ThePhatomfart Posted March 14, 2020 Posted March 14, 2020 Took the tyre's off so the rims could be paint stripped, Fireblade 929
dern Posted March 14, 2020 Posted March 14, 2020 Haven't done anything in the bike for some time due to a ripped tendon in my shoulder. Felt better this week so thought I'd start with something easy and would fit done indicators I got off eBay. Ended up taking bloody ages and having to dismantle half the bike. Anyway, happy with the result and the shoulder still works.Front indicators work as running lights when not indicating... Rear indicators act as extra brake lights when not indicating... CheersMark
Snod Blatter Posted March 15, 2020 Posted March 15, 2020 So, the leaky radiator. Remove ridiculous and unnecessary shoulder pad plastics:https://i.imgur.com/5CpNY5U.jpg' alt='IMGUR>'>Remove unnecessary belly pan and move bracket for unnecessary belly pan which happens to be RIGHT IN THE WAY of the coolant drain bolt https://i.imgur.com/MPT1F8J.jpg' alt='IMGUR>'>Drain the tea from the systemhttps://i.imgur.com/LXeBC3H.jpg' alt='IMGUR>'>Honestly I've never seen coolant look like this.Old one on the left, less old one on the right..https://i.imgur.com/LvQQIgE.jpg' alt='IMGUR>'>Installation is the reverse of removal. Fill with much more delicious looking liquid:https://i.imgur.com/YOQScs8.jpg' alt='IMGUR>'>Start 'er up and run until the fan comes on, no leaks means a job well done. Mechanicing is so easy sometimes.Get a new bike they said. You won't have to fix it all the time they said. Mehhhhh!! Now I just have to hope that the coolant hadn't turned to tea because it's full of exhaust gas..
Guest Posted March 15, 2020 Posted March 15, 2020 Just had the last ride as lockdown comes into effect tomorrow for at least 15 days! So I couldn't put the Strom away dirty!
Bianco2564 Posted March 15, 2020 Posted March 15, 2020 Washed about half an inch of mud off the Silverwing.280 miles a week up and down the A45 & A361 soon cake it in crap.
Guest Posted March 15, 2020 Posted March 15, 2020 https://www.themotorbikeforum.co.uk/viewtopic.php?f=23&t=72124
Bender Posted March 15, 2020 Posted March 15, 2020 Eventually got round to wiring in a relay for USB socket.
James in Brum Posted March 15, 2020 Posted March 15, 2020 I have removed a stator and wired in new one I have mended the rear brake light switch which had been a do later job. It’s seems like such a little thing written down but seems like a really big deal to me. I need an extension bar and some penetrating spray so that I can loosen the rear axle nuts so I can tension my chain. I will look to replace the chain in May I think.
Bender Posted March 15, 2020 Posted March 15, 2020 Can they work in the rain? The USB is waterproof with cover on, relay is going to be tucked up under side plastic, I think given the position of the socket rain shouldn't be an issue while riding if it was needed.
Guest Posted March 15, 2020 Posted March 15, 2020 Can they work in the rain? The USB is waterproof with cover on, relay is going to be tucked up under side plastic, I think given the position of the socket rain shouldn't be an issue while riding if it was needed. You've got a bike [mention]Bender[/mention]? Why isn't it listed on your profile? Not Chinese is it?
Bender Posted March 15, 2020 Posted March 15, 2020 Can they work in the rain? The USB is waterproof with cover on, relay is going to be tucked up under side plastic, I think given the position of the socket rain shouldn't be an issue while riding if it was needed. You've got a bike @Bender? Why isn't it listed on your profile? Not Chinese is it?Chinese really.....
Guest Posted March 15, 2020 Posted March 15, 2020 Fazer.......good choice!Maybe you're not the knuckle dragging bellend that I thought you were?Of course if you want any credibility we'll need to see some Ride Reports!And no......that doesn't apply in your case [mention]dynax[/mention].
James in Brum Posted March 17, 2020 Posted March 17, 2020 Two days of commuting later and having had to have a couple of weeks away from the bike I love it! Dry roads less traffic and all the pride that comes with having mended it! [mention]Stu[/mention] i will drop some dosh in the forum coffers after payday as a little thanks for the forum.I bloomin love it!
Older biker Posted March 18, 2020 Posted March 18, 2020 Reattached the now silver sparkle powder coated pillion grab rail to the F800st.It had suffered somewhat from having the Givi topbox bracket on top of it, flaked and grotty. Now as good as new if not better.
boboneleg Posted March 19, 2020 Posted March 19, 2020 Just had the last ride as lockdown comes into effect tomorrow for at least 15 days! So I couldn't put the Strom away dirty! I hope you cleaned those downpipes
Guest Posted March 19, 2020 Posted March 19, 2020 Just had the last ride as lockdown comes into effect tomorrow for at least 15 days! So I couldn't put the Strom away dirty! I hope you cleaned those downpipes
S-Westerly Posted March 19, 2020 Posted March 19, 2020 Unwrapped the bike from its winter Woolies. Happy to find it started first time and ran up to temperature without any hiccups. Had to top up the air in the tyres and now all set for a run south from Teesdale to Gloucestershire on Saturday. Weather permitting I'll take the scenic route via Sedbergh and Kirkby Lonsdale then past the hell hole of Liverpool/Manchester into the Welsh borders and on to Gloucester. If it's crap I'll go via the A1M and Coventry then Stow and home.
Guest Posted March 20, 2020 Posted March 20, 2020 Polishing shit that didn't need polishing basically! I guess this is what is called CORVID-19 Blues!
dynax Posted March 20, 2020 Posted March 20, 2020 Went out on Xena this afternoon had go pick up a prescription, then went for a ride to get some beans, the supermarket had sold out so i ended up going to the Forest of Beans, luckily there were a couple of young tins in the undergrowth so both Xena and Bridget have a small tin of beans each to keep them going The Forest of Beans. Duly collected ready to take home,
Guest Posted March 20, 2020 Posted March 20, 2020 Completely f@cking barking!I think even [mention]Six30[/mention] is on the verge of flouncing!
S-Westerly Posted March 20, 2020 Posted March 20, 2020 Its nice to see that even Xtreme can be trolled. Makes me feel all warm and fuzzy in this time of shite.
Stu Posted March 20, 2020 Posted March 20, 2020 Not today but Wednesday I actually rode it!! bit of an achievement after been on sick for 9 weeks and counting! Managed to test my new textiles I have had for about 4 months! Which are lovely and warm
