onesea Posted January 27 Share Posted January 27 Not disposable of course, although they all tend to have a shelf life. I have tried various and have found the pod system work best for me. No coils to change no seals to leak, I tend to have 2 on the go my present ones have been great. Until I discovered what for me is a significant fault. When sailing randomly the auto pilot would randomly throw its hand in. At random times, it would not steer or just not be quite right. It’s taken me months to work out the fault @S-Westerly will be mumbling into his Sowester . My vapes are magnetic, one of them massively so at 1m it can cause 10 or 20 degree deviation in heading. So stepping past the compass or standing near it vaping caused chaos (nearly as embarrassing as the magnetic travel chess board). It was only when I was standing in front of the digital display vaping, trying to find the fault did I put 2 and 2 together So does anyone know of a non magnetic Pod Vape? Or can recommend a non magnetic Pod Vape. Presently I have and was quite happy with: Voopoo - Argus Z - massively magnetic, Aspire - Geotek - Not so magnetic, much more subtle, 1 Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted January 27 Share Posted January 27 One of the reasons my company bans them from ships. Quote Link to comment Share on other sites More sharing options...
husoi Posted January 27 Share Posted January 27 How about stop smoking all together? 2 Quote Link to comment Share on other sites More sharing options...
rightstuff Posted January 28 Share Posted January 28 Not only vapes find if my usb charger is plugged in on my boat cuts the fm radio out also auto pilot Also if usb charger is plugged into van loose radio signal Quote Link to comment Share on other sites More sharing options...
husoi Posted January 28 Share Posted January 28 So basically, your radio signal goes out in smoke... Quote Link to comment Share on other sites More sharing options...
onesea Posted January 28 Author Share Posted January 28 6 hours ago, rightstuff said: Not only vapes find if my usb charger is plugged in on my boat cuts the fm radio out also auto pilot Also if usb charger is plugged into van loose radio signal There USB Chargers that stop that, they are not normally cheap from China. Apparently it’s to do with the electrical noise made changing voltages. Some one clever will be along to advice. Quote Link to comment Share on other sites More sharing options...
Old-codger Posted January 28 Share Posted January 28 Just a suggestion for modern day problems!!!!! could you not take up smoking again at least you wouldnt go off coarse then. 1 1 Quote Link to comment Share on other sites More sharing options...
Tiggie Posted January 28 Share Posted January 28 3 hours ago, onesea said: Some one clever will be along to advice Quote Link to comment Share on other sites More sharing options...
Mawsley Posted February 15 Share Posted February 15 Genuinely never come across this as a problem - and I’ve been covering harm reduction products since 2011! I’m being sent some samples of unit construction pods (three separate components, used recycled materials in construction), I’ll update if they are magnet free. Not aware of anything on the market that doesn’t use magnets. Quote Link to comment Share on other sites More sharing options...
Mawsley Posted February 16 Share Posted February 16 Strike that one off then - these have magnets for days Quote Link to comment Share on other sites More sharing options...
