Simon Davey Posted February 21 Share Posted February 21 I used to sell, crash, or end up with a girlfriend that doesn't like bikes, before it needed doing, but.......... Is there a particular method for cleaning the radiator and oil cooler? Mine are clogged with dirt, but those fins look delicate. Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted February 21 Share Posted February 21 I've always just hosed them but on a low pressure. 1 Quote Link to comment Share on other sites More sharing options...
Fiddlesticks Posted February 21 Share Posted February 21 Same. Better to hose it from behind, so you're not forcing crud further in. 1 1 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted February 21 Author Share Posted February 21 Thanks guys, they're looking a bit crusty, maybe I should spray-soak them with a citric acid solution (nothing nasty), then rinse from behind. Cheers Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted February 21 Share Posted February 21 simple- a very fine brush / toothbrush, tweezers and a hand spray bottle. 1 1 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted February 21 Author Share Posted February 21 A tooth brush would be perfect, why didn't I think of that! Cheers 1 Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted March 9 Share Posted March 9 Snow foam works really well 1 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted March 9 Author Share Posted March 9 5 minutes ago, Chrissb6 said: Snow foam works really well Thanks but, I should have mentioned it's indoor cleaning Quote Link to comment Share on other sites More sharing options...
husoi Posted March 10 Share Posted March 10 @Bender will tell you to put it in the dishwasher I'm strongly considering to get a cheap second hand one for the garage. 1 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted March 10 Author Share Posted March 10 1 hour ago, husoi said: @Bender will tell you to put it in the dishwasher I'm strongly considering to get a cheap second hand one for the garage. Dishwasher, or toothbrush? Quote Link to comment Share on other sites More sharing options...
husoi Posted March 10 Share Posted March 10 2 hours ago, Simon Davey said: Dishwasher, or toothbrush? Definitely dishwasher Couple years ago I did a refurbishment on the radiator of the pan. Hose it up with only a bit of pressure, then patiently straighten the fins and give it a good temperature resistant black paint after removing all oxide Still going strong since then. It takes time but worth the trouble 1 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted March 10 Share Posted March 10 5 hours ago, husoi said: @Bender will tell you to put it in the dishwasher I'm strongly considering to get a cheap second hand one for the garage. I have an old dishwasher in the garage. It's just a bit of pain getting the plumbing in. 2 Quote Link to comment Share on other sites More sharing options...
Bender Posted March 10 Share Posted March 10 8 hours ago, husoi said: @Bender will tell you to put it in the dishwasher I'm strongly considering to get a cheap second hand one for the garage. Tin Of wd40 or any other oil as things start to rust pretty quick afterwards, quick squirt and a rub down works wonders 1 1 1 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted March 10 Author Share Posted March 10 1 hour ago, Bender said: Tin Of wd40 or any other oil as things start to rust pretty quick afterwards, quick squirt and a rub down works wonders I fear I may have missed something 2 Quote Link to comment Share on other sites More sharing options...
