Gibbo Posted February 20, 2023 Share Posted February 20, 2023 Hi all, I've had my Yamaha YS125 (2019) for around a year now. The previous owner said it went over in strong wind so it had scuffs but no major damage when I purchased it. After a heavy downpour I noticed condensation behind the screen which I dried out but has returned. The screen now intermittently comes on as if it's in the start up sequence during ignition, without the key being present. Any ideas what this could be? I've isolated the battery for now. Hopefully this link will work. https://photos.app.goo.gl/oREbzJCLewaWWfDn9 Quote Link to comment Share on other sites More sharing options...
bonio Posted February 20, 2023 Share Posted February 20, 2023 That is freaky. No, soz, not a clue. Quote Link to comment Share on other sites More sharing options...
Stu Posted February 20, 2023 Share Posted February 20, 2023 When it does it will the bike start without the key? Quote Link to comment Share on other sites More sharing options...
Old-codger Posted February 21, 2023 Share Posted February 21, 2023 I seem to think I have read this problem before that it is a common problem of water getting into the binnicle and all manner of strange things happen to the electrical circuits. Quote Link to comment Share on other sites More sharing options...
Bender Posted February 21, 2023 Share Posted February 21, 2023 5 hours ago, Old-codger said: I seem to think I have read this problem before that it is a common problem of water getting into the binnicle and all manner of strange things happen to the electrical circuits. Yup water and electricity don't mix well when it's not designed for it, I had a boiler pcb with water in it, turned off when turned on, ran the heating when hot water was called for, on heating it fired the burner but not the pump and all of that only with it in the off position hair dryer is good way to dry out electrical stuff. 1 Quote Link to comment Share on other sites More sharing options...
bonio Posted February 21, 2023 Share Posted February 21, 2023 1 hour ago, Bender said: hair dryer is good way to dry out electrical stuff. used gently Quote Link to comment Share on other sites More sharing options...
Gibbo Posted February 21, 2023 Author Share Posted February 21, 2023 18 hours ago, Stu said: When it does it will the bike start without the key? Lucky it doesn't. Seems to stop once the ignition is turned over. I'll give the hairdryer a go. Thanks all Quote Link to comment Share on other sites More sharing options...
Bender Posted February 21, 2023 Share Posted February 21, 2023 2 hours ago, bonio said: used gently Nope, ghd full belt (I have a better hair dryer than the wife) usually leave to cool for 10 min before putting power back on Quote Link to comment Share on other sites More sharing options...
Old-codger Posted February 21, 2023 Share Posted February 21, 2023 Once you have dried it out try and find where the moisture is getting in and seal it up. Quote Link to comment Share on other sites More sharing options...
onesea Posted February 22, 2023 Share Posted February 22, 2023 18 hours ago, Old-codger said: Once you have dried it out try and find where the moisture is getting in and seal it up. Or put a hole so it can drain out, Hobsons choice IMHO. Just make hole is not where water can get forced in. Quote Link to comment Share on other sites More sharing options...
