Elvispercy Posted November 25, 2022 Share Posted November 25, 2022 Is this a good idea or will they drain the hell outta my battery? Quote Link to comment Share on other sites More sharing options...
billy sugger Posted November 25, 2022 Share Posted November 25, 2022 Absolutely fine Quote Link to comment Share on other sites More sharing options...
Tigs Posted November 25, 2022 Share Posted November 25, 2022 I'm not sure - but I got silk inners for my gloves and they do make a difference - my hands are warm - and not sweaty. I've been advised that a heated gilet - is the way to go (they are about £100 and I think heated with a a battery pack Quote Link to comment Share on other sites More sharing options...
onesea Posted November 26, 2022 Share Posted November 26, 2022 (edited) Should be fine, however I alway run extras through a relay. That way you are confident when the key turns off nothings running. 1) Ignition or Toggle switch splice into wiring where appropriate (hardest part), 2) Water pump is device eg heated grips, I also have USD charger for my phone. For heated grips I recommend these: https://www.ebay.co.uk/itm/374345005992 oldest are 5 years have fitted to a few bikes, never had a failure. The big advantage is they don’t have a big control unit to mount on bike. The disadvantage is they don’t get as hot as oxfords, they also don’t draw much power. It also means they don’t heat your hands so much they start sweating get wet and cold. I have ridden ALL year and had cool hands but never cold. Edited November 26, 2022 by onesea 1 Quote Link to comment Share on other sites More sharing options...
Elvispercy Posted November 26, 2022 Author Share Posted November 26, 2022 Cheers everyone for your input Quote Link to comment Share on other sites More sharing options...
bonio Posted November 26, 2022 Share Posted November 26, 2022 If you want to be sure, checking your alternator rating. Here's my post from a year ago, in case it helps: Quote Link to comment Share on other sites More sharing options...
onesea Posted December 2, 2022 Share Posted December 2, 2022 On 25/11/2022 at 23:27, Tigs said: I've been advised that a heated gilet - is the way to go (they are about £100 and I think heated with a a battery pack Try £10 https://www.amazon.co.uk/Electric-Washable-Clothing-Charging-Motorbike Buy big as I am large but in this I am 3xl, ladies sizes available as well. I like the ones with neck warmer. Already had battery pack (large ish) and it lasts all day on low which is all I have needed. Arms and legs still chilly but warm up much quicker as core is warm... 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted December 5, 2022 Share Posted December 5, 2022 On 02/12/2022 at 21:25, onesea said: Try £10 https://www.amazon.co.uk/Electric-Washable-Clothing-Charging-Motorbike Buy big as I am large but in this I am 3xl, ladies sizes available as well. I like the ones with neck warmer. Already had battery pack (large ish) and it lasts all day on low which is all I have needed. Arms and legs still chilly but warm up much quicker as core is warm... How's your face since you got it? 'Facial improvement and body shaping: it activates various functions between the skin and promotes metabolism.' Quote Link to comment Share on other sites More sharing options...
