Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 I found a video on YouTube which I think shows me how to do it. It looks like filler bolt is up and at the back of the engine in a nuisance spot. I’ll check out the parts diagram to find out what the part is with a wire. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 [mention]fastbob[/mention] Thank you very much. All my looking did not help me find those images. They look really helpful. I’ll feed back in a bit, I am going to try today. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 So I think this is where I put new oil? Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 If so the bolt head bit is soft as anything and alread a bit rounded. I don’t have my sockets at the moment. Not sure what to do? I haven’t let the oil out yet fortunately. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Yup bolt head type part is soft and rounded. At this point I am stumped and don’t know what to do. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Answer is mike grips. I am pressing on...Scratch that. Tried to undo what I think is the sump plug and it is blocked by the exhaust. As far as I can undo it it hits the exhaust before being removable. Help. Quote Link to comment Share on other sites More sharing options...
JRH Posted August 30, 2018 Share Posted August 30, 2018 Answer is mike grips. I am pressing on...Scratch that. Tried to undo what I think is the sump plug and it is blocked by the exhaust. As far as I can undo it it hits the exhaust before being removable. Help. has oil come out? Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 A small drip. Not really. The thread and the bolt are oily but it wasn’t running down the bolt. Quote Link to comment Share on other sites More sharing options...
JRH Posted August 30, 2018 Share Posted August 30, 2018 A small drip. Not really. The thread and the bolt are oily but it wasn’t running down the bolt. Doesn't sound like the sump bolt then. If it was the sump then i would expect oil to pour out as the bolt is undone.can you still see oil in the engine through the level glass?editlooked at some utube vids and the sump plug is long so if it is still in the threaded part it may still be preventing the oil from coming out. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Unless I am supposed to drain it through the fuel filter thimble hole then I think I have the right bolt. It is at the lowest point of the engine.Problem is I think I need to at least loosen the exhaust to get it off.I might ring the bike garage down the road and see if I can watch them change my oil. Then I can do next time. Quote Link to comment Share on other sites More sharing options...
JRH Posted August 30, 2018 Share Posted August 30, 2018 Does it look like the exhaust may have been changed at some point?and is there still oil in the engine? Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Not been changed. It is a new Chinese made bike. Starting to understand some of the criticism now. I think the bike is based on a Honda and in the images of that bike I can see the exhaust does not run up the middle of the bike. I cannot see anywhere else that could be sumo plug. It has a little seal on it and everything. I suspect it is poor design. But it could be more of me being a muppet. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 30, 2018 Share Posted August 30, 2018 There are often more than one bolt on the underside of engines, on some Suzukis for examples it's common for people o undo the gear selector detent spring bolt which allows the engine oil to drain but it's not the drain plug. If that is the only bolt then it sounds like the designer failed to spot the exhaust was going to foul it - in which case it means undoing the back end of the exhaust and seeing if it will shift sideways enough to clear the bolt. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 30, 2018 Share Posted August 30, 2018 If you are certain that it is a seal and not just a metal washer - Then you have the correct bolt.Therefore it looks like you will have to loosen and drop the exhaust (or remove it).As to the 'rounded' filler cap nut. Mole Grips should work but, you really should replace it. it has probably been over-tightened.Use of the correct socket should keep it OK. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 30, 2018 Share Posted August 30, 2018 Think long and hard before trying to undo the: exhaust bolts, nuts at the head. If you shear one , youre in a world of pain. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Do I risk it, think of this as a learning opportunity and go for it, carefully moving the exhaust or in case I have it all wrong do I pay the mechanic person to do an oil change and watch? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 30, 2018 Share Posted August 30, 2018 You Tube Video?Owner's blog?Workshop Manual?Friendly TMBF guy close by who could take a look and advise? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2018 Share Posted August 30, 2018 Think long and hard before trying to undo the: exhaust bolts, nuts at the head. If you shear one , youre in a world of pain. Can't he just loosen the silencer and take that off? Or is it all one piece? I am beginning to subscribe to the gear selector drum detent school of thought. I have never come across a bike that required the exhaust to be removed to get to the sump plug.....but I'm not saying they don't exist....... Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 30, 2018 Share Posted August 30, 2018 That bolt looks daft long to be a sump plug, but it is Chinese. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 30, 2018 Share Posted August 30, 2018 Need a decent picture showing the whole base of the engine.Does no-one live close to this chap? Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 30, 2018 Share Posted August 30, 2018 If it is the sump plug, try undoing the silencer support bracket bolt and gently turn the whole exhaust away from the sump bolt. May not have to undo the header bolts/nuts. Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 30, 2018 Share Posted August 30, 2018 Do I risk it, think of this as a learning opportunity and go for it, carefully moving the exhaust or in case I have it all wrong do I pay the mechanic person to do an oil change and watch? Mate, PM me with your postcode and I'd be happy to nip over from Coventry and help you sort this thing out on Saturday morning. Don't remove the exhaust just yet because you will need a new gasket. Quote Link to comment Share on other sites More sharing options...
Muttly Posted August 30, 2018 Author Share Posted August 30, 2018 Thank you [mention]fastbob[/mention] pm sent Quote Link to comment Share on other sites More sharing options...
