daveinlim Posted August 21, 2020 Posted August 21, 2020 I've got a puncture in my rear tyre. It looks like it's from a nail which isn't in the tyre any more.The tyre is fairly new and the puncture is in the dead centre of the tyre son ideal spot to repair rather than replace. My bike is a gsxs125 so wouldn't be going over 60 and most 90% of miles are in London traffic. Would these be suitable as a long term solution? They look dead simple to use. They would definitely do for a quick fix but can I use it longer than that? Quote
Guest Swagman Posted August 21, 2020 Posted August 21, 2020 No they are only a temporary fix to get you out of trouble it needs to go to a tyre firm and have it done properly from the inside. Quote
Gerontious Posted August 21, 2020 Posted August 21, 2020 (edited) Depends on the plugs. there are different systems. I have repaired a puncture and then a few months later toured europe on the same repaired tyre. The tyre didnt need to come off the wheel and I did the repair in under 10 minutes. I have done this several times over the years. If the repair fails (and that has never happened) you just get a flat and need to call rescue as you would with any flat. I tend to do the repair and then monitor the pressure for a week or two. no change in pressure and I essentially forget about it. Edited August 21, 2020 by Gerontious Quote
daveinlim Posted August 21, 2020 Author Posted August 21, 2020 I forgot to say which one I was looking atGryyp Cargol Turn & Go - K004 KitSeems easiest to use Quote
raesewell Posted August 21, 2020 Posted August 21, 2020 The Turn & Go has been known to leak, it looks like a fantastic idea.Dynaplug is what I carry. http://www.dynaplug.com/ultralite.htmlI fixed a leak on my Son-in-laws bike a few thousand mile ago and it's still going strong and not leaking, it was a two plug leak. Quote
geofferz Posted August 21, 2020 Posted August 21, 2020 I've read mixed opinions. If you're only going slowly everywhere you may be fine, someone said they had one in for a year. I ride quite fast and wouldn't trust one. Quote
Stu Posted August 21, 2020 Posted August 21, 2020 Roadside plugs to get you home then a permanent fix once home for me! It's each to their own I like to know its done properly with a mushroom plug from the inside as I have seen roadside plugs let go in the past and I have also seen the consequences of a flat while riding too. Quote
manxie49 Posted August 21, 2020 Posted August 21, 2020 I've only ever used them as a temporary fix to get me home, I also ride really slowly with one in. I personally wouldn't trust them long term, however I do know some people have faith in them depending on the type used. Quote
Guest Swagman Posted August 21, 2020 Posted August 21, 2020 These kits should only ever be used as a short-term fix, and you should always seek help from a tyre professional at the earliest opportunity. Riding your motorcycle with an incorrectly repaired puncture or temporary repair for a prolonged period may affect your insurance. This is a quote from Bennett’s insurance. Quote
Commuter Posted August 21, 2020 Posted August 21, 2020 I rode a YBR125 on a 30 mile round trip into London for 8 years and generally got between 1 and 3 punctures per year. I found a professional repair cost almost the same as a new tyre (£50 as compared to £70 or £80).I used a kit like this one: https://www.eurocarparts.com/p/benson-car-tyre-repair-set-27pc-553991400?type=shopping&gclid=EAIaIQobChMI2pDl1b2s6wIVVe3tCh2pZAd1EAQYBSABEgJFrPD_BwE You can get them off auction site for about £5. I found they worked perfectly as a permanent repair - never had one fail. there are videos on youtube on how to use them. Last time I changed the tyre I had 4 of these repairs in it.I'm sure others will disagree, but that was my experience. I wouldn't rely on one on my current larger bike for higher speeds, but commuting into a city, max speed probably 45'ish. I think they are fine. Quote
Fozzie Posted August 21, 2020 Posted August 21, 2020 I blew a 6mm hole in my front tyre hitting a bolt on the M56 during lockdown (was doing volunteer courier work). The plug I used lasted less than a week and I heard it slapping on the mudguard before coming out again. Luckily I heard it and got ready as that sort of sudden pressure loss makes the front of the bike go very funny very quickly.I've never had a plug go wrong, so that shook me up a bit, and I didn't trust the replacement I put in, even with extra cement. So from now on, it's pro repair, or replace which ever tyre went. Quote
raesewell Posted August 21, 2020 Posted August 21, 2020 I think a 6mm hole is asking a bit much of any plug. Quote
dynax Posted August 21, 2020 Posted August 21, 2020 If the hole is bigger than the reamer for the plugs there's not much chance of it holding out for long Quote
WD-40 Posted August 21, 2020 Posted August 21, 2020 I've always used the stringy ones from the pound shop and never had a problem with them. I've had a couple of them in a rear tyre at the same time for thousands of miles and had no problems. I've only had rear punctures. I don't think I would plug a front tyre. Quote
daveinlim Posted August 21, 2020 Author Posted August 21, 2020 These kits should only ever be used as a short-term fix, and you should always seek help from a tyre professional at the earliest opportunity. Riding your motorcycle with an incorrectly repaired puncture or temporary repair for a prolonged period may affect your insurance. This is a quote from Bennett’s insurance. I hadn't though of insurance implications. I must get the details out and see what they say. Quote
Benny Posted August 22, 2020 Posted August 22, 2020 I’m a noob but can you use either the tire foam as temporary or how about the slime they put in push bike wheels at Halfords is that suiatable for motorbikes? As I believe that sits in the tyre until it punctures then seals and go hard?! Quote
Mississippi Bullfrog Posted August 22, 2020 Posted August 22, 2020 I’m a noob but can you use either the tire foam as temporary or how about the slime they put in push bike wheels at Halfords is that suiatable for motorbikes? As I believe that sits in the tyre until it punctures then seals and go hard?! Don't use either stuff in bike tyres. Some products damage the rims. Slime is useless, I tried it in push bike tyres, all it does is wreck the valves, makes a mess and leaves a small thorn hole hissing air. Best to carry a puncture repair kit. That will get you home, then get the tyre professionally repaired. Quote
Gerontious Posted August 22, 2020 Posted August 22, 2020 I’m a noob but can you use either the tire foam as temporary or how about the slime they put in push bike wheels at Halfords is that suiatable for motorbikes? As I believe that sits in the tyre until it punctures then seals and go hard?! Don't use either stuff in bike tyres. Some products damage the rims. You have a gift for understatement.you may be lucky.. and the paint or coating might protect the metal underneath. or you might be very VERY unlucky... Quote
daveinlim Posted August 26, 2020 Author Posted August 26, 2020 Little update. I took the cautious approach and went to the garage. They sorted me out on the spot and for less than the price of a repair kit. Quote
husoi Posted August 27, 2020 Posted August 27, 2020 I would never use foam, tyre plugs yes in an emergency.f I can make it to a garage then I will leave it to the professionals. Quote
geofferz Posted August 27, 2020 Posted August 27, 2020 Little update. I took the cautious approach and went to the garage. They sorted me out on the spot and for less than the price of a repair kit.Good point and fair consideration - the cost of the new tyre. If you're running cheap ones then deffo get it replaced! Quote
daveinlim Posted August 27, 2020 Author Posted August 27, 2020 Little update. I took the cautious approach and went to the garage. They sorted me out on the spot and for less than the price of a repair kit.Good point and fair consideration - the cost of the new tyre. If you're running cheap ones then deffo get it replaced! I have a decent set of Dunlop tyres on. So they aren't some random Chinese tyre nobody has ever heard of. Aside from the small puncture they are in great condition too. So I'm happy to keep them on for now. Quote
raesewell Posted August 27, 2020 Posted August 27, 2020 Opinions are always divided on puncture prevention and repair, never the twain I'm afraid. Everyone speaks of their own experiences no matter how out of date they are or how much technology has moved on. No harmony to be achieved with this subject. Quote
Guest Swagman Posted August 27, 2020 Posted August 27, 2020 Just purchased a plug repair set and a small compressor they both fit under the seat nicely. Quote
