Trooper74 Posted February 5, 2023 Share Posted February 5, 2023 Suggestions please ... Quote Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2023 Share Posted February 5, 2023 Stop and go and a small compressor too Dont fanny about with the CO2 canisters as it will take around 4 to get a decent pressure in the rear to move the bike but not enough to inflate it fully 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2023 Share Posted February 5, 2023 https://www.mandp.co.uk/products/stop-and-go-pocket-tyre-plugger-tubeless-standard-561467 https://www.amazon.co.uk/AA-Inflator-Compact-Lightweight-Travel/dp/B00HWMPK6S/ref=sr_1_9?crid=X79FCDUF0S1I&keywords=aa+air+tyre+inflator&qid=1675631050&s=automotive&sprefix=aa+air+tyre+inflator+%2Cautomotive%2C76&sr=1-9 Thats the smallest inflator I have been able to find in the past 1 Quote Link to comment Share on other sites More sharing options...
manxie49 Posted February 5, 2023 Share Posted February 5, 2023 I have the stop and go tyre repair kit. Never had to use it in anger, but it was recommended to me by a couple of different people over here. Pretty easy to use, gets good reviews and certainly looks like it’ll do the job if needed. The 6000 version comes with a mini compressor, but you can also get the CO2 inflators. Kit without mini compressor should fit under seat Quote Link to comment Share on other sites More sharing options...
Pie man Posted February 5, 2023 Share Posted February 5, 2023 18 minutes ago, Stu said: https://www.mandp.co.uk/products/stop-and-go-pocket-tyre-plugger-tubeless-standard-561467 https://www.amazon.co.uk/AA-Inflator-Compact-Lightweight-Travel/dp/B00HWMPK6S/ref=sr_1_9?crid=X79FCDUF0S1I&keywords=aa+air+tyre+inflator&qid=1675631050&s=automotive&sprefix=aa+air+tyre+inflator+%2Cautomotive%2C76&sr=1-9 Thats the smallest inflator I have been able to find in the past That's my set up too 1 Quote Link to comment Share on other sites More sharing options...
jedibiker Posted February 8, 2023 Share Posted February 8, 2023 I use the caterpillar type and bought this pump for when i did nc500, it charges up so no cables needed, and its not bad at all https://www.amazon.co.uk/gp/product/B09GFP9N1F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 1 Quote Link to comment Share on other sites More sharing options...
Fish Posted February 8, 2023 Share Posted February 8, 2023 Have this one myself https://twotyres.co.uk/product/motorcycle-puncture-repair-kit/ Quote Link to comment Share on other sites More sharing options...
Fish Posted February 8, 2023 Share Posted February 8, 2023 5 hours ago, jedibiker said: I use the caterpillar type and bought this pump for when i did nc500, it charges up so no cables needed, and its not bad at all https://www.amazon.co.uk/gp/product/B09GFP9N1F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I hope that you remember to recharge it daily Quote Link to comment Share on other sites More sharing options...
Gerontious Posted February 8, 2023 Share Posted February 8, 2023 (edited) Stop and Go. you will also need a small pair of pliers to remove the object and to pull the mushroom stalk to finish the repair. (they don't tell you that until you read the instructions) - I carry a multitool, with needle nose pliers. which is always a handy thing to have with you anyway. Gerber or Leatherman. The best thing by far about the stop and go is it doesn't use any glue. with glue, once you open it you need to replace it for next time as it will go off once its exposed to air. once you have found the object in the tyre, the repair takes 2/3 minutes and however long it takes to reinflate. you can usually be on your way agin within 20 minutes or less. But... it should be obvious, sods law comes into effect. if you have it with you then you will never use it. the moment you forget and leave it at home then that is when you will get a puncture. Edited February 8, 2023 by Gerontious 1 Quote Link to comment Share on other sites More sharing options...
Mick67 Posted February 9, 2023 Share Posted February 9, 2023 I use the plug kit from M&P and to inflate have a https://www.sportouring.co.uk/shop/accessories/tyre-care/tyre-inflation/rocky-creek-12v-tyre-inflator/ and also got the https://www.sportouring.co.uk/shop/accessories/tyre-care/tyre-inflation/rocky-creek-tyre-gauge-dial-type-with-two-chucks/ The pump is great nice and light and inflates in no time, the gauge is ok but could do with being smaller tbh. Quote Link to comment Share on other sites More sharing options...
jedibiker Posted February 14, 2023 Share Posted February 14, 2023 On 08/02/2023 at 18:22, Fish said: I hope that you remember to recharge it daily it holds its charge for days. Quote Link to comment Share on other sites More sharing options...
