Fidgetgreen Posted April 23, 2019 Share Posted April 23, 2019 Hi! I did some maintenance on my kawa er6f yesterday. I replaced the chain and sprockets as the chain wear was really uneven even thought the bike has only done 2500 miles. When riveting on the soft link, one of them cracked. I wasn't able to replace them straight away as I only had one in the pack. I plan to change this soon but can I ride this in the meantime or is it a definite no until i get a new soft link? Also, do you think I can take this to a mechanic for them to just replace the link? I'm a bit worried about doing it again and the same thing happening. Thanks,S Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted April 23, 2019 Share Posted April 23, 2019 I'd say not to ride it in current condition as it could snap it as any second and that's bloody dangerous as could do more damage than just the soft links if it did go so I'd get some more soft links and have another go Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted April 23, 2019 Share Posted April 23, 2019 Where in the country are you? Quote Link to comment Share on other sites More sharing options...
Fidgetgreen Posted April 23, 2019 Author Share Posted April 23, 2019 I'm in London Quote Link to comment Share on other sites More sharing options...
Smithers Posted April 23, 2019 Share Posted April 23, 2019 I'm convinced a lot of chain and sprocket wear is down to accuracy of rear wheel alignment. How often do check your wheel alignment and how? (open question). Quote Link to comment Share on other sites More sharing options...
winston smith Posted April 23, 2019 Share Posted April 23, 2019 I'm convinced a lot of chain and sprocket wear is down to accuracy of rear wheel alignment. How often do check your wheel alignment and how? (open question). That's a really good point/question.I've always done it by eye (tape pencil on either side of the swingarm to be not quite touching the wheelrim then spin the back wheel) after setting the chain length using the markers on the swingarm. Of course, this method only works if frame, swingarm and back wheel are all true, and hub/wheel bearings and swingarm bearings in good order. But it's always been ok for me.And of course you need centre stand or paddock stand to do it safely.I've known loads of people who only recommend the long string around the front wheel method, but seems like a lot of faffing to me. Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted April 23, 2019 Share Posted April 23, 2019 The thing with the Mark's on swingarm how accurate are they, it does look like they have a lot of margin for error so there must be a better less faffy way of getting the rear wheel alignment bang on Quote Link to comment Share on other sites More sharing options...
BIKERDAD Posted April 23, 2019 Share Posted April 23, 2019 I'm convinced a lot of chain and sprocket wear is down to accuracy of rear wheel alignment. How often do check your wheel alignment and how? (open question). I thought (was told why mine was streched .chain .) Was When i slow down i use the gears to help me slow down as well as brakes .. X lorry driver so i use the engine to slow down as well as brakes . So i just do the same on the bike say approaching a round about.... brakes ..change down gear more brakes clear to go off brakes you change up .... So if been told that doing that stretches my chain and damaging the sprocket was chain stretched and not fitting on the cog/teeth right .. Quote Link to comment Share on other sites More sharing options...
skyrider Posted April 23, 2019 Share Posted April 23, 2019 I have always had bikes with split link chains and never a problem Quote Link to comment Share on other sites More sharing options...
winston smith Posted April 23, 2019 Share Posted April 23, 2019 The thing with the Mark's on swingarm how accurate are they, it does look like they have a lot of margin for error so there must be a better less faffy way of getting the rear wheel alignment bang on Yep, I agree about the swingarm marks - that's why double check by eye, spinning the wheel afterwards. It only takes a few extra minutes. Quote Link to comment Share on other sites More sharing options...
Old-codger Posted April 23, 2019 Share Posted April 23, 2019 Just get the correct split link for your chain it will be fine, Do Not ride it with a damaged soft link if it snaps you could be in a whole world of trouble. Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 23, 2019 Share Posted April 23, 2019 A belt drive has a certain appeal . Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted April 23, 2019 Share Posted April 23, 2019 I'd love a picture, how did you manage it?? Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 24, 2019 Share Posted April 24, 2019 If there is a chance the chain could snap, don't ride it. A snapped chain makes a real mess of a bike and can easily lock the rear wheel (mid corner) sending you sliding into incoming traffic..Stretched chains are actually a myth. Yes they get longer but nothing stretches. Measure rear wheel alignment from the swing arm pivot. Easy enough to knock up a bit of wood with a bolt in one end for the swing arm pivot and marks the other end for the axle bolt. Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 24, 2019 Share Posted April 24, 2019 Check this out ..https://twitter.com/gt2andy/status/1120982895127146497?s=19 Quote Link to comment Share on other sites More sharing options...
Fidgetgreen Posted April 26, 2019 Author Share Posted April 26, 2019 Thanks for all the responses, I'll look at getting it fixed asap. When we were riveting one of the links, I think we put a bit too much pressure on it. This isn't my chain but this is similar to what my link looks like (the one on the right)[img][Not sure if you can see but there is a crack on the link on the right. I'll also look at my wheel alignment as well. Quote Link to comment Share on other sites More sharing options...
Stu Posted April 26, 2019 Share Posted April 26, 2019 That doesn't look like a soft link to me!A soft link has a hole in the middle normally Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 26, 2019 Share Posted April 26, 2019 Yeah, why aren't those indentations in the middle of the pins? Quote Link to comment Share on other sites More sharing options...
Copycat73 Posted April 26, 2019 Share Posted April 26, 2019 Yeah, why aren't those indentations in the middle of the pins? because he didn't use a DID riveter ... Quote Link to comment Share on other sites More sharing options...
megawatt Posted April 26, 2019 Share Posted April 26, 2019 Most soft/ rivet links already have a dimple in the middle of the pin anyway? Quote Link to comment Share on other sites More sharing options...
smallfrowne Posted April 26, 2019 Share Posted April 26, 2019 If you know of a mechanic man willing to do it not too far away I'd ride it there, gently like. Though without an actual picture it's hard to tell. But I did ride my own bike with an unrivited link about 10 mile or something to the man. I was Mr Gentle and Mr Smooth and went horribly slowly but I survived so you might as well. If the wheel is aligned then you might be OK to tootle off, but of course caveat equitem Quote Link to comment Share on other sites More sharing options...
Lumor_uk Posted May 2, 2019 Share Posted May 2, 2019 Has that guy removed part of the chain guard? Quote Link to comment Share on other sites More sharing options...
