Just bought one of these from SBS, I so wish I had have done this a long time ago .... Money well spent!  Makes cleaning and getting to the tyre valve to check pressures so much easier
  • Like 2
  • Thanks 2
OMG - that's such a good idea! I have a rear paddock stand but cleaning the front is a ballache. Thank you - I'll get one before I next clear mine again!
  • Like 2
It's a lot heavier and more robust than it looks in the picture, rubber feet on the underside to prevent slip, the rollers can be altered to accommodate different size tyres and it has a rubber bung to go under the side stand (if needed) to make the bike sit a bit more upright .... I'm well impressed with it (easily pleased me) 😀
Top tip. Thank you.
  • Like 2
Seriously need this as I doing the front wheel is annoying,, cheers
I'm lucky that when mine is on the centre stand it naturally falls onto the front wheel, so spinning the rear wheel is easy, to do the front I use a quick grip clamp in the expanding orientation and jack up from the front footpeg, this lifts the front wheel and sets the rear wheel nice and firmly on the ground :thumb:
Posted (edited)
Because my bike is parked on a slope the rear wheel is off the ground slightly anyway so spinning it is never a problem. If I want to spin the front I just put a bucket with a few litres of water on the pillion and it's heavy enough to tip it on to the back wheel.
Edited by S-Westerly
Certainly a cheaper method if you can do that
Guest Richzx6r
You back in the eng er land then?
Nope - still in miami. Back to Turkey tomorrow
3 minutes ago, Slowlycatchymonkey said:
How was Miami?
It's lovely thanks chica - everything is open which is odd, people are crazy, it's 24 degrees and sunny, the girls are delightful and it's supremely expensive.
You lucky, lucky sod.
👍 It’s cheering to hear at least someone’s having a good time!
and sounds like he is digging deep :classic_huh:
