Probably ebay or have a look on FB market place, they are usually called panels :thumb:
so side panels if they come from ebay would i expect them to come with all the screws etc to fit it on..cheers
Very much doubt it, you may find them on Wemoto, you might even be able to get the panels from there too but new rather than used :thumb:
no the side pannels usually have two lugs and one screw hole each side, you will have to supply your own screws and you could have a look for bar end weights while you are on fleabay :thumb:
If you find 2nd hand panels you could always ask the seller if he has the screws as well.
Make sure you get panels for the same or newer year thn yours, earlier model panels are different ( Earlier YBRs don't have the extra plastic panels at the front of the tank.
AS said above you needa chain guard as well, I think ti will fail an MOT without.
Bar ends are optional, thye stop vibrations that make you fingers tingle.
Posted (edited)
It looks like you need this;
https://www.wish.com/product/5ec79ad785f4c7102c5be70c?hide_login_modal=true&from_ad=goog_shopping&_display_country_code=GB&_force_currency_code=GBP&pid=googleadwords_int&c={campaignId}&ad_cid=5ec79ad785f4c7102c5be70c&ad_cc=GB&ad_curr=GBP&ad_price=32.00&campaign_id=6493229882&exclude_install=true&gclid=Cj0KCQiA2uH-BRCCARIsAEeef3nN6JqBmVQoDC2SsjjpUDHNKVr_d_IjOsmSMo53nF6R8EdwcyGRB28aAiIQEALw_wcB&share=web
That gives measurements so you can check if it is correct and the hole for the bolt lines up. You just need to get the correct sized bolt, preferably stainless steel as it is less likely to corrode.  For £8 you could get this job lot and renew various bolts on your bike.
https://www.ebay.co.uk/itm/193536141548
Please note, I have found examples, I have not checked them or shopped about for the best price.
Edited by Throttled
STUFF FROM WISH?????
Are you trying to get a TOTY nomination??
  • Haha 1
I just posted the first link I found, I have no idea what "Wish" is, and I did say check and shop around. Here is another on ebay, twice the price;
https://www.ebay.co.uk/itm/New-Yamaha-YBR125-YBR-125-2005-2009-Left-Right-Side-Panel-Battery-Cover-Black/184364179059?epid=16003390053&hash=item2aecf61e73:g:ZM0AAOSwTIRfEcpr
5 minutes ago, Blackholesun said:
i did buy the wrong things then...oh man i'm thick
I have made the same mistake in the past. I still have a centre stand in the shed that was the wrong one. You could try and resell them.
shove them on fleabay :classic_blink:
Bar end weights do make a difference...
Regarding S/S bolts I would not worry, just put some copper slip on when you put regular ones in.
If you use S/S you will need some duralac or similar to stop galvionic corrosion...
