Slowlycatchymonkey Posted October 27, 2020 Share Posted October 27, 2020 Custom lid painting. Tentatively thinking of giving it a go. Anyone tried it or had any experience of it?Yes I know all the danger warnings about sanding, paint choices and compromising the safety of your lid. I’d like to know about the practicalities. Quote Link to comment Share on other sites More sharing options...
bonio Posted October 27, 2020 Share Posted October 27, 2020 Don't know if this is much help: The older guy who runs the Helmet City store in Cheddar is getting a lid done for his wife. If you're passing that way, it may be worth dropping him and asking him. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 27, 2020 Author Share Posted October 27, 2020 Thanks [mention]bonio[/mention] I’ll ask him about it. If it’s the slim, polite, quietly spoken guy he’s pretty sensible Quote Link to comment Share on other sites More sharing options...
bonio Posted October 27, 2020 Share Posted October 27, 2020 Thanks @bonio I’ll ask him about it. If it’s the slim, polite, quietly spoken guy he’s pretty sensible That sounds like the one. He rides an S1000XR, so 50% wild, 50% sensible. Quote Link to comment Share on other sites More sharing options...
learningtofly Posted October 28, 2020 Share Posted October 28, 2020 Custom lid painting. Tentatively thinking of giving it a go. Anyone tried it or had any experience of it?Yes I know all the danger warnings about sanding, paint choices and compromising the safety of your lid. I’d like to know about the practicalities. As in doing it yourself or finding someone to do it? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 28, 2020 Author Share Posted October 28, 2020 Doing it myself. If the helmet city guy is using someone local they might be happy to talk to me about paint etc Quote Link to comment Share on other sites More sharing options...
dynax Posted October 28, 2020 Share Posted October 28, 2020 Most modern lids are made from plastic as opposed to the older ones that were fibreglass, using modern acrylic enamel paints and primers won't have any detremental effect on the helmet, just make sure anything used is NOT solvent based and you should be good Quote Link to comment Share on other sites More sharing options...
dynax Posted October 28, 2020 Share Posted October 28, 2020 If you are going the airbrush way to paint them, i can recommend the Polyvine range of acrylic enamel paint https://www.craftmill.co.uk/decoupage-decopatch-blanks-supplies/enamel-airbrush-paint Quote Link to comment Share on other sites More sharing options...
husoi Posted October 28, 2020 Share Posted October 28, 2020 Keep in mind that some lids have a couple coats of clear varnish. You need to remove it before doing and styling.Main rule in spraying anything:Spend 100 hrs in preparation and save 150 hrs in trying to fix it Quote Link to comment Share on other sites More sharing options...
dynax Posted October 28, 2020 Share Posted October 28, 2020 Another thing to bear in mind is to leave the certification sticker alone, do not remove it, you can cover it with tape when you paint over it, but it must remain intact otherwise it will render the helmet not fit to be used on a public highway Quote Link to comment Share on other sites More sharing options...
husoi Posted October 28, 2020 Share Posted October 28, 2020 Another thing to bear in mind is to leave the certification sticker alone, do not remove it, you can cover it with tape when you paint over it, but it must remain intact otherwise it will render the helmet not fit to be used on a public highway Or. If is a plastic one you can VERY GENTLY (I know, a biker doesn't do gentle ) use a hairdryer to heat up the glue and remove it. then use a double sided tape to put it back.But as Dinax says, better leave it alone Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 Thanks [mention]dynax[/mention] n [mention]husoi[/mention] I’ll have a look at those paints. Yep I get the prep things 75% of the effort, I got a gloss helmet so I’ll be able to see when I’ve removed enough of the surface without going too far in. I’m thinking about taking off the sticker though It would be a risk if you’re stopped by someone not au fair with the law but they just have to state they’re compliant and they usually put it in the label inside the helmet now, they have in the one I wanna paint so.... Quote Link to comment Share on other sites More sharing options...
husoi Posted October 29, 2020 Share Posted October 29, 2020 Instead of removing the sticker you can mask it with tape and remove the tape before the clear coats. It will protect it and make a smooth surface Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 Instead of removing the sticker you can mask it with tape and remove the tape before the clear coats. It will protect it and make a smooth surface That was my first choice but then I thought I’d prefer no stickers. Easy and a cleaner look. Mind you thats assuming I can achieve a clean look, pretty unlikely on a first stab! Quote Link to comment Share on other sites More sharing options...
husoi Posted October 29, 2020 Share Posted October 29, 2020 Best way to practice is to get a plastic container and spray it, you can do it as many times as you need to feel comfortable that you will be doing a good job.It doesn't really matter the type of container as long is plastic. You then can experiment with filler, primer (the one for plastic) and spray your templates.Like that you won't be messing with the helmet.The paint supplier will be very happy to see you taking a gallon of paint Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 Best way to practice is to get a plastic container and spray it, you can do it as many times as you need to feel comfortable that you will be doing a good job.It doesn't really matter the type of container as long is plastic. You then can experiment with filler, primer (the one for plastic) and spray your templates.Like that you won't be messing with the helmet.The paint supplier will be very happy to see you taking a gallon of paint Great advice thanks. I’d thought a quick practice would be wise but didn’t think of doing it on a plastic container to try out the primers. Quote Link to comment Share on other sites More sharing options...
Cpt_Tact Posted October 29, 2020 Share Posted October 29, 2020 Just a thought but have you considered hydro dipping it instead? Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 Just a thought but have you considered hydro dipping it instead? Yeh I have. Watched quite a few YouTube tutorials on it. Decided to leave that for another day cos I know I’d likely be unhappy with the first dip n find myself scrapping wet paint off a lid!Have you tried it? Quote Link to comment Share on other sites More sharing options...
geofferz Posted October 29, 2020 Share Posted October 29, 2020 My mate on insta does it-he's a nice chap, drop him a message, he'll be happy to chat. https://instagram.com/biketagger?igshid=ix4rbo3l7aw3 Quote Link to comment Share on other sites More sharing options...
Cpt_Tact Posted October 29, 2020 Share Posted October 29, 2020 Just a thought but have you considered hydro dipping it instead? Yeh I have. Watched quite a few YouTube tutorials on it. Decided to leave that for another day cos I know I’d likely be unhappy with the first dip n find myself scrapping wet paint off a lid!Have you tried it? Not on anything motorcycle related but I have done it for rifle stocks and after a few practice attempts and watching videos on youtube it's actually not that difficult. Admittedly these were just single matt colours which meant it didn't really matter on angles/ placement etc but once you have "the dip motion" sorted it is pretty quick and easy.I picked up a cheap plasterers bath to do it in as didn't have the confidence to do it in my bathtub. They held up pretty well for a few years being knocked about and out in all weathers. Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 [mention]geofferz[/mention] thats great thanks. Not quite moving into airbrush territory yet cos with a few exceptions I have a history of taking up a hobby doing it until reasonably proficient and then going “bored of that now.. NEXT”Don’t want to waste money on tools. Although I do like wasting money on tools [mention]Cpt_Tact[/mention] Any pics? Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 29, 2020 Share Posted October 29, 2020 Another thing to bear in mind is to leave the certification sticker alone, do not remove it, you can cover it with tape when you paint over it, but it must remain intact otherwise it will render the helmet not fit to be used on a public highway I wouldn't worry too much about that . Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted October 29, 2020 Author Share Posted October 29, 2020 I spied the stickers on eBay Quote Link to comment Share on other sites More sharing options...
Cpt_Tact Posted October 30, 2020 Share Posted October 30, 2020 @geofferz thats great thanks. Not quite moving into airbrush territory yet cos with a few exceptions I have a history of taking up a hobby doing it until reasonably proficient and then going “bored of that now.. NEXT”Don’t want to waste money on tools. Although I do like wasting money on tools @Cpt_Tact Any pics? Unfortunately not on close-ups and I am now back with wooden stocks so couldn't grab a fresh one, I don't think the admin would appreciate rifle photos on a motorcycle forum. Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted October 30, 2020 Share Posted October 30, 2020 Don't see why rifle stocks would be a problem. After all we've had pictures of dogs, cats, horses, Chinese motorbikes, push bikes, boats, all kinds of tools, garden sheds, knives and God knows what else besides. Quote Link to comment Share on other sites More sharing options...
