Slowlycatchymonkey Posted January 15, 2021 Share Posted January 15, 2021 Stopped at some traffic lights and smell burning, persuade self it’s not my bike and ride on. Stop at next set of lights, definitely is my bike I think maybe the back brake is sticking. How do I check if that’s it and what do I do if it is? Quote Link to comment Share on other sites More sharing options...
Bender Posted January 15, 2021 Share Posted January 15, 2021 Lift rear off ground with it out of gear you should be able to spin rear wheel with little to no resistance, if brake is sticking you will feel the drag or it won't turn by hand easily if at all. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 4 minutes ago, Bender said: Lift rear off ground with it out of gear you should be able to spin rear wheel with little to no resistance, if brake is sticking you will feel the drag or it won't turn by hand easily if at all. Yes I did that and the wheel moves fairly freely (tbh I’m not sure how spinny a back wheel is supposed to be) but there is a kind of scraping sound. Quote Link to comment Share on other sites More sharing options...
Bender Posted January 15, 2021 Share Posted January 15, 2021 Remove rear brake caliper, check pads, push piston back in, re fit spin whee pull brake to re seat pad, see difference with it removed, pads may catch very slightly but if a piston is sticking it will keep wearing pad. If it's sticking the disk will be getting hot. 1 Quote Link to comment Share on other sites More sharing options...
Trooper74 Posted January 15, 2021 Share Posted January 15, 2021 Lick your finger and briefly touch to the disc ... if it hisses your pads are dragging ... 2 1 Quote Link to comment Share on other sites More sharing options...
Bender Posted January 15, 2021 Share Posted January 15, 2021 2 minutes ago, Trooper74 said: Lick your finger and briefly touch to the disc ... if it hisses your pads are dragging ... I had disks glowing on an audi I owned long-time back, I was doing ferrying of folk for a wedding, for some reason I deemed it a good idea to stick my finger to one to see how hot it was, well apparently very fn hot was the answer 1 3 Quote Link to comment Share on other sites More sharing options...
Trooper74 Posted January 15, 2021 Share Posted January 15, 2021 (edited) Thats why you lick your finger ... the saliva hisses ... not your skin .... Except for the times i’ve forgotten to lick the finger ... then she complains bitterly ... Edited January 15, 2021 by Trooper74 Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 41 minutes ago, Bender said: Remove rear brake caliper, check pads, push piston back in, re fit spin whee pull brake to re seat pad, see difference with it removed, pads may catch very slightly but if a piston is sticking it will keep wearing pad. If it's sticking the disk will be getting hot. Thanks. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 Just wondering if there’s anything else its likely to be? Quote Link to comment Share on other sites More sharing options...
JRH Posted January 15, 2021 Share Posted January 15, 2021 Check exhaust something may have stuck to it. I had a plastic catch on the silencer while riding and it stank. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 2 minutes ago, JRH said: Check exhaust something may have stuck to it. I had a plastic catch on the silencer while riding and it stank. Sadly nothing stuck. Hmph. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted January 15, 2021 Share Posted January 15, 2021 Have you checked the front wheel? Run the bike stationary and see if the smell persists. If it does then it's not wheel related. If it only appears when moving it's most likely one of the brakes. Check the radiator as well. I get some interesting scents when horse crap gets in the rad. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 4 minutes ago, Mississippi Bullfrog said: Have you checked the front wheel? Run the bike stationary and see if the smell persists. If it does then it's not wheel related. If it only appears when moving it's most likely one of the brakes. Check the radiator as well. I get some interesting scents when horse crap gets in the rad. Thanks MB will do. Hadn’t thought of that. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 15, 2021 Share Posted January 15, 2021 It's not just burning road crap on the exhaust is it? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 9 minutes ago, Stu said: It's not just burning road crap on the exhaust is it? I’m afraid not Im usually pretty at recognising burning smells but I don’t recognise this, it’s not familiar, I have no idea what burnt brake pads smell like.... Quote Link to comment Share on other sites More sharing options...
Stu Posted January 15, 2021 Share Posted January 15, 2021 2 minutes ago, Slowlycatchymonkey said: I’m afraid not Im usually pretty at recognising burning smells but I don’t recognise this, it’s not familiar, I have no idea what burnt brake pads smell like.... They smell like burnt clutch Its a really odd smell and hard to explain to be honest Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 It wasn’t quite burnt clutch, that usually has slightly oily chemically smell, this had none of that. I would say it was and odd smell and I can’t explain it! There’s nothing I can think of to compare it to. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 15, 2021 Share Posted January 15, 2021 2 minutes ago, Slowlycatchymonkey said: It wasn’t quite burnt clutch, that usually has slightly oily chemically smell, this had none of that. I would say it was and odd smell and I can’t explain it! There’s nothing I can think of to compare it to. Sorry I should have said the same as a car. They are the same material and smell the same when on fire. Quote Link to comment Share on other sites More sharing options...
Six30 Posted January 15, 2021 Share Posted January 15, 2021 3 minutes ago, Slowlycatchymonkey said: It wasn’t quite burnt clutch, that usually has slightly oily chemically smell, this had none of that. I would say it was and odd smell and I can’t explain it! There’s nothing I can think of to compare it to. did you have an Indian last night ? 1 Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 1 minute ago, Six30 said: did you have an Indian last night ? How do you know these things? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 2 minutes ago, Stu said: Sorry I should have said the same as a car. They are the same material and smell the same when on fire. I don’t know that smell, burning cars isn’t Friday night entertainment round here It’s new to me which is why I think it’s brakes. Quote Link to comment Share on other sites More sharing options...
Six30 Posted January 15, 2021 Share Posted January 15, 2021 1 minute ago, Slowlycatchymonkey said: How do you know these things? experience , unfortunately . Quote Link to comment Share on other sites More sharing options...
Stu Posted January 15, 2021 Share Posted January 15, 2021 We only did it on weekdays so people couldn't get to work the next day I would do the suggestions above and make sure there is no brakes binding Does it feel heavier to move? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted January 15, 2021 Author Share Posted January 15, 2021 Just now, Stu said: We only did it on weekdays so people couldn't get to work the next day I would do the suggestions above and make sure there is no brakes binding Does it feel heavier to move? No when I got back I pushed it round to a spot I could put it on its centre stand and it felt the same but when I was riding it before I smelt the burning I had thought “this doesn’t feel like it’s pulling away the same as usual” but dismissed it cos haven’t ridden it since Christmas Eve. It continued to stink on the return journey. I wonder if they were on and loosened off, if that can happen. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 15, 2021 Share Posted January 15, 2021 1 minute ago, Slowlycatchymonkey said: I wonder if they were on and loosened off, if that can happen. Yes that can happen but they usually loosen off within a few miles or so Quote Link to comment Share on other sites More sharing options...
