Simon Davey Posted May 22, 2024 Posted May 22, 2024 1 hour ago, peepae said: Service done at BMW dealer - they did a further check - Front brake pads need replacing - Headraces very notchy so also need replacing Will go to the local for that as they are wanting to charge me 192 to replace front brake pads and 300 for the headraces. Jeeeeeezus, that's disgusting, so much for me thinking you took it to the right place. Pads take 5 minutes to replace, but admittedly, headrace bearings are a bit of a job. When you take it to the local, don't ask him to do it, but ask him for his opinion. 3 Quote
peepae Posted May 22, 2024 Posted May 22, 2024 1 minute ago, Simon Davey said: Jeeeeeezus, that's disgusting, so much for me thinking you took it to the right place. Pads take 5 minutes to replace, but admittedly, headrace bearings are a bit of a job. When you take it to the local, don't ask him to do it, but ask him for his opinion. That’s what I was thinking lol, I just posted a thread with the actual notchiness and it does look pretty bad look at this for the rear ones too: 1 Quote
Gerontious Posted May 22, 2024 Posted May 22, 2024 (edited) Bike started immediately. Tyre pressures are fine. And made it here with barely a wobble Edited May 22, 2024 by Gerontious 5 Quote
RideWithStyles Posted May 22, 2024 Posted May 22, 2024 2 minutes ago, Simon Davey said: Jeeeeeezus, that's disgusting, so much for me thinking you took it to the right place. Pads take 5 minutes to replace, but admittedly, headrace bearings are a bit of a job. When you take it to the local, don't ask him to do it, but ask him for his opinion. agree with SD. sometimes they dont actually need replacing, just releasing(loosen) the tension on them and other ones then reset and tightening up again. 1 Quote
Gerontious Posted May 22, 2024 Posted May 22, 2024 There is an ancient Eskimo proverb, written on whatever it is they write on up there “Man with big feet have feet touching peddle get warped disc” Those eskimos know a thing or two. Mot passed. 1 advisory. Slight warp. So… need to move the peddle downward. As and when it’s not so wet. And it’s very wet. So wet it’s beyond moist. im actually happy about this. I was fearful of something nasty lurking ready to pounce and ruin my day. A big bill is not what I need right now. So. Insurance - check. MOT - check And in the nick of time too. Only 102 days till the Eifel. Not that I’m counting, though as everyone knows that equals 14 weeks and 4 days precisely. (Obviously) 3 1 Quote
RideWithStyles Posted May 22, 2024 Posted May 22, 2024 ill assume its the front your referring to? first level of warping is more likely from the buttons and the connection faces due to crap/corrosion disc built up. later levels are poor brake maintenance, poor service, button failure.... not from toprak levels of antics, though wearing will be. Brake cleaner, toothbrush, fine pick, air line if possible. Quote
Simon Davey Posted May 22, 2024 Posted May 22, 2024 Nice result @Gerontious Good that you know some eskimo proverbs, they'll probably be useful come 1st week of September. Quote
Throttled Posted May 22, 2024 Posted May 22, 2024 MOT, no advisories. I have done 1,708 miles over the past 12 months. 3 Quote
Stu Posted May 22, 2024 Author Posted May 22, 2024 Need to get mine booked in for mot! Runs out next month! Just to make @Throttled feel bad I will be looking at about 6k between mots 2 Quote
Mississippi Bullfrog Posted May 23, 2024 Posted May 23, 2024 20 hours ago, peepae said: Service done at BMW dealer - they did a further check - Front brake pads need replacing - Headraces very notchy so also need replacing Will go to the local for that as they are wanting to charge me 192 to replace front brake pads and 300 for the headraces. That's mad. The head bearings need some dismantling to get at them but the front pads are a 10 minute job. Just looked at your video....they need doing but when you get the races out you'll find the pitting will be tiny. I'll bet you haven't even noticed when riding the bike, it only looks so bad because the front wheel is floating free. 1 1 Quote
S-Westerly Posted May 23, 2024 Posted May 23, 2024 Found the dreaded V100 coolant leak so took it in to local dealer who has promised to get it sorted by tomorrow evening. Need it for Saturday so here's hoping. Guzzi forums are full of this issue so not a surprise but as I'd made it to 3000 miles I thought I'd dodged the bullet. Hey ho..... 5 Quote
Throttled Posted May 23, 2024 Posted May 23, 2024 20 hours ago, Stu said: Need to get mine booked in for mot! Runs out next month! Just to make @Throttled feel bad I will be looking at about 6k between mots I am surprised it is under 2k. That distance included trips to the Isle of Lewis, Isle of Man, Dingwall, numerous challenge tags and use most weeks of the year. Quote
Stu Posted May 23, 2024 Author Posted May 23, 2024 2 hours ago, Throttled said: I am surprised it is under 2k. That distance included trips to the Isle of Lewis, Isle of Man, Dingwall, numerous challenge tags and use most weeks of the year. Yeah I was shocked at your low mileage to be honest! You usually get about a fair bit Quote
Nick the wanderer Posted May 24, 2024 Posted May 24, 2024 Ditto the mileage thing, I'd be looking at my speedo and scratching my chin. In a way it's good for keeping your mileage low as a positive spin but then worrying if it's not working quite right. Quote
Mississippi Bullfrog Posted May 24, 2024 Posted May 24, 2024 Oil changes for both bikes. The Bobber takes 3.4 litres with the oil level bang in the middle of the sight glass. The CBF says it takes 3.1 litres but if you put that much in the oil level is only just touching the bottom of the dipstick. 3.3 litres takes it halfway up the dipstick. I've never figured that one out. Quote
JRH Posted May 24, 2024 Posted May 24, 2024 1 hour ago, Mississippi Bullfrog said: Oil changes for both bikes. The Bobber takes 3.4 litres with the oil level bang in the middle of the sight glass. The CBF says it takes 3.1 litres but if you put that much in the oil level is only just touching the bottom of the dipstick. 3.3 litres takes it halfway up the dipstick. I've never figured that one out. Is 3.3 litres if no oil filter changed. My bike gives 2 oil values. Oil change only and oil and filter change. Quote
RideWithStyles Posted May 24, 2024 Posted May 24, 2024 (edited) also the lower engines inside are tapered and not square (every engine is different btw) so fills it up little (at this point not as much internals filling the space) but hiher up is squarer and wider but space is filled up more with parts so little oil now will fill the window space very easily. Edited May 24, 2024 by RideWithStyles Quote
Mississippi Bullfrog Posted May 24, 2024 Posted May 24, 2024 2 hours ago, JRH said: Is 3.3 litres if no oil filter changed. My bike gives 2 oil values. Oil change only and oil and filter change. The book (and every online source I can find) says 2.9 for oil only, and 3.1 for oil and filter. I always change both. I prefilled the filter and still added 3.1 litres, and that was just showing at the very bottom of the dipstick. 1 Quote
peepae Posted May 24, 2024 Posted May 24, 2024 Not with or on but - I bought the tyres which were replaced - I put S rated metzeler tourance fron tyre on there. (v rear one) I see they also sold H rated ones but they were out of stock - other than the difference in speed (112 vs 130 or so) what is the difference between these tyres... and I am likely to have a front tyre blowout at above 113 MPH Quote
Throttled Posted May 24, 2024 Posted May 24, 2024 (edited) 20 hours ago, Stu said: Yeah I was shocked at your low mileage to be honest! You usually get about a fair bit Lewis was about 700 miles, the IOM was about 550 miles and Dingwall also about 550 miles, total 1800, so the MOT cannot be right as it was less than that. Need to do some checking. Edit - I used "mileage history figures" but the mileage for the 2023 MOT was 8,411 and a few days ago for the 2024 MOT it was 11,524, so 3,113 miles over the past year. The 1,708 was the mileage 2022-23, and it was 1,183 for 2021-22, when there was no touring at all and the pandemic was restricting use. Edited May 24, 2024 by Throttled 1 Quote
JRH Posted May 24, 2024 Posted May 24, 2024 2 hours ago, peepae said: Not with or on but - I bought the tyres which were replaced - I put S rated metzeler tourance fron tyre on there. (v rear one) I see they also sold H rated ones but they were out of stock - other than the difference in speed (112 vs 130 or so) what is the difference between these tyres... and I am likely to have a front tyre blowout at above 113 MPH In the most extreme case it may fail at speed in excess of its rating, but more importantly it may invalidate your insurance in the event of an accident/ claim. 1 Quote
RideWithStyles Posted May 24, 2024 Posted May 24, 2024 (edited) 6 hours ago, peepae said: Not with or on but - I bought the tyres which were replaced - I put S rated metzeler tourance fron tyre on there. (v rear one) I see they also sold H rated ones but they were out of stock - other than the difference in speed (112 vs 130 or so) what is the difference between these tyres... and I am likely to have a front tyre blowout at above 113 MPH it s not just blow outs but delaminating, degrade, unstableness etc. theoretically and splitting hairs yes..as unpopular and people will whine about , your putting more pressure on a tyre that wasn't designed to do that speed but as usual depending what that bracket of reference the manufacturer is basing it on to come up with that spec? what Was the bike, load and weight distribution, tyre pressures, temperature, corners speeds yada yada yada, then plus abit more for varying conditions. unless your doing a wanna go to long prison risk session, track day, autobann it's unlikely. Edited May 24, 2024 by RideWithStyles 1 Quote
S-Westerly Posted May 25, 2024 Posted May 25, 2024 Are you actually going to exceed 112 mph ever? If you don't the tyre itself will perform as expected. 3 1 Quote
S-Westerly Posted May 25, 2024 Posted May 25, 2024 On 23/05/2024 at 12:00, S-Westerly said: Found the dreaded V100 coolant leak so took it in to local dealer who has promised to get it sorted by tomorrow evening. Need it for Saturday so here's hoping. Guzzi forums are full of this issue so not a surprise but as I'd made it to 3000 miles I thought I'd dodged the bullet. Hey ho..... Well a mixed bag of a day. No problem with the cooling system so a win there. Couldn't get it ready until lunchtime today so instead of leaving at 0900 and having an interesting ride north it will be 0400 tomorrow and a thrash up the motorway. Loss here. Next loss is there is a problem but according to Guzzi rep its a minor issue and bike will be good for the summer. However to fix the issue is a major dismantle of the engine so a big job (warranty). Frasers, who have been very good, have proposed I drop the bike in to them prior to my going back to sea and they'll then sort it out while I am away. Sounds a reasonable plan to me. Not entirely sure what the issue is other than it involves an oil mist (?). Oil levels are fine. As its under warranty if the whole thing blows up it's covered anyway so I'll enjoy - with caution. 3 2 Quote
