Stu Posted March 30, 2017 Share Posted March 30, 2017 The screwdrivers in tool kits are disposable! you use them once then throw them away But it is a really good question! I have never checked and I would assume they would be Quote Link to comment Share on other sites More sharing options...
Westbeef Posted March 30, 2017 Share Posted March 30, 2017 Well I hope they last more than one use I used mine to sort out my battery terminals Quote Link to comment Share on other sites More sharing options...
raesewell Posted March 31, 2017 Share Posted March 31, 2017 I have a set of Japanese Industrial Standard (JIS) screwdrivers but quite often change the fasteners where possible to hex or allen. Quote Link to comment Share on other sites More sharing options...
fastbob Posted March 31, 2017 Share Posted March 31, 2017 Unless it's a classic restoration I always replace every single screw and bolt with an Allen bolt . Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 31, 2017 Share Posted March 31, 2017 Unless it's a classic restoration I always replace every single screw and bolt with an Allen bolt .Torx heads are so much cooler than allen bolts. harder to round off too Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 14, 2017 Share Posted April 14, 2017 Unless it's a classic restoration I always replace every single screw and bolt with an Allen bolt .Torx heads are so much cooler than allen bolts. harder to round off tooWould it be possible to replace every screw and bolt on a bike with Torx head bolt? Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 14, 2017 Share Posted April 14, 2017 Unless it's a classic restoration I always replace every single screw and bolt with an Allen bolt .Torx heads are so much cooler than allen bolts. harder to round off tooWould it be possible to replace every screw and bolt on a bike with Torx head bolt? probably... my BMW bike uses torx head fasteners almost exclusively Quote Link to comment Share on other sites More sharing options...
TimR Posted April 15, 2017 Share Posted April 15, 2017 Regardless of the type of tool you need for the fastener if you buy cheap fasteners expect cheap material that will chew up regardless Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 15, 2017 Share Posted April 15, 2017 Regardless of the type of tool you need for the fastener if you buy cheap fasteners expect cheap material that will chew up regardlessWhere did that come from? Quote Link to comment Share on other sites More sharing options...
TimR Posted April 15, 2017 Share Posted April 15, 2017 Regardless of the type of tool you need for the fastener if you buy cheap fasteners expect cheap material that will chew up regardlessWhere did that come from? People changing fasteners from screw to torx/hex type are prone to buying the generic cheap kits off ebay which will chew the head up just as much as a screw head would Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 15, 2017 Share Posted April 15, 2017 People changing fasteners from screw to torx/hex type are prone to buying the generic cheap kits off ebay which will chew the head up just as much as a screw head wouldFair enough. Only if they used the incorrect driver for them which some probably do. Quote Link to comment Share on other sites More sharing options...
