hussnainh8 Posted June 5, 2019 Posted June 5, 2019 Hi,If anyone could help me with this quick question it would be greatful.. My tube in my tyre ended up flat so I had to replace the inner tube however when putting the tyre back on.. I noticed the direction arrows are the same as the front tyre which if im correct it should be the opposite not the same?I have a few pictures here of my 2 tyres, please could anyone tell me which way they are meant to face before I put it back on. The back tyre size 100/80 has front arrow and rear arrow as well. Should the front be facing forwards and the rear arrow be facing backwards on the rear? My front tyre has the rear arrow facing forward and the front arrow facing backwards. Here are pictures of the tyres.. This is on a CBR125 REPSOL 2006 with contigo tyreshttps://www.dropbox.com/s/shd9gx7w7pj23h4/20190605_205316.jpg?dl=0&fbclid=IwAR0cxIaIpy6CS0iWAK18skUR8x3YQFE5s3paWCl0aSsGDkC76OwAMEsy02Mhttps://www.dropbox.com/s/bu7pq3xbg08lx5i/20190605_205324.jpg?dl=0&fbclid=IwAR2eJTy9T2df7_Ny7VzbYdL06uiN7w87W29Wxx-VXGu1NhEwMPEGazVvCDUhttps://www.dropbox.com/s/75l02spdelnvriq/20190605_205331.jpg?dl=0&fbclid=IwAR3gqNFyNWtqB3-9JKkHk3YPBLnsVLooWbldaM-tlI7X7iakr7BM3VFjPlUThank you. Quote
Stu Posted June 5, 2019 Posted June 5, 2019 Hi and welcome to the forum I would follow the direction arrows thats on the tyre Quote
Gerontious Posted June 5, 2019 Posted June 5, 2019 The arrow is the direction of rotation of the wheel once its on the bike and the bike is moving forward. Thats really all you need to know. Quote
Mississippi Bullfrog Posted June 5, 2019 Posted June 5, 2019 When fitted the arrows should point the way the wheel will rotate as the bike is moving forwards. That covers the different forces the front and rear wheels are dealing with. Quote
Guest Richzx6r Posted June 5, 2019 Posted June 5, 2019 When fitted the arrows should point the way the wheel will rotate as the bike is moving forwards. That covers the different forces the front and rear wheels are dealing with. Didn't know we were on about jedi's I'll get my coat Quote
hussnainh8 Posted June 5, 2019 Author Posted June 5, 2019 HiThanks for your replies guys so the pattern for both tyres should be the same then? thats why i got confused becaused i read up that the pattern on the back tyre is opposite to the pattern on the front. When i saw both tyres pointing front i started worrying.Thank you. Quote
JRH Posted June 5, 2019 Posted June 5, 2019 Both tyres should NOT be pointing front.The arrows are rotational arrows. So the front tyre has the FRONT arrow pointing in the correct direction when the bike is moving. The rear tyre has the REAR arrow pointing in the correct direction when the bike is moving, ( eg towards the front of the bike). IE both arrows will be pointing to the front of the bike. Quote
hussnainh8 Posted June 5, 2019 Author Posted June 5, 2019 I can do the rear Tyre so the rear arrow faces the front which is the way the wheel moves however at the moment the front tyre has the rear arrow facing forwards.. Should I remove the wheel and turn it around and bolt it back on so the front arrow is facing forwards? Quote
hussnainh8 Posted June 5, 2019 Author Posted June 5, 2019 problem is i dont have just 1 arrow.. I have 2 .. one is left for rear and 1 is right for front ... so on both tyres.. The front arrows should be facing front ? Quote
Mississippi Bullfrog Posted June 6, 2019 Posted June 6, 2019 problem is i dont have just 1 arrow.. I have 2 .. one is left for rear and 1 is right for front ... so on both tyres.. The front arrows should be facing front ? No. The arrows point in the direction each wheel rotates as the bike moves forwards.The front wheel has the arrow marked front going in the direction of rotation, and the rear wheel has the arrow marked rear going in the direction of rotation.The tread patterns will then work according to the major forces each wheel is dealing with. Primarily the front does most of the braking force and the rear does the driving force.If you're not sure get a tyre fitter to do it for you Quote
JRH Posted June 6, 2019 Posted June 6, 2019 I can do the rear Tyre so the rear arrow faces the front which is the way the wheel moves however at the moment the front tyre has the rear arrow facing forwards.. Should I remove the wheel and turn it around and bolt it back on so the front arrow is facing forwards? You can’t just put the front wheel in so the tyre rotation is correct. You need to have the tyre fitted correctly.The wheel will only go in the one way, due to the disc brake. Quote
learningtofly Posted June 6, 2019 Posted June 6, 2019 Both tyres should NOT be pointing front.The arrows are rotational arrows. So the front tyre has the FRONT arrow pointing in the correct direction when the bike is moving. The rear tyre has the REAR arrow pointing in the correct direction when the bike is moving, ( eg towards the front of the bike). IE both arrows will be pointing to the front of the bike. That wasn't confusing at all Quote
JRH Posted June 6, 2019 Posted June 6, 2019 Both tyres should NOT be pointing front.The arrows are rotational arrows. So the front tyre has the FRONT arrow pointing in the correct direction when the bike is moving. The rear tyre has the REAR arrow pointing in the correct direction when the bike is moving, ( eg towards the front of the bike). IE both arrows will be pointing to the front of the bike. That wasn't confusing at all I know what I meant. You need to read the whole post not just the last sentence. Quote
JRH Posted June 6, 2019 Posted June 6, 2019 Both tyres should NOT be pointing front.The arrows are rotational arrows. So the front tyre has the FRONT arrow pointing in the correct direction when the bike is moving. The rear tyre has the REAR arrow pointing in the correct direction when the bike is moving, ( eg towards the front of the bike). IE both arrows will be pointing to the front of the bike. That wasn't confusing at all This better Quote
Mississippi Bullfrog Posted June 7, 2019 Posted June 7, 2019 I wish I could draw as well as that. Quote
Ross Posted June 20, 2019 Posted June 20, 2019 I assume if they have directional arrows thats they way they go...If no directional arrows maybe make an educated guess by the tread patternBut hey... you know what they say about assumption.... its the mother of all F**k ups, good luck Quote
fastbob Posted June 22, 2019 Posted June 22, 2019 What bike was it that was discussed on here ages ago where tyre fitters keep putting the back tyres on backwards due to the disk and sprocket being the opposite way round to previous models ? Was it a Triumph by any chance ? Quote
Mississippi Bullfrog Posted June 22, 2019 Posted June 22, 2019 What bike was it that was discussed on here ages ago where tyre fitters keep putting the back tyres on backwards due to the disk and sprocket being the opposite way round to previous models ? Was it a Triumph by any chance ? I think it was, due to Triumph keeping the traditional fitting of the chain on the right side of the bike.(You see what I did there?) Quote
krahang Posted May 13, 2024 Posted May 13, 2024 Apologies for resurrecting an old thread. It is on the first page of Google search for motorcycle tyre arrows, I wish to help others by posting an answer. If the tyre has 2 arrows pointing to different directions, and one arrow is marked FRONT and another REAR, it means that the tyre can be installed on either the front or the rear wheel of the motorcycle. It is very common for small scooters and underbones to have front and rear tyres almost the same size, hence small tyres are often 'universal'. FRONT and REAR mean Front Tyre and Rear Tyre. They DO NOT mean front and rear of the same tyre - this is where the confusion comes from. As others mentioned, the thread pattern is usually inverted for front and rear tyres and it is completely normal. For the front wheel, the FRONT arrow should follow wheel rotation when moving the motorcycle forward. For the rear wheel, the REAR arrow should follow wheel rotation when moving the motorcycle forward. Hope it helps someone. 2 Quote
RideWithStyles Posted May 13, 2024 Posted May 13, 2024 (edited) w Edited May 14, 2024 by RideWithStyles Quote
Nick the wanderer Posted May 14, 2024 Posted May 14, 2024 13 hours ago, RideWithStyles said: why bother resurrected a very old thread? anyway simple as follow the bloody arrow to the front of the bike no matter simple as... You got a grump on you mardy sod, read what he says, some tyres can be used in both directions depending whether front or back use. 1 Quote
krahang Posted May 15, 2024 Posted May 15, 2024 Correct, the original question reads, 'The back tyre size 100/80 has front arrow and rear arrow as well. Should the front be facing forwards and the rear arrow be facing backwards on the rear?' This page is the top of Google search if someone asks the same question, so I tried to give a clear answer: REAR and FRONT means which wheel the tyre is on, then the corresponding arrow should rotate forward. Quote
Bender Posted May 15, 2024 Posted May 15, 2024 Front and rear have different requirements, front handles braking rear gives traction, tyres are marked to do the best depending on if it's on front or rear, hence 2 arrows if it's a size that can be used either end 1 Quote
Mississippi Bullfrog Posted May 16, 2024 Posted May 16, 2024 So far everyone has got this wrong. It is very very simple. At all times your tyres should be facing down. If they are facing the sky you have crashed. 1 7 Quote
