bonio Posted May 3 Posted May 3 15 hours ago, veracocha said: Returned it to showroom condition. Six hours of washing/scrubbing/detailing ready for selling. I realise that it's just too big a bike for me and I don't feel confident when coming to stops. In Scotland last week I took a tumble whist stationary and that helped secured my decision to sell. I had a Tracer 7GT before moving onto the F900 XR and I was sure footed with that being a much smaller, lighter bike. Shame as I like the bike very much. That a shame mate. If you like it that much, have you thought about fitting lowering links? Or perhaps you've already got your eye on something to replace it with? 1 Quote
veracocha Posted May 4 Posted May 4 8 hours ago, bonio said: That a shame mate. If you like it that much, have you thought about fitting lowering links? Or perhaps you've already got your eye on something to replace it with? I have thought about fitting a Touratech lowering kit (front & rear) springs for £250 which will get me flat footed however the weight is a consideration also. 196kg vs 220Kg might not sound much but lugging the bike around the yard you feel the difference. I might go back to a Tracer 7GT; I really liked that bike and without doubt, a comfier ride than the BMW. 3 Quote
Bianco2564 Posted May 5 Posted May 5 Stripped and repainted the rear subframe on the RGV. Fitted it back to the frame and started reattaching everything; oil tank, coolant reservoir,cdi box, battery box, loom. 5 Quote
bud Posted May 6 Posted May 6 (edited) I've had a slow leak from the front tyre for a while now. It will lose 5-6 psi in a week. I could never see anything piercing the tyre. So today I removed the wheel and found it leaking from the rim. Broke the bead, cleaned and inflated again. There did seem to be a small amount of corrosion inside the rim. It doesn't seem to be leaking now. Fingers crossed. Edited May 6 by bud 4 Quote
Simon Davey Posted May 6 Posted May 6 (edited) 1 hour ago, bud said: I've had a slow leak from the front tyre for a while now. It will lose 5-6 psi in a week. I could never see anything piercing the tyre. So today I removed the wheel and found it leaking from the rim. Broke the bead, cleaned and inflated again. There did seem to be a small amount of corrosion inside the rim. It doesn't seem to be leaking now. Fingers crossed. I feel your pain. I had this issue for months, and months, even on holiday I had to inflate every morning as I was losing 3-4 PSI per day. Proper mechanic looked at it and called me, he says, "when they fitted those new tyres Simon, they ignored the valve seats"..... That's all it was, nine months of thinking I had corroded alloys leaking air, and all it needed was for the valves to be removed, the valve seat in the rim cleaned up, and new valves fitted. Edited May 6 by Simon Davey 3 Quote
Mickly Posted May 6 Posted May 6 Gave the KTM some love before a weekend at Motojunkies, starting with an oil change, don’t know when it was last done, the magnetic drain plug didn’t have any debris on it & the strainer was clean, the oil was very black. created a chute for the oil with some foil to stop it coating the stand. 2 Quote
Mickly Posted May 7 Posted May 7 17 minutes ago, RideWithStyles said: Nice. Think the chain could do with some loving Indeed it does & I will be giving a good seeing to later today, it’s gagging for it the dirty thing 1 3 Quote
Mickly Posted May 7 Posted May 7 This afternoon the KTM chain got a good going over. First gave the area adjacent to the action a quick wipe down Then gave the chain it a good scrubbing with a wire brush to remove most of the caked on crud and wiped it down I then used this, I won it in a raffle Here is the result after about an hour, a clwan lubed chain that no longer has a grindy sound when spinning the wheel. Just need to fill it with oil & it’s ready to go 9 Quote
Mickly Posted May 7 Posted May 7 Oh No !! Luckily this is not all it seems, It’s the first time I’ve ever seen this in a workshop manual.. Any how, it’s all done now and ready to rock at Motojunkies tomorrow 3 3 Quote
bonio Posted May 8 Posted May 8 Changed the oil on the MV. So nice to have slickety-click gear changes again 3 Quote
Essexboy Posted May 9 Posted May 9 11 hours ago, bonio said: Changed the oil on the MV. So nice to have slickety-click gear changes again We'll make an engineer of you yet 🏍 1 Quote
S-Westerly Posted May 9 Posted May 9 4 hours ago, Essexboy said: We'll make an engineer of you yet 🏍 Don't be rude 6 Quote
Mississippi Bullfrog Posted May 9 Posted May 9 I fitted a pair of iridium spark plugs to the Bobber. I'm very pleased with the result. Acceleration is crisper and smoother. I put a pair in the CBF a couple of years ago and they have been very good. 5 Quote
V650 Posted May 10 Posted May 10 16 hours ago, Mississippi Bullfrog said: I put a pair in the CBF a couple of years ago and they have been very good. Did you need to remove the tank on the CBF500 for the plugs I replaced mine with Iridium on the 500X as it is such a pain to do the plugs Quote
Mississippi Bullfrog Posted May 10 Posted May 10 6 minutes ago, V650 said: Did you need to remove the tank on the CBF500 for the plugs I replaced mine with Iridium on the 500X as it is such a pain to do the plugs I removed the tank, it's not difficult and makes access much easier. 1 Quote
V650 Posted May 10 Posted May 10 3 minutes ago, Mississippi Bullfrog said: I removed the tank, it's not difficult and makes access much easier. Good opportunity to get under there and do a bit of cleaning oiling and preventative maintenance while your there The 500X is such a pain to remove the fairings and tank Quote
S-Westerly Posted May 10 Posted May 10 Spent £180 at Evotech on bobbins and shiny bolts. Must be bloody mad. Can only blame having the trots, must have crapped my brains out as well as everything else. 1 4 Quote
Mickly Posted May 11 Posted May 11 On 10/05/2025 at 11:03, Throttled said: Fitted a sissy bar. You gonna tell your pillion that they’re a sissy? 3 Quote
RideWithStyles Posted May 11 Posted May 11 Better than nothing….but if I was being amusing or a woman way of thinking the back rest is smaller than the seat…you saying they got a fat arse??? 1 Quote
Bianco2564 Posted May 11 Posted May 11 Stripped and repainted the RGV exhausts. I found one of them was totally corroded through, unfortunately this was after an hour or so wire brushing the rest of it before I spotted it. Fortunately I have a spare set of pipes in picked up at Newark some years ago, £10 well spent. 7 Quote
Throttled Posted May 12 Posted May 12 16 hours ago, Mickly said: You gonna tell your pillion that they’re a sissy? It is what the maker calls it. I would have called it a backrest. My son is the main user. 2 Quote
Tinkicker Posted May 17 Posted May 17 (edited) The missus is not working this weekend and announced that it is time for her to partake in the inaugural ride of the season, in particular a ride to Breighton airfield ( she loves the vibe there as much as I, glad I ended up married to an outdoorsy, tomboy type female, not one interested in makeup, fashion and glamour). As a result, my single days are over for the season. I have just removed the single seat cowl, refitted the rear grab handles and I am now a married rider again. Complete with a pair of ever critical eyes watching my every riding decision from the pillion. Just kidding, I far prefer her perched on the back keeping me company than riding with a group of others. Single biker. Married biker now with space for the quick thump to the kidneys dispenser. Edited May 17 by Tinkicker 5 Quote
