So the OEM heated grips died on the Tiger Explorer after a whisker under 12 months and 10,000 miles of mostly not being switched on. The seller sent a warranty request to Triumph who don't want to know. Partly because they didn't fit them; partly because they're end of line.
First world problems. 🌍
So I could go with Oxford hotgrips as a replacement, but wondered if there was anything out there that could re-use the 2 setting illuminated existing switch.
Any ideas?
Posted (edited)
That's pretty poor service from Triumph. They were on my list of bikes but I needed a step ladder to mount. Glad about that.
Edited by S-Westerly
My suggestion if your looking for Subtle control for the grips:
Heated Grips
Paired with these:
Grip covers
I know cheap and cheerful but they work and I have had one set fail after 6 years.
Yes they dont get supper hot, but they have always kept my hands warm.
I haven't got a scooby about utilising the control, after my luck with the last couple of bikes, my option now, is heated gloves, more faffery, but can use on more than one bike. :-D
Posted (edited)
Any ideas?
Doubtful. this has been a question asked for years by owners of the Africa Twin. as it's been quite hit and miss for people how effective the OEM heated grips are. not only do they want to replace them with some that use the same indicator lights and switch on the LHS handlebar, they also want some that will use the level setting tell tale on the display. But, Ive never seen a satisfactory answer that solves even one of those - let alone two. usually people resort to removing the OEM grips and replacing them completely. or using the heated wraps that are available.
Heated grips on mine are at best 'adequate'. they're not impressive. However I seldom need to use them as I spent on really good gloves rather than fret over the grips.
Personally, I think the issue with grips that dont get super hot is down to inadequate insulation between the element and the metal of the handlebars, so instead of the heat being pushed outwards its absorbed and channeled away by the cold metal underneath. total failure is another story.
Edited by Gerontious
  • Like 3
Any ideas?
Could you find out who manufactures the OEM?
They're not likely to be made by Triumph, maybe it's known brand.
5 hours ago, rennie said:
I still haven't sourced a replacement switch cover for mine
Might be worthwhile sending this seller a message. see if the ones he produces by 3d printing will fit your particular bike. he does mention a change in design in the description if the photos on the page doesn't quite match yours.  https://www.ebay.co.uk/itm/225002176840
  • Thanks 1
Posted (edited)
The throttle side on my OE Yam died and got replaced with the Ultimate Addons grips. Not bad after a few mins to warm up, and not to mention no stupid extra controller box having to be mounted on the handlebars
Edited by Fish
Another question on heated grips (never had them on a bike before) - can you add grip puppies over them?
Yes you can sir. They seem to work fine on mine; perhaps takes a couple of minutes longer to heat up.
  • Thanks 1
Yes, they take a little longer to warm up but do retain the heat a little better
  • Thanks 1
58 minutes ago, onesea said:
As above yes no problems, tip for putting grip puppies on.
Compressed air, electric paddles board pump, or dinghy pump.
I can recommend these for 1/5 the price.
Grip puppies direct from China.
Don't buy from China if I can help it although chances are ones I buy here are made in China.  Not expensive though.
