Posted November 21, 2020 Share Posted November 21, 2020 I am guessing this is only on mobile Bob? I haven't used my phone much so can't say I have seen it happen Quote Link to comment Share on other sites More sharing options...
JRH Posted November 21, 2020 Share Posted November 21, 2020 Happens on the IPad as well, but only if it is from an unfinished post. As @Bender says. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted November 21, 2020 Share Posted November 21, 2020 One little bug I did find when replying (or even just posting) is if you double click any of the smileys it deletes your entire post and replaces it with the smiley you chose Not the end of the world but thought I'd share as its annoying when you have your entire post reduced to 1 Quote Link to comment Share on other sites More sharing options...
fastbob Posted November 23, 2020 Author Share Posted November 23, 2020 Right , well I'll give it a try . It only does it when I try to reply twice in the same thread . I would have thought that once I've sent or posted it would clear itself . I have to say , I'm still struggling with this new format . Just now I went to unread posts , looked at something , accidentally exited and now of course it's no longer in unread posts . But where is now if I want to find it again ? Quote Link to comment Share on other sites More sharing options...
learningtofly Posted November 23, 2020 Share Posted November 23, 2020 (edited) 11 minutes ago, fastbob said: Right , well I'll give it a try . It only does it when I try to reply twice in the same thread . I would have thought that once I've sent or posted it would clear itself . I have to say , I'm still struggling with this new format . Just now I went to unread posts , looked at something , accidentally exited and now of course it's no longer in unread posts . But where is now if I want to find it again ? You'll find it under the "Active" button. Edited November 23, 2020 by learningtofly 1 Quote Link to comment Share on other sites More sharing options...
Tiggie Posted November 23, 2020 Share Posted November 23, 2020 This button on mobile Quote Link to comment Share on other sites More sharing options...
learningtofly Posted November 23, 2020 Share Posted November 23, 2020 (edited) 17 minutes ago, Tiggie said: This button on mobile I have a feeling that might be the default stream button, which is personal settings-dependent. (For example, mine takes me to a completely different stream - the one I've set as my default.) Edited November 23, 2020 by learningtofly Quote Link to comment Share on other sites More sharing options...
Tiggie Posted November 23, 2020 Share Posted November 23, 2020 I believe you are right all activity should be the default stream though and that is pretty much unread posts Quote Link to comment Share on other sites More sharing options...
Stu Posted November 23, 2020 Share Posted November 23, 2020 35 minutes ago, Tiggie said: I believe you are right all activity should be the default stream though and that is pretty much unread posts The default is unread as labelled on the bottom of mobiles so not to cause confusion But you can change your own default as described in my guide Quote Link to comment Share on other sites More sharing options...
Tiggie Posted November 23, 2020 Share Posted November 23, 2020 What he said!! 1 Quote Link to comment Share on other sites More sharing options...
James in Brum Posted November 23, 2020 Share Posted November 23, 2020 Bob, you can still look the old way. Hit the home buttons and look for thread titles or if it is not longer in un read you can search for it with the search at the top of the page. 1 Quote Link to comment Share on other sites More sharing options...
