Hi all.
Bike is a 2013 Triumph Tiger Explorer 1200
Thought it sounded a bit throaty this afternoon. Looks like one of the three tabs in a join under the belly pan has rotted off.
Not sure if it's been repaired previously.
I have a welder here, but not confident it's worth trying to patch.
Anyone any idea what I'm looking at in terms of cost to repair? Not sure whether it will be just the centre section, or the front pipes too.
IMG_20221002_175337.thumb.jpg.8ee8ef2d2abfdd390eff693ebd373a0d.jpgIMG_20221002_175236.thumb.jpg.5b38e764d5765a2fe77ce2b8d2dd30ed.jpg
looks like they went cheap to me.. I would replace it with a full system if there is one available, in S/S.
@Stu is right. I'm betting you would burn many many extra holes in that trying to weld it up. At least I know I would :lol:
As a temp measure could you use one of the holts silencer patches?
Funnily enough I have knocked up something temporary that looks remarkably similar.
Looking through the Triumph forums it seems like a common (and expensive) problem.
Can be bugger to weld, depends on mix in what it's made from, using a mig and working out slowly using the weld you started with rather than trying to bridge straight off is best way.
Even if you can successfully weld the break the chances are high that the material immediately adjacent to the weld will rapidly corrode away or it will fracture on the edge of the weld. Patch in the short term, replace in the longer term.
It’s more than a little shocking that something like this, which was common in the 80s is happening on a relatively modern bike from 2013.  My old beemer unchanged when I bought it in 97 was fully stainless and it first appeared in 1993!!
Triumph. What were you thinking!!
I would personally go for replacement, however, that's going on my own experience and skill with welding, which certainly isn't my favourite DIY job.
I was wondering about a custom stainless system but not sure about the legality of removing the cat.
If your happy with the bike you can have a stainless cat added you don't have to have it without
