Esoteric Posted April 11, 2020 Posted April 11, 2020 Hi all,I'm pretty new to this forum and biking in general. Been biking for a few months but haven't got much time in yet due to work.Anyway, to the point, not so long ago my bike fell over., it scratched the exhaust very slightly (nothing major) and the fairing (again just scratching nothing significant. However, oil has been leaking out of the bottom of the bike. It's leaking quite slowly and is coming out of the engine near the 'sump' I've been told by a kind neighbour. It is covering the nuts/bolts at the bottom and some of the lower piping as well as the stands. Any suggestions on what it might be or how I can investigate it?No where is open to take it for repair. My neighbour is quite experienced with bikes and has offered to give me a hand with the actual repair once I've figured out what it is and got the part I need.I'm using my car at the moment due to the problem and my lack of spare time (work in healthcare and right now it's nuts)Thank you all in advanced for all of your help Quote
fastbob Posted April 11, 2020 Posted April 11, 2020 I would remove the fairing and wipe the whole engine down so it's completely clean and free of any trace of oil . Then you will be able to identify exactly where it's originating . Bear in mind that oil is very clingy and will run along the underside of surfaces so the place that it is dripping from might not be the place that it is coming from . If it were me , I would start the bike and let it run for a while so that the oil is redistributed to where it's supposed to be . And please can you tell us what bike it is and which way it fell . Quote
Esoteric Posted April 11, 2020 Author Posted April 11, 2020 https://imgur.com/Fn8JYSz' alt='IMGUR>'>https://imgur.com/wzU8wcR' alt='IMGUR>'>It's a Honda CBF125MD Quote
Ian Frog Posted April 11, 2020 Posted April 11, 2020 I would love to help but for some reason I cant see your pics!CheersIan Quote
skyrider Posted April 11, 2020 Posted April 11, 2020 there is a couple on fleabay and the bikes just seem to have a headlamp style fairing and one has a belly pan Quote
fastbob Posted April 11, 2020 Posted April 11, 2020 Same , can't open pics . Just go attachments , add files , choose image and submit . Quote
Guest Richzx6r Posted April 11, 2020 Posted April 11, 2020 From the description I'd guess it fell on it its right side? So could be the oil filler cap or somewhere maybe? Quote
Esoteric Posted April 11, 2020 Author Posted April 11, 2020 Thanks for all the help so far. Can you see the pictures now?I believe it fell on it's right side but I was at work and my neighbour saw it and picked it up for me so I'm not 100% certail Quote
skyrider Posted April 11, 2020 Posted April 11, 2020 is that rust or is it oil drooling out of your sump plug Quote
Guest Richzx6r Posted April 11, 2020 Posted April 11, 2020 is that rust or is it oil drooling out of your sump plug Looks like a spot of rust top tight of the bold and wet oil on the underside of the bolt head? Quote
Guest Richzx6r Posted April 11, 2020 Posted April 11, 2020 I'd put a guess on its dribbled down from maybe the oil filler cap doesn't look like the sump plug is actually leaking as there doesn't look to be too much residual oil around the seam of the plug Quote
TimR Posted April 11, 2020 Posted April 11, 2020 Two pieces of advice1. Check this bolt for tightness DO NOT GO MAD ON IT !!!! IT ONLY NEEDS TO BE TIGHT ie hand tight then spanner tight ( you begin to feel the resistance and a weeny bit more )Wipe clean the area and keep an eye on it .This is unlikely to have been as a result of yhe bike going over unless the base of the engine struck something ie lamp post / kerb 2.investigate this clean silver line as it may be a crack in the casing There may be a historic leak as looking at the picture one side of engine is bone dry but other seems stained/wet Quote
Bender Posted April 11, 2020 Posted April 11, 2020 As above highly unlikely falling over caused it, you don't want oil on rear tyre, follow above, clean off, check bolt, check oil level, keep an eye on it see where its spreading from, oil tends to spread rearward and downward from a leak. Quote
fastbob Posted April 11, 2020 Posted April 11, 2020 I reckon a little bit of oil has come out of the breather and has dribbled down to the sump plug which is at the lowest point on the engine. Here you go . The crankcase breather will usually be plugged into the air box so have a poke around in there and to will probably find a bit of oil lurking around . Quote
Tiggie Posted April 11, 2020 Posted April 11, 2020 Completely agree with this assessment.And as he has a Harley he is very experienced in oil leaks Quote
fastbob Posted April 11, 2020 Posted April 11, 2020 Completely agree with this assessment.And as he has a Harley he is very experienced in oil leaks Perhaps you would be kind enough to point them out to me . Quote
Tiggie Posted April 11, 2020 Posted April 11, 2020 [mention]fastbob[/mention] Nope, I've got nothing, very tidy looking machine Quote
Esoteric Posted April 11, 2020 Author Posted April 11, 2020 Two pieces of advice1. Check this bolt for tightness 20200411_194541~3.jpgDO NOT GO MAD ON IT !!!! IT ONLY NEEDS TO BE TIGHT ie hand tight then spanner tight ( you begin to feel the resistance and a weeny bit more )Wipe clean the area and keep an eye on it .This is unlikely to have been as a result of yhe bike going over unless the base of the engine struck something ie lamp post / kerb 2.investigate this clean silver line as it may be a crack in the casing 20200411_194541~2.jpgThere may be a historic leak as looking at the picture one side of engine is bone dry but other seems stained/wet 20200411_194541~4.jpg Wow thank you for this detailed advice. I'll give it all a hose/hand clean, take some new pictures for comparison and try to have a look around. Like I said I have no experience at all with this so thank you for going into so much detail and showing me on the pictures. I bought this from a dealership and came into problems a couple of months later (the tyres had some weird gel squirted into them to cover up punctures) but I've not had the bike fully checked over... seems it was a mistake to trust the dealer (though they did have good rep). If the casing is cracked, what should I do in the meantime? I not sure if my neighbour will be willing or able to help me with a repair so significant and nowhere around here is open due to the quarantine. Is it just a case of topping up the oil and starting the engine every couple of days to get things moving around?Once I've cleaning and investigated a bit more I'll post the new pictures up here (might take a few days though)Thank you all again! Quote
Esoteric Posted April 11, 2020 Author Posted April 11, 2020 I reckon a little bit of oil has come out of the breather and has dribbled down to the sump plug which is at the lowest point on the engine. Here you go . The crankcase breather will usually be plugged into the air box so have a poke around in there and to will probably find a bit of oil lurking around . Thank you, I'll take a look at this before and after I clean the bike and see if I can spot anything. What would the best course of action be if this is the problem? Is it an easy fix? Or am I gonna die trying Quote
fastbob Posted April 11, 2020 Posted April 11, 2020 I reckon a little bit of oil has come out of the breather and has dribbled down to the sump plug which is at the lowest point on the engine. Here you go . The crankcase breather will usually be plugged into the air box so have a poke around in there and to will probably find a bit of oil lurking around . Thank you, I'll take a look at this before and after I clean the bike and see if I can spot anything. What would the best course of action be if this is the problem? Is it an easy fix? Or am I gonna die trying There probably isn't any problem . Quote
FallingDown Posted April 11, 2020 Posted April 11, 2020 I reckon a little bit of oil has come out of the breather and has dribbled down to the sump plug which is at the lowest point on the engine. Here you go . The crankcase breather will usually be plugged into the air box so have a poke around in there and to will probably find a bit of oil lurking around . Thank you, I'll take a look at this before and after I clean the bike and see if I can spot anything. What would the best course of action be if this is the problem? Is it an easy fix? Or am I gonna die trying There probably isn't any problem . The joys of Honda ownership. Good luck, sure it's probably nothing to worry about once you've cleaned it up and checked your oil level Quote
Guest Richzx6r Posted April 12, 2020 Posted April 12, 2020 Completely agree with this assessment.And as he has a Harley he is very experienced in oil leaks Perhaps you would be kind enough to point them out to me . Its that bad its sprayed the wall by the left handlebar Quote
