RandomBob Posted September 22, 2022 Share Posted September 22, 2022 Have a 20 plate Benelli TRK 502x which has been a great ride, until now. It's developed a horrendous vibration in the footpegs. Present when idle and actually causes me pain in my left knee when going anything about 20 mph. Have changed the sprockets and chain. Everything is where it should be. Had new tyres fitted few weeks ago which were working fine. I've checked the rims and brakes so have run out of the easy ideas. Anyone got a suggestion ? If I can't get this worked out I'm going to have to spend lots of money at a workshop or sell the bugger as it's genuinely painful... Quote Link to comment Share on other sites More sharing options...
Fiddlesticks Posted September 22, 2022 Share Posted September 22, 2022 Did it start after the new tyres were fitted? Were the wheels balanced correctly? 2 Quote Link to comment Share on other sites More sharing options...
billy sugger Posted September 22, 2022 Share Posted September 22, 2022 (edited) Check wheel balance weights are still there if you had the wheels balanced whe new tyres were fitted Fiddlesticks replied as I was typing Edited September 22, 2022 by billy sugger 2 Quote Link to comment Share on other sites More sharing options...
Bender Posted September 22, 2022 Share Posted September 22, 2022 If its present at idle and not moving its not wheels and tyres, engine mounts? 1 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted September 22, 2022 Share Posted September 22, 2022 Are you sure both cylinders are firing? From a cold start spray some water on each header, make sure they are both the same temperature. 1 Quote Link to comment Share on other sites More sharing options...
Pie man Posted September 22, 2022 Share Posted September 22, 2022 2 hours ago, Bender said: If its present at idle and not moving its not wheels and tyres, engine mounts? or engine woes. If it's that bad and painful I would save my money and get shut 2 Quote Link to comment Share on other sites More sharing options...
Bender Posted September 22, 2022 Share Posted September 22, 2022 2 hours ago, Pie man said: or engine woes. If it's that bad and painful I would save my money and get shut Possibly, but engines usually die fairly quickly with that level of harshness. Quote Link to comment Share on other sites More sharing options...
Pie man Posted September 22, 2022 Share Posted September 22, 2022 I'm not convinced the Chinese have ability to produce a quality product even if it is in the disguise of an Italian 1 1 Quote Link to comment Share on other sites More sharing options...
bonio Posted September 22, 2022 Share Posted September 22, 2022 Incoming.... ! 1 2 Quote Link to comment Share on other sites More sharing options...
RandomBob Posted September 22, 2022 Author Share Posted September 22, 2022 From speaking to friends think the engine mounts are next in line. Wheels were balanced at time so should be good. If its internal then its off to the workshop. Thanks folks Italian/Chinese engineering...what could go wrong ?! 1 Quote Link to comment Share on other sites More sharing options...
johnjackson1949 Posted January 20 Share Posted January 20 2020 TRK502 rear wheel hub is wrongly, not concentric, machined, This is creating a vibration through ..whole bike & handle bars. Waiting to claim Warranty !!! Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20 Share Posted January 20 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20 Share Posted January 20 lol is it fixed yet? Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted January 20 Share Posted January 20 (edited) Cant be wheels if it does it at idle. its the engine, had a similar problem but its for the same reason as mine which is why i sold it , on the side stand, rev it, it will actually move the bike up and forward while on its side stand! these engines are extremely tight from new which is why you wouldn't have noticed it before. Its down to its design, harmonic balance problems especially noticeable when past run in after 4000 but gets silly bad after 8-10000miles. Tried different things to mask it but had no desire to keep pissing around spending loads of money and waiting months on end to come from china for parts even if they were available... yes you can get mounts (if available for china?) and it may help to a point but it will still do it and having to do that to such a new bike is just not realistic 10yrs ago let alone today... if its that bad for you just sell it, you'll get probably around low £2k with low mileage if you rob them, thats even if anyone is desperate or no idea of it. Edited January 21 by RideWithStyles Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23 Share Posted January 23 (edited) sorry for being so facetious no intent intended. I've never owned a parallel twin but they are renound for the big vibration almost bought a Suzuki TL 1000 and that's the reason I didn't. I just don't like twin cylinder bikes. Ducatis look lovely but I would never buy one. the honda CX 500 worst bike honda ever made. mho Edited January 23 by Vic101 Quote Link to comment Share on other sites More sharing options...
