Ehcbr125 Posted October 11, 2020 Share Posted October 11, 2020 Hi guys, it’s me again! So I live on private land so have been lucky enough that I have a small road that I can ride around, I started off on a 650cc so riding a 125cc was alien to me! Anyway long story short both me and partner feel like it doesn’t have the pull that it should (Honda CBR125R 06) my partner had the same bike and same model and could easily pop a wheelie in gear 1. With my bike there would be no danger of that. It’s not that I want to pop wheelies because I don’t, I just want the bike to run as it should. It maybe due a service which I plan to do next month but I wondered if you guys knew if that could be the problem or it could be something else. The previous owner removed the baffle from the sports exhaust and I wondered if that could be a contributing problem. Thanks in advance for any help or advice Quote Link to comment Share on other sites More sharing options...
skyrider Posted October 11, 2020 Share Posted October 11, 2020 Hi how long ago was it last serviced and how many miles have you done since Quote Link to comment Share on other sites More sharing options...
Ehcbr125 Posted October 11, 2020 Author Share Posted October 11, 2020 Hi how long ago was it last serviced and how many miles have you done since I only got it at the beginning of the month and the guy didn’t speak much English. But the oil is still good. It’s starts on the button every time with no worries so don’t think it’s carb related. Point is though I don’t actually know when a service was last done. It wouldn’t have done many miles though as only 11,000 miles on the clock. Last MOT was a year ago and it’s only done a few miles since then Quote Link to comment Share on other sites More sharing options...
James in Brum Posted October 12, 2020 Share Posted October 12, 2020 125’s really don’t have much power. Another question to think about is how much do you weigh (no need to answer this here ) Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 12, 2020 Share Posted October 12, 2020 Check the obvious, plug, air filter - but my guess is that if the exhaust has been messed with that will reduce the power particularly at the low end. Quote Link to comment Share on other sites More sharing options...
dynax Posted October 12, 2020 Share Posted October 12, 2020 Have the sprockets been changed, they are often changed from stock sacrificing low end torque for higher speed Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 12, 2020 Share Posted October 12, 2020 Have the sprockets been changed, they are often changed from stock sacrificing low end torque for higher speed Very true - you often see this done, but on a small engine it is a waste of time as the engine doesn't have enough grunt to hold the higher gearing anyway. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 12, 2020 Share Posted October 12, 2020 My rule is that when I buy a second hand bike NEVER believe a word anyone says about the oil and ALWAYS change it , and the filter , at the very first opportunity . Quote Link to comment Share on other sites More sharing options...
Ehcbr125 Posted October 15, 2020 Author Share Posted October 15, 2020 125’s really don’t have much power. Another question to think about is how much do you weigh (no need to answer this here ) I’m 5’2” and weigh 8 stone so it’s not that I’m aware they don’t have much power and I don’t know a lot but I know it doesn’t run as it should Quote Link to comment Share on other sites More sharing options...
Ehcbr125 Posted October 15, 2020 Author Share Posted October 15, 2020 Thanks for all your replies. I will get the service done and change the chain and sprockets and see how I go. Thanks again Quote Link to comment Share on other sites More sharing options...
